Question about Book Computers & Internet
How to get my next book out of dnx fast boot mode
Fastboot Mode on Android from Kingo, which offers the best one-click Android root software for free.
Here's the link:
Aug 07, 2017 | Cell Phones
My screen on my kenwood dnx 6990hd says (DC OFFSET ERROR) What does thay mean
Basically that means there is an overload or some form of power issue with the machine.
The best thing to do is reset the unit to start with. Do you have the manual?
Dec 28, 2016 | Kenwood Knob Dnx-6980 Dnx-6180 Dnx-6190hd...
Why is my tablet Stuck on entering DnX mode.Waiting for fast boot command...
my next book tablet is stuck in dnx fastboot mode, it will not unlocked, and it stuck on voice command
May 12, 2016 | Nextbook Premium 8 Se Android
Tablet says, Entering DNX Mode: waiting for Fastboot command...
I would book mark these links. Below.
Copied from :
What is Fastboot for?
While in fastboot, you can modify the file system images from a computer over a USB connection. Fastboot mode can start on your device even before Android loads, even under the circumstance when Android isn't installed at all. And because of that, fastboot mode is useful for quick-updating the firmware, without having to use a recovery mode. In fact, it's the preferred way to initially install the recovery image. Once you set up, you boot to your phone to fastboot and you can flash image files to the internal memory. Flashing a custom recovery like ClockworkMod is a popular use case. The images you flash don't need to be signed with a particular key, and thus you should use care when flashing. It can also be used for developer operations. Things like erasing partitions and overriding kernel command line options can be done. And all this features make the tool very useful for developing hardware and software solutions, like unlocking the Bootloader of Google' Nexus.
May 11, 2016 | Tablets & eReaders
Unable to find startup file boot.efi
see if you can boot holding the command key (next to the space bar) and "s"; once booted to this text only single user mode, type "fsck -f" and enter; this is unlikely to work (as it also needs boot.efi), so you'll need to use your OS DVD or USB memory stick, boot holding option key (next to command key) and pick that device, then run Disk Utility (may have to go to the Tools menu), select your hard drive, and click the repair disk permissions button
you may also need to just install the OS again (assuming you were tinkering with things you shouldn't have, otherwise, your hard drive might be failing)
Sep 22, 2015 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
I'm trying to reformat my laptop but it's not booting up in DVD can i fix this problem..can you me how to do it to boot up in recovery disk?
Hi tech_sup156 ,
Please follow the below steps:-
  1. On the first screen , press Del or F2 when you boot your computer so that you enter BIOS mode.
  2. In Bios mode search for boot mode or boot devices priority and choose the first boot drive as your DVD - RAM drive.
  3. Now save the changes and exit BIOS and you would find the next time you reboot the PC , it will ask you to book from the DVD - RAM drive , only on the condition that the DVD is a bootable DVD , as usually found in case of genuine windows operating system dvds/cds.
Hope this helps , your feedback would be appreciated.
May 16, 2011 | HP Pavilion dv6000z Notebook
Bios speed slow fast karni hai
First of all, your computer must be completely powered down and turned off before starting this process. You won't be able to edit the BIOS in sleep mode or hybernation mode. Next, power on the PC and enter the system BIOS. How you enter the system BIOS screen will vary according to your computer's manufacturer. This usually involves a series of keystrokes. Which keys are used will depend on your system. Now that we are in the BIOS screen, we are ready to speed up Windows XP boot time. Find the Boot menu and select it using the arrow, Tab and Enter keys on your keyboard.In most systems, you'll find a Quick Boot option. Enabling this will skip common system self tests that occur automatically when the computer is powered up.
In the next step to speed up boot time, look for the Boot Device Priority option. You should change the first boot device to your hard drive. This will speed up boot time, but won't allow you to boot via a boot disk like CD or floppy. If you make this change, then need to boot from a disk later, you can re enter BIOS and change it back. Next, choose the option Exit and Save Changes and the computer will restart.
Always Remeber to do this process carefully because a wrong action will cause destruction and make your computer useless.
Dec 04, 2010 | IBM ThinkCentre 8172 Intel Desktop PC -...
I have Kenwood DNX 7100. I plugged my car charger
how do i put my kenwood 7100 in discovery mode so i can pair to my phone?
Oct 15, 2009 | Kenwood DNX7100 Car Video Player
Playback of audio files does not resume where I left off when powering back on
I have an e260. I use it for audiobooks a lot. I just press pause (centre top of the dial), and the track will resume from there next time (unless I go back to the main menu for radio of course.)
Aug 16, 2008 | SanDisk Sansa e250 MP3 Player
Computers & Internet Logo
62 people viewed this question
Top Book Computers & Internet Experts
john h
jimmy Leo
Are you a Book Computer and Internet Expert? Answer questions, earn points and help others
