Question about Jabra BT350 Wireless Headset
Bt350 when plugging in to charge the lights go from green to orange in less than a second and then to nothing
  • pmaisonneuve Nov 29, 2007
    same problem here! Please help!
I've gotta solution for you. I had the same problem and what I have found out is that if the headset does not go charged for an extended period of time, the battery needs to get kick started so that it will accept a charge. In order to do this, you have to remove the blue plate with a small screwdriver first. Then with an extremely small torx bit take off 2 screws that were under the blue plate. Next remove the board from the shell, but not so much as to disconnect them from the soldered components.
Here's the tricky part. You will see the 150 MAH NiMH battery with a + and - post right on top of it. the connections are about 1/8" thick. You MUST HAVE a battery charger that can manipulate the current and voltage while charging. This would be like a peak charger for an R/C car of which I happen to have. Set it at 150 MAH, and Delta Peak at Auto and in 10 minutes its charged and ready to go. After you put it all back together, you can then again charge it as you normally would with the AC charger or USB connection. I believe the majority of DOA headsets are due to being on the shelf for an extended period of time and not getting some it happens!
Posted on Jan 28, 2008
Thanks Gerald, I had the same problem
Posted on Jan 30, 2008
Why won't my Roomba start when I press a green "clean" button?
Bad PC board. Throw it away. Robot vacs are nothing more than novelties ( expensive toys ) They may do what you want them to do at first but they never last very long and other than brush replacements they are not repairable. If it is within the warranty period you can get a replacement with that.
Jul 01, 2017 | Roomba iRobot 630 Vacuum Cleaning Robot
Cant get it turn on
It likely that rechargable battery is not taking a charge any further or the contacts point of plug are damaged. Sorry to say "it's dead, Jim."
Jan 31, 2013 | Jabra BT350 Bluetooth Headset Headset
Roomba 4220 light says charged but wont turn on
Try resetting
to reset the charging system. You can do this by removing the battery from the robot and unplugging the charger from the wall and robot. Please hold the power button down for 30 seconds. You then should charge the robot....."
Dec 29, 2012 | Vacuums
It wont charge it blinks three times then stops
Hi,Okay, well, I don't want to be a shill for Apple (I mean, heck, I had to buy my Shuffle, so it's not like they're sponsoring this in any way! :-) so let's talk about the color sequences and what they mean.
First off, there are a number of different functions that are denoted by different color sequences, so flashing green might mean one thing when you're listening to music, and something else entirely when it's plugged in and charging or syncing with your PC.
The primary functions are powering on, charging, syncing, and general feedback. Let's look at each.
When you turn on your ipod shuffle, the light will indicate your current charge level:
green = 30-100% charge, you're good to cruise
orange = 10-30% charge, low, but still good for a short workout
red = less than 10% charge, time to plug it in
no light = too late, you've run out of juice
If you see an alternating pattern of green-orange-orange then your Shuffle's crashed or otherwise needs to be restored. Needless to say, that's not a good thing, but probably easy to fix when you hook it up to your PC or Mac.
When you're charging up your shuffle, there are three possible light states:
orange = charging
green = fully charged, unplug whenever you're ready to go
flashing orange = busy, either syncing or in use as a remote disk
When you're playing some music, you can see visual feedback on what's happening and what state you're in:
Press play and
solid green = you're playing music
flashing green = you're in pause mode
Press and hold play and
green-orange-orange-orange = you've disabled your buttons
orange-green-green-green = you've reenabled your buttons
That's bound to be one where people panic and fear that they've broken their shuffles, I bet. If your buttons aren't working at all on your Apple iPod Shuffle 2nd Gen, then press and hold your Play button to see what light sequence you're given. This is also shown by the Shuffle flashing orange when you push a button too.
If your player flashes alternating green and orange, you have no music in the shuffle. This can be because it's fresh out of the box, or because, well, something's happened and the music has vanished. Either way, time to sync with your iTunes library.
If you're seeing a flashing red sequence, you're just about out of battery and just need to plug it in so it can charge up.
Finally, Apple has some good tech notes on the new Shuffle too that you might want to check out if you're still a bit baffled by this tiny engineering wonder: Understanding status light behavior, Shuffle Second Gen, Frequently Asked Questions and iPod Shuffle Support Overview.
Feb 17, 2011 | Apple iPod shuffle Second Gen. Silver (1...
Starts charging then stops
It sounds like the battery has some dead cells and needs replacing.
Oct 12, 2009 | Acer Aspire 5315 Notebook
Orange battery light on, but computer says its running on electrc
Hi, the orange light is meant to show a charging status, so if you have orange light and its running on electric it just means its plugged in and charging.
Mar 09, 2009 | Dell Inspiron 6000 Notebook
My ipod shuffle blinks orange when it should be charging
Make sure that you plug your ipod into a high power usb port. Also some computers won't charge it if the comp is in sleep mode.Try using the usb on the back of the tower. The indicator light will be a steady green if it is charged. Also make sure you haven't disabled the ipods buttons.
Jan 21, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Does not switch on and there is no orange chg.light or green ligh
Your' battery may be bad, have gotten disconnected, or the battery is dead, and the charger is bad.
Dec 29, 2008 | Sony DVP-FX810 Portable DVD Player
My DS will not switch on with or without the charger connected. When i plug into the charger the orange light flashes for 1/2 a second and goes out again, but no other reaction. My ds won't switch on but...
try to charge it with another battery,if that does not solve the problem then there is a blown fuse inside the board.its besibe the battery terminal to the right.but first you have to open the unit using a triwing screwdriver and a small precision phillips screwdriver.
Dec 18, 2008 | Nintendo DS Lite Console
Jabra BT350 Wireless Headset Logo
255 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
