Question about The Office Equipment & Supplies
My unit which is about ten years old mounted inside the roof switches on and runs for ten seconds then switches off. I've switched the mains off, I've reset, nothing works. Any ideas?
    Top Expert:
  • The Master
  • 48,549 Answers
Call a local service company
Posted on May 02, 2017
  • The Master
  • 9,348 Answers
First we have no idea what kind of unit you are asking about??????
How do u reset kelvinator reverse cycle airconditioning system
Ok first there should be a switch on the wall near the Condensing unit this is the unit outside Switch off for 10 sec and then back on if cant locate switch just switch circuit breaker labeled with Ac or just switch main circuit breaker off for ten seconds
Jul 15, 2014 | Heating & Cooling
Bizhub 751 c 3803
Sir/Mam,
Turn off the main both power switch one located inside the front door, second on the control panel, then wait ten seconds. then turn on main inside first. Then holding down the utility/counter button turn the sub power switch on. You must keep the utility button down The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit check. Have a qualified tech look at it. :( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! Fire could occur that would ruin a perfectly good day!!!!
Jan 08, 2014 | Minolta bizhub 350 Black and White Copier
Minolta 451 erro 3-b04
Sir/Mam,
Turn off the main power switch located inside front door. Then holding down the utility/counter button turn the main power switch on. Close front door you must keep the utility button down also make sure that the sub power switch is on. This is the switch on the side of the control panel. The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit High Current Device for the fusing unit. Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! hope this helps
Oct 23, 2013 | Konica Minolta KONICA BR BIZHUB C451...
HOW DO I CLEAR ERROR CODE C3B04
Sir/Mam,
Feb 02, 2013 | Konica Minolta KONICA BR BIZHUB C451...
Powers off immediately after starting
My immediate reaction would be to cut your losses and buy a new unit as sooner or later you will run into a part that is no longer available.
Nov 03, 2012 | Whirlpool Microwave Ovens
What kind of game disc do u use in a VOD 102 roof mount player.
There is no "game disc". The unit comes with a wireless game controller. When switched on a list of ten games is displayed on the screen.
The other route is to connect a seperate gaming unit through the inputs located along the edge of the unit, select source until the gaming device logo appears on the screen, begin paying.
Sep 07, 2012 | Audiovox VOD102 Car DVD Player
C-3725 trouble code
Sir/Mam,
Turn off the main power switch located inside front door. Then holding down the utility/counter button turn the main power switch on. Close front door you must keep the utility button down also make sure that the sub power switch is on. This is the switch on the side of the control panel. The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit. It will be expensive!!! Sorry:( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!!
May 18, 2011 | Konica Minolta KONICA BR BIZHUB C451...
Error message c 3725 konica minolta c 550
Sir/Mam,
Turn off the main power switch located inside front door. Then holding down the utility/counter button turn the main power switch on. Close front door you must keep the utility button down also make sure that the sub power switch is on. This is the switch on the side of the control panel. The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit. Which will be expensive!!! Sorry:( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!!
Mar 08, 2011 | Konica Minolta KONICA BR BIZHUB C451...
Error message 3725 on Bizhub C451, how do i reset so I can print
Sir/Mam,
Turn off the main power switch located inside front door. Then holding down the utility/counter button turn the main power switch on. Close front door you must keep the utility button down also make sure that the sub power switch is on. This is the switch on the side of the control panel. The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit High Current Device for the fusing unit. Which will be expensive!!! Sorry:( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!!
Sep 24, 2010 | Konica Minolta KONICA BR BIZHUB C451...
Roof mounted spotlights
You can run the power wire into the cab to a universal
toggle switch. Then run a wire from the other side of the switch to the + side of your second battery.
Ground the light at the mounting point. Be sure to use a 20amp circuit breaker toggle switch, or splice in an inline fuse holder with a 20amp fuse, on the +
side. Hope this helps. Good luck.
Feb 07, 2010 | 1999 Toyota Land Cruiser
32 people viewed this question
Top The Office Equipment & Supplies Experts
Victorman
Victorman
micky dee
fhonwizards
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
