Question about Garden
How to use K2 pressure washer
Cannot find instruction details
3 Suggested Answers
eugbug
  • 479 Answers
SOURCE: I would like the instruction
The manual is available on the Karcher website here:
http://www.karcher.co.uk/uk/Products/Home__Garden/Pressure_washers/Entry_class/16724110.htm
Click on product manuals and then pick the fourth file in the list.
Posted on Mar 22, 2011
  • 5631 Answers
SOURCE: How much should I sale a karcher k2. 35 pressure washer for?
Let's say, maximum about 60 USD if it's in perfect conditions
Posted on Oct 02, 2015
Using K2 Karter pressure washer
Try Googling (karter)(K2)(manual) without parens.
May 02, 2017 | Garden
Oct 02, 2015 | Karcher Garden
Its leaking water
Take it out of case
Connect to hose. Turn on tap & see were the leek is.
Jun 14, 2015 | Karcher 16016080 K2 26 1600 PSI Electric...
Karcher K2 seams to be directing pressure away
Need a better description of the problem
Oct 04, 2014 | Garden
Karcher K2 seams to be directing pressure to soap
If you use the wrong tip when trying use pickup tube, you will force water into the tank. You can only use the low pressure suds tip. There are typically 4 tips- 0 deg, 15deg, 40 deg and a soap tip. You cant pressure wash and use soap at same time.
Karcher k2 900
You tube, karcher k2 900 take apart, This is the easiest way to do it,
Apr 16, 2014 | Garden
I have no pressure and the pump surges when i release the trigger on my electric karcher modle k 2.360
If you have a Karcher then you should always post your machines barcode.
Because you have the low pressure and pulse this will be the valve block. Your machine has 3 piston and each has 2 valves (inlet and outlet). Because you dont have the barcode, i cant be sure if you will buy a valve kit of 6 valves or a pre-assembled manifold block.
it could be this machine and spares :
http://www.sparesgiant.com/cleaning-equipment/pressure-washers/karcher/k-series-parts/k2-range/k2-36m16724300/
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Sep 01, 2013 | Karcher K238CCK 1600 PSI 13 GPM Electric...
I would like the instruction book for the Karcher k2-59 pressure washer
Mar 21, 2011 | Microwave Ovens
I need to replace the high pressure outlet on a k2-26m elecreic
if you contact Karcher they will tell you where your nearest supplier is located. try this link.
http://www.karcher.com/int/contact.htm
Sep 19, 2009 | Karcher K2.26 Electric Power Washer
Garden Logo
70 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
