Question about Garden
Using K2 Karter pressure washer - Garden
    Top Expert:
  • Garden Master
  • 40,263 Answers
Try Googling (karter)(K2)(manual) without parens.
Posted on May 02, 2017
How much should I sale a karcher k2. 35 pressure washer for?
Let's say, maximum about 60 USD if it's in perfect conditions
Oct 02, 2015 | Karcher Garden
Its leaking water
Take it out of case
Connect to hose. Turn on tap & see were the leek is.
Jun 14, 2015 | Karcher 16016080 K2 26 1600 PSI Electric...
Karcher K2 seams to be directing pressure away
Need a better description of the problem
Oct 04, 2014 | Garden
Karcher K2 seams to be directing pressure to soap
If you use the wrong tip when trying use pickup tube, you will force water into the tank. You can only use the low pressure suds tip. There are typically 4 tips- 0 deg, 15deg, 40 deg and a soap tip. You cant pressure wash and use soap at same time.
Karcher k2 900
You tube, karcher k2 900 take apart, This is the easiest way to do it,
Apr 16, 2014 | Garden
How can I remove the top cap of the winding lever for Pentax K2? This is for me to remove the top cover as the lever is a bit sticky and I would like to lubricate it
K1000: Remove counter cover (3 setscrews around perimeter), remove counter disk (screw is right threaded - turn right to remove!!!!!), washer if not glued to bottom of disk, round nut with slots (also right threaded), lift off counter base, three advance lever spring screws, turn spring until loose, remove advance lever, remove washer underneath
K2: using a rubber stopper, and downward pressure on the cap/ cover screw, turn to right (this cap screw is right threaded!!!)If you try and turn it like you would a normal screw you will break it off. If the camera has corrosion under the cap screw it may stick - try heating with a soldering iron (careful the screw cap will be very hot). In extreme cases I have drilled two holes (one on either side) and used a pair of round nose fine tip pliers to turn it.
Unsure of which model you have as both are mentioned in post
Oct 25, 2013 | Pentax K1000 35mm SLR Camera
I have no pressure and the pump surges when i release the trigger on my electric karcher modle k 2.360
If you have a Karcher then you should always post your machines barcode.
Because you have the low pressure and pulse this will be the valve block. Your machine has 3 piston and each has 2 valves (inlet and outlet). Because you dont have the barcode, i cant be sure if you will buy a valve kit of 6 valves or a pre-assembled manifold block.
it could be this machine and spares :
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Sep 01, 2013 | Karcher K238CCK 1600 PSI 13 GPM Electric...
My washer was running fine and it just stopped. Now It won t start again. Any help!! Model K2.97
Check the fuse on the unit. Since this is a electrical unit, it may have also tripped your main breaker on your power source. If using an extension cord, try to use a larger one (size of wire) and shortest as possible. For more info go to www.karcher/ (Troubleshooting problems) .... Good luck.
Dec 04, 2010 | Karcher Garden
I need to replace the high pressure outlet on a k2-26m elecreic
if you contact Karcher they will tell you where your nearest supplier is located. try this link.
Sep 19, 2009 | Karcher K2.26 Electric Power Washer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
