Question about Garmin GPS
My garmin S3 will not load, and keeps showing can't authenticate maps. How do I fix this problem
marcelbakker
  • 174 Answers
SOURCE: Won't stay on
Have you installed anything lately? Do you have any sd card installed? Usually this is the cause for it to crash. There is a reset on the bottom of the nuvi, when it locks up blank, press the reset button and see what happens...
Posted on Jul 08, 2008
jonniewalker
  • 1031 Answers
SOURCE: how to load maps from google to garmin
This solution works for more than the 760. i think it will work for all 6xx and 7xx series.
a simple solution to convert Google maps to Garmin routes and is found here:
http://www.elsewhere.org/journal/gmaptogpx/
In essence, you create your route in Google maps and then click the recommended url bookmark.
Save the GPX file to the Garmin device and from "My Data" (under Tools) convert the file to a route. You are done.
hope this helps pls appreciate by rating as fixyaa thanks
Posted on Nov 23, 2008
SOURCE: Garmin Nuvi 205 keeps saying no maps available ???
This is easy. You have to run your software, select the maps tap and then transfer maps to the device. Chances are good you uploaded a 2009 map on top of the 2008 map. The updater doesn't delete maps.
Your unl file only has one key, you have two maps loaded. Simple go into the garmin directory and delete the map file and the mapsupp file. You can easily find them because they are greater than 500 mb.
Then run mapinstall (google for the file). This will install your most current map to the Nuvi. You are back in business.
Posted on Apr 12, 2009
RPFinney
  • 385 Answers
SOURCE: garmin nuvi 200 after upgrading drivers, it keeps
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
Regards
Richard.
Posted on May 19, 2009
  • 30 Answers
SOURCE: Garmin nuvi 250
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Posted on Jul 14, 2009
Hi, do you know if I can install City Select maps I bought for a previous Garmin device now out of order, on a new Garmin 1490T preloaded with City Navigator ? thanks
If you want to test the maps on your new Garmin you can do one of two things. Either you can copy the maps onto an SD card and then insert the card into your GPS. You can also connect the GPS to your computer with the USB cable that was supplied with you unit. Using whatever file manager you normally use with your version of Windows (Windows Explorer, Total Commander, etc), you will be able to see your Garmin GPS as another drive on your system. You can then copy your City Select maps over to your Garmin.
Once you have the maps either directly on your Garmin GPS or on a microSD card, you have to choose to use those maps. From the main screen of your GPS choose Tools>Settings>Map. If your City Select maps are compatible with your GPS they will show up in the list of maps. To make use of the map just choose it by touching the name of the map. Your Garmin will then load that map and display it. If your City Select maps do not show up in the list, or if you choose them and they do not load or give you an error then they are not compatible with your 1490T.
If you need anymore information or help please let me know. Thank you.
Mar 12, 2011 | Garmin nuvi 1490T GPS Receiver
I want to update my new garmin nuvi 245 where du I go?
Goto garmin website.
Download web updater
Run this program and then connect the gps, it will then show what updates are available (not maps)
for maps your device needs to be registered on garmin website and it will then show you what maps you can buy for your device.
Please dont forget to vote this answer was helpful
Many thanks
Feb 17, 2011 | GPS
Unfortunately deleted the maps suppled withe the device.Hve obtained the basemap and sum file on dics from garmin and have loaded it to the device however the maps are not showing up.Have downloaded...
When reinstalling the maps to the unit, use the program Map Install from garmin. If you did and still cant find your maps, call garmin back and have them remotely access your PC. They will be able to fix your issue.
Hope this helps!
Feb 12, 2011 | Garmin GPSMAP 62s GPS Receiver
Garmin nuvi® 255W Car GPS Receiver. Problem: Reboots during Map
The simple way is to send the unit to Garmin they will load the maps for free.
If you keep trying - try this -
With your thumb in the lower right corner of the screen - pushing in - like there is an X there - [ push with your thumb before you turn it on] Turn it on -
when this screen comes up - push YES -
then try your maps.
If they do not load on your pc [ which must have the unit hooked up and a legit copy of the newest maps ] then send the unit to Garmin. They will load your maps for you FREE. 86278d7.jpg
May 11, 2010 | Garmin nuvi 255W GPS Receiver
My GPS keeps saying cant unlock maps after i already loaded maps on it
The Garmin Maps require a map unlock code in order for the GPS to be able to open/access it. Since the maps are copyright protected by Garmin you should of recieved the unlock code from Garmin when you purchased the new map update.
Mar 07, 2010 | Garmin GPS
Have usa garmin nuvi 260 ,want to load austalia maps how?
well you need to update the firmware of your gps also call garmin customer support they are great tell them about the map, also the poor satelite cover might be because of your location or weather conditions
May 26, 2009 | Garmin nuvi 200W GPS Receiver
Garmin 710 Doesnt show all the maps
Garmin maps are married to the device they were bought for. You should not be able to take an SD card from one and have it work in another. Another point is, was the 710 already registered to someone else and never deregistered? Have your registered the 710 and does it show up on your Garmin account?
If the 710 is not on your account, Run Garmin Express (download from Garmin). Connect the 710 to your PC. Any maps that the 710 is entitled to will show up in Garmin Express. You may have to buy the map on Garmin if the 710 never had it before.
Mar 30, 2017 | Garmin NUVI 710 Car GPS Receiver
I have a Garmin 350 that won't load maps and stays frozen what can I do to fix problem
Have you tried a software upgrade. Talk to Garmin, they were pretty helpful when I talked to them.
Oct 07, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 250 mapsource
Verify that you have the correct basemap for the country that you are in. There are two maps inside a new Garmin. The basemap which shows all the major highways and mapsource which shows all the street. If you don't have the correct basemap try changing 'Navigation' Advoidance to avoid highways and Toll Roads.
Sep 25, 2007 | Garmin nuvi 350 GPS Receiver
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
