Question about LG Washing Machines
I WANT TO buy leveling screws for LG washing machine front load in India. LG do not respond on this. where will I get those bolts in India? I am unaware about the bolt size. The model is WD-1409TP
  • 209 Answers
SOURCE: Brown spotting on washed clothes
chances are if you have eliminated anything thats got in by accident that the drum bearings are about to go, the drum bearings are protected by a water seal, this has started to leak and is now washing the grease out of the bearings back into the wash, you may also find a small amount of water on the floor, if you also remove the back and look behind the large pulley you may also see brown water marks running from the center of the outer drum
the next step will be a very noisy spin, like a rumbling noise
Posted on Oct 15, 2007
SOURCE: Washer LG Model WD-8013F Noisy & vibrates badfly when spinning
I had same problem, the bowl is supported by (2) large springs from the top & two telescoping shock absorbers underneath.
I inverted the machine, found a large hollow retaining plastic bolt had falled out of the shock absorber,causing the bowl to be out of balance & the drive belt to be missaligned.
I reinstated the plastic retaining pin/bolt then tried the machine again.
Now the damn thing refuses to wash or spin.
I'm not happy.
Posted on Nov 06, 2008
  • 3463 Answers
SOURCE: Drum locking bolts - front loading washing machine
If the hole is in the rear cover of m/c, then it should be o/k, if it is in the side then it could have caused some damage.
Plz rate my solution.
Posted on Jan 18, 2009
  • 11361 Answers
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Posted on Dec 23, 2009
SOURCE: How to increase the water level of Front loading washing machine
I have used extra weight inside the tub. I have used bottle of water and also a plastic 2 or 5 pound weight.
Posted on May 05, 2010
How do you adjust the water level on an LG front loader washer?
You cant, water levels are factory set for optimum water efficiency, new machines use a lot less water than older machines, poor wash results are usually caused by over loading
Oct 17, 2013 | LG WM-2277HW Front Load Washer
Not Spinning LG WM2301HR
Steve R is right except that if the splines in the rotor are stripped you will have to buy a new rotor or the bolt will just continue to lossen itself up. The rotor is $64.33 online. Still a ten minute fix, after you wait a week for part delivery.
Jan 11, 2012 | LG WM-2077C Front Load Washer
We have moved to a different city and as adviced we got the drum locked for safety. How can I remove that, its a front load LG washing machine
the locks on LG machines are normally 2 or 3 long bolts on the rear of the machine screwed into the back of the drum. all you can normally see are the bolt heads, with what may appear to be a plastic washer on them.
hope this helps
May 13, 2011 | Washing Machines
LG WD-12124RD How do I remove the front panels?
most machines now open from the back you will find 2 or 3 screws/bolts at the top holding on the top section if you un screw those then slide the top back slightly it should unclip allowing you to take off the top this should expose some more screws or bolts that will be holding on the front & sides, if your machine is leaking from the front you could have a leaky door seal too so you may want to check that before starting to take it apart.
Hope this helps
Apr 23, 2010 | LG WD-12124RD Front Load Washer
We recently moved and brought our LG front loader washing machine with us. It is now located on the second level of our house and it is vibrating all over the place. Any quick fixes without call a...
make sure it is level and the floor is good and solid.
you can alos remove the lid and back panel and check the shocks and the suspension springs to make sure none of those became dislodged during you move.
Di you put the shipping bolts back in when you moved the unit?
Feb 16, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer will not stop shaking during spin cycles, we have removed akll shipping bolts
Place a load in the machine use a good level to get machine perfectly level. Now put machine on spin and check the feet. Find the one that is not solid and slowly adjust it until it stops shaking. PS place level on flat top surface and level side to side and front to back.
Jan 26, 2010 | LG Washing Machines
My LG front loading Washer 1.5 yrs old
They told you right. This problem has to be done by a service tech. If you are sure it is level and all feet are touching the floor when it vibrates it is an internal problem.
Jan 13, 2010 | LG WM-2077C Front Load Washer
May 03, 2008 | LG WM-2277HW Front Load Washer
Walking during the spin cycle
Is your floor level, first thing. Okay, the rear 2 legs are not adjustable so leave it. The front 2 legs should be screwed up (ie the machine should be at the lowest level in front) and there are check nuts to tighten inside the body of the machine. Check the machine it it rocks by using your hand against it. Adjust accordingly, this is if your floor is not too good. You shd not hv any problem. If the rocking persists check inside machine, behind after getting he plug off wall, maybe shockabsorbers hv come off, springs?.....
and rate me please if helped.............
Jan 12, 2008 | LG WM2277H Front Load Washer
Washing machine
Try leveling the machine, get a simple bullet level and place it on the top center and level side to side then place the level on any side and level front to back.
Jul 26, 2007 | LG WM-2077C Front Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
