Question about Garden
How to replace pto belt on club cadet model ii1046
4 Suggested Answers
  • 3074 Answers
SOURCE: Need to replace Deck Belt
this may help Tim:
http://www.ehow.com/how_6182447_remove-mower-deck-cub-cadet.html
Posted on May 26, 2011
  • 6468 Answers
SOURCE: Cub Cadet LT1042 PTO
you only need to remove the center bolt but make sure you see where the pins that keep it from spinning go this will help put it back togeather
Posted on Jun 04, 2012
  • 48 Answers
SOURCE: How to change pto belt on club cadet 1046
To replace a transmission drive belt on a Cub Cadet LT1046 you need to remove the deck, preferably put the front wheels up on blocks or stands, unplug the PTO power (directly under the engine, which can be a pain ) You need a 5/8" socket to get the bolt out of the PTO pulley assy.(electric clutch). If you don't have an impact wrench take a spark plug out and push rope into the hole. This will bind the cylinder and keep the drive shaft from turning. Remove rope and replace plug when finished. Battery and/or spark plug wires should be removed for this process for safety.
The PTO may be stuck on there so you may want to tap it with a hammer and a block of wood carefully to release it. Loosen old belt from tensioner pulley. Lower engine pully on drive shaft, below pully "keys". It may be difficult to remove. Spray with "PB Blaster" or similar bolt loosener spray. Remove old belt from engine pulley first, transmission pulley last. Remember how belt goes around pulleys before doing so, make a diagram to help.
You'll need to put the belt on the transmission pulley first then thread the belt up to the engine pulley. Thread your belt back through the pulleys and tensioner (make sure your spring is strong enough to tension the belt or buy a new one).
The PTO pulley is "keyed" on the shaft. Replace bolt and washer. Torque bolt to 38-50 ft. lbs. using the rope meathod as described before. Put your deck back on and you're ready to mow again
Posted on May 11, 2017
May 11, 2017 | Garden
How do i replace v belt on ltx 1040 cub cadet.
Nolan, Check the attached links,instruction and guides for belt replacement on Cub Cadet. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change the Deck Belt on Cub Cadet Riding Lawn Mower Using Model...
How To Install or Replace Drive Belt on Lawn Mower Cub Cadet
How to Change the PTO Belt on Cub Cadet Riding Lawn Mower
cub cadet belt replacement diagram Google Search
Jun 30, 2016 | Garden
Need diagram to replace belt on cub cadet mower
Hi there r photos on how to fit the belt. Type in Google. cub cadet mower photo of belt. There r also movies on YouTube how to fit belt. Type in how to change the PTO belt on ? cub cadet , good luck
Apr 20, 2016 | Cub Cadet Street Sign- tractor lawn riding...
What does PTO stand for
power take off which drives the belt that runs the mower deck sounds like a dead short in the pto clutch maybe a wire shorting out check for bare wires
Apr 17, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
Club cadet i have a noise when pto is engaged
have you taken of wire, could have done bearing in one of the pulleys or spindle housings probably the one that had wire around it
Mar 18, 2013 | Cub Cadet Lawn Mower Electric PTO Clutch...
Jun 01, 2012 | Cub Cadet Street Sign- tractor lawn riding...
I have a cub cadet series 1000 LT 1024 need to replace drive belt, how do i get the pto clutch off?
You donot get PTO of to change the belt. if you want to take the pto
clutch Need to turn the opesit way left
May 31, 2012 | Cub Cadet Garden
I have a cub cadet LT1042 and it is 3 years old...we have replaced the pto 2 times and replaced the belt 7 times what is the deal
You have to have something rubbing under there that isn't supposed to be, crawl under the tractor and watch the belt go around by hand, if you can turn it. Maybe see what is frozen up, in the wrong place, Gotta be a belt guide is rubbing or a pulley is not spinning. The PTO should last 20 years, all i can think is they got it too tight to start, .010" min, that is tight, and you must be in Florida picking up a lot of sand? If it was under any kind of warranty, I would raise a big stink about it. Those PTO's are not cheap. And the belt has got to be $20. I wouldn't go to a dealer for the belt, unless it is really special, just match it up at the auto parts store, for half the price of dealer. Hope this helps.
Jun 18, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
