Question about Blue Video Game Consoles & Games
Acoustic solutions flatscreen tv, wont turn on, blue stanby light on but when press button nothing happens but blue light blinks on n off
Basically what i said above, it was working fine last nite turned it off to go to bed & now this, ive turned it off & on at wall, pressed every button- acoustic solutions flatscreen tv, wont turn on, blue standby light on but when press button nothing happens but blue light blinks on n off,& it has a ps3 & digi box hooked up. help please
SOURCE: nokia 6300 wont turn on, blue lights on side stay on
I had a simliar problem with my k800i, it turned out that it needed its firmware/software updated. So u can either get it "flashed" at a shop (around £10) or you can try doing it at home but you'll need the software and the data cable for the phone. Google it i'm sure you'll find something. Good luck
Posted on Sep 28, 2008
SOURCE: Blue light
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first.
Posted on Feb 20, 2009
  • 979 Answers
SOURCE: tv wont turn on
Hello Charliebigwh, hi technically your monitor's power supply has a problem, this is either your switching regulator does not work or there is a short in that section, If you want to do it your self, need to replace all large value, and or high voltage capacitors(especially the capacitors with its top is bubbly), need also to replace the switching IC, and power transistor.
Have it checked by a technician if you cannot do the work.
Posted on Apr 15, 2010
Testimonial: "how helpfull thanku kindly !"
SOURCE: My Tv wont turn on, the standby light stay orange,
Hi, l had the same problem. HAD !!
l bought a universal remote control (5 euro), but unfortunetly no codes for Acer in it.
Then l did the setting up by auto search and YES : there was a code. But, wheeehh, it did not work.
A little bit sad l took the Acer control and guess what: it worked again!!!!! l guess the TV had a total reset, and l use only the Acer remote control now.....
Female and blond!
Posted on Nov 26, 2010
SOURCE: Acoustic Solutions LCD26761HDF TV turned
The solution to Acoustic Solutions problems, such as intermittant power off and flashing blue light is very simple: dump it in the trash. This product has lots of problems which are associated with memory and timing. There is no software update available, its just cheap Chinese ****.
Posted on Nov 29, 2010
I've searched far and wide, starting with RCA too no avail. Just don't see a model number or any program instructions. Again, it's a very old remote.
Wow ,, without the model number for that it will be very hard to give you step by step instructions or even tell if its compatible. but dont fear there is a possible solution. Notice that code search button the the remote ?? well basically some TV's share the same code so even if it inst listed doesn't mean it wont work.. Unfortunately you will need manual to tell you the exact procedure, but it should be something along the following..
1.) turn the tv on
2.) press and hold code search for 2 seconds or more until the LED lights continuously,
3.) press the tv button the led should blink and go out or bink and come back on.
4.) press the power button, if the tv turns off press the enter button to store the code.
5.) if nothing happens repeat steps 4 and 5.
Dec 27, 2012 | Televison & Video
Acoustic Solutions LCD26761HDF TV turned itself off & standby light started flashing. TV wont respond to remote or on set buttons
Sep 25, 2010 | Daewoo DLP3212 32 in. LCD Television
Tv wont turn on
Apr 15, 2010 | LG 32LG30 32 in. LCD HDTV
Black screen, blinking green light, nothing happens
Hi it is the indication of error code......can you tell me how much time does light blinks......
Jun 03, 2009 | Mitsubishi WD-52528 52" Television
My sony TV wont turn on.
Un plug and let stand for one minute. If it still does blink then use the reset on the remote and press it while pressing the power button on the TV.
Jan 19, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Acoustic solutions mp3 player
when i try and play my mp3 i click the on button and a blue light comes on with the acoustic solutions logo but nothing else happens
Aug 31, 2008 | Audio Players & Recorders
Acoustic solutions TV
There is not a RF TV signal or the RF circuit is has a bad funtion, try to verify de antenna connection
Feb 03, 2008 | Audio Players & Recorders
My 50" hitachi ultravision won't turn on
i got a 62VS69A model type hitachi tv.... and it was thunderin and lightning outside all day .... and i left it on ... and when i woke up ... it was off..... and when i went to turn it back on.... it blinks blue,, then the light below it blinks red.... and the light below that light blinks red .... and then the first blue one again ... and over and over again ... untill finally it juss stays red... i donno whats goin on with this tv... im assumin it was the bad weather outside that did it but im not sure..... can someone PLEASE help a brother out ? lol
Nov 16, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Blue screen and shut off by self
You will need to reset the Netcommand and tuner settings in the set. The little indented button in the front of the set needs to be pushed in (when the set is off). The front light will blink for about a minute or minute and a half. Then, reprogram the Netcommand settings. This should solve your problem. If you need more information, then, reply to this post and I will respond.
Sep 23, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Video Game Consoles & Games Logo
Top Blue Video Game Consoles & Games Experts
James Wishart
Are you a Blue Video Game Console and Game Expert? Answer questions, earn points and help others
