I cancelled my business landline over 1 year ago,they only stopped billing me a month ago and has not refunded me yet.
  • 51 Answers
SOURCE: incorrect monthly billing
It is not Xbox Live since they don't charge that much. It could be a netflix account though, but they don't charge that much either. You will need to contact your bank for full information. They will also give advice on how to claim back any money you may entitled to.
Posted on Jan 24, 2009
  • 860 Answers
SOURCE: landline is always busy
If its still showins as a busy when the phones plugged in at the NId ( the box outside) then the trouble is showing towards the telco . Call your local provider for repair.
Posted on Oct 09, 2009
  • 15935 Answers
SOURCE: my jenn-air electric range is about 18 years old.
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
  • 12 Answers
SOURCE: i cancelled my membership months
First, I advise you put a stop payment at your bank for the charging company. You can ask the bank to trace the transaction source for contact details, sometimes you have to request in writing that is sent priority mail with signature required.
Posted on Jul 04, 2011
  • 126 Answers
SOURCE: Please give ma refund to
hello please write your complaint to the concerned person. you can use this link and complain. And if this solution was helpful please vote it beolw. thank you.
Posted on Jul 21, 2011
Why was I already billed when it specifically said 30 day free trial
Well you would need to contact whatever service you're talking about. Fixya has nothing to do with any billing.
Feb 10, 2017 | Computers & Internet
I want to unsubscribe to the digital New York Times. How do I go about it?
You can change or cancel your subscription at any time. U.S. subscribers should call Customer Care at 1-800-NYTIMES (1-800-698-4637). If you are outside the U.S., click here to find the Customer Care phone number serving your country.
When you cancel, we will stop charging your account the following billing cycle. Each billing cycle is four weeks, so your access will continue for the remainder of the current four-week period.
View the full NYTimes cancellation and refund policy »
Dec 08, 2016 | Miscellaneous
I cancelled NetZero and I have another ISP. They say they cannot refund for August which just posted. That does not seem right. Can you help?
With such things there is a cancellation period. It is often ONE FULL billing period. It your subscription is from say 2nd of the month of May and you cancelled it on the 5th May, you would have to pay all of May, and then all of June (one full period) and your sub would end 1st July.
Not a 'simple billing activity', you are terminating the contract you signed. It will be in the small print somewhere when you signed up that nobody ever reads :>)
Jul 28, 2016 | Computers & Internet
How do I cancel a trial subscription
Depending on the business this might be rough. I'd contact them and ask to cancel if you have not done so...
I had a similar circumstance with my digital radio subscription account which might give you some ideas. I called several times and told them I no longer wanted to continue my yearly subscription. The gal at their "Customer Service" would not hear of it then offered steep discounts. I told her to cancel at least three times but they still billed me for a year.
I checked on line and found the DA for Manhattan where they were based had 3,000+ complaints aginst them for this so I filed a complaint with the district attorney's office on line at 2AM. I was then promptly contacted by digital radio CORPORATE CUSTOMER service rather than just customer service - Corporate was in DC.
They apologized and promptly refunded our money. I was still bombarded with emails and offers from them until I sold off all three of our digital radio receivers then they stopped. We bought an Internet Radio Tuner with 16,000 channels and no longer needed them.
If you put this on your credit card call your bank and stop them from billing you or they will keep doing so. Check for their corporate customer service rather than customer service. Go to your state's consumer affairs office and ask for their help if they keep sending/billing you or possibly your local district attorney or state's prosecutor to make a report and seek local help.
Goold Luck!
Aug 12, 2014 | Televison & Video
I want to cancel
Go to this link:
In the left panel, click on the Refund Information link.
Aug 05, 2014 | Symantec Norton 360 for PC (037648318846)
Itok complaints
wouldn't be these people would it. the number is on the page.
you didn't say which country as there is more than 1 business called itok.
Jun 27, 2014 | Computers & Internet
I cancelled my membership months ago and got debited on the27th april 30th may and 2nd july my profile had been removed and repeat billing cancelled my card no are 5163 7612 or this card 5163 5050 please...
Jul 03, 2011 | Computers & Internet
Need a refund on my cupid account
i canseled my substriction i want my money back refund urgenty
Apr 13, 2011 |
Charges on my mastercard
write to the people who have your details, give them written confirmation to stop the service
Aug 27, 2009 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
