Heating gets to he temperature clicks off and wont restart when room cools down how do we get it to click back in
  • Heating & Co... Master
  • 1,082 Answers
How does it be gained heating in the first place?? Possibly a bad tstat? Good Luck!!
Posted on May 02, 2017
My thermostat is set on 68 degrees and it shows room temperature is 68, but the furnace still kickson, Honeywell said it has a 1 degree difference. so what's the problem then?
Yes there is a one degree tolerance, in fact my heater just kicked on and it is set to 67 and the inside temperature reads 67. It is also a Honeywell.
Dec 28, 2016 | Heating & Cooling
Why is my portable air conditioner blowing out room temperature air?
Make sure the filter(s) have been cleaned (Washed) and that the thermostat is set to the correct temperature. If the room temp is the same as the setting on the air con, it wont cool or heat. Just the fan will be operating.
Sep 10, 2014 | Heating & Cooling
My portable dental compressir is not starting up only the fan is working
Try this, disconnect from power source and let it cool down to room temperature. If the unit over heats it will go into a thermal cutoff.
The compressor has a bi-metal temperature sensor attached to the body. In most cases it is along side of the compressor terminals.
While you are in that area, look for burnt wiring or loose wires.
Assuming that the compressor has over heated and in a thermal, try restarting the unit and see what happens.
If it still wont start and is not tripping breakers, check the start/Run capacitor for bulging or leakage.
May 07, 2014 | Heating & Cooling
Heat pump compressor wont come on in heat mode, works fine in cool mode, we get heat occaisionally for about 2 min, then the compressor shuts off. it is a fridgedaire window unit.
Try setting the thermostat at a normal heat setting. By raising the temperature too high the unit thinks that the heat pump won't be effective and go into strip heat mode.
Nov 17, 2013 | Frigidaire Energy Star Room Air...
My AC unit is 3 years old. its set at 72 but wont go below 78 degrees. im in Las Vegas...Help
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the AC manufacturer or a service person to verify the cooling system is operating correctly.
Or call the techline 18002842925.
Jul 18, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Its not cooling down even though I can hear the motor running
Jul 17, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Projector heating up and bulb shuts down
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Jul 08, 2010 | Dell 2300MP Multimedia Projector
We have the white and rodgers thermostat model 1F81-261. The problem is that the ac unit will not work. We have reset and changed the batteries and set the point 4 degrees less than the actual room...
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating system is operating correctly.
Reset the thermostat by pressing , UP,DOWN and TIME at the same time.
Jun 28, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Freezer won't run
There is no reset switch. There is a thermal overload protector mounted on the compressor. Does the compressor hum and then give a click sound. If so your compressor has failed. If the compressor is cold (Room Temperature) and it does not try to run your thermostat may be bad. If so remove the temperature control and jumper the two main wires that connect to the control. Unit should be unplugged to do this operation. Insulated the wires so they do not contact any metal surface. Plug the freezer back in. If it runs and cools replace the thermostat.
Jul 01, 2008 | Freezers
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
