Question about Yamaha Audio Players & Recorders
Yamaha rxv375 says check sp connection when turned up then turns it self off
    Genius:
  • Yamaha Master
  • 1,054 Answers
One of your speakers or speaker wires are shorted
Posted on May 02, 2017
I bought YamahaRXV375 online. Can anyone help with firmware?
google it sometimes if you input the model number and name, it will come up with what you need to repair it
Mar 09, 2015 | Yamaha RXV371
What settings for Yamaha rxv375 sub bass on set up
Check to ensure you don't have a high pass filter set on the amp or radio!
Sep 02, 2014 | Car Audio & Video
How to reset yamaha rxv375 receiver won't turn on
hold the 'tone control' and 'info' buttons and press power. If the unit shuts back off immediately, then you have a problem that needs to go into a shop for repair.
Jun 23, 2014 | Yamaha RX-V375
Check SP Wires Problem
There is a short in the receiver that will need to be repaired. Best to take it into a shop
May 12, 2014 | Yamaha HTR-5650 Receiver
Hi . I have XJR 1300 SP. I CANT GET IT TO START. it turns over ok
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to carburetor or throttle body pinched or kinked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and CDI box.
Spark plug cables in bad condition and shorting check for leakage in the dark, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty MAP, CKP, O2, TPS, sensors.
14. Faulty neutral, clutch lever, or kickstand safety switch.
15. Faulty fuel pump or fuse or relay.
16. Faulty CDI box.
17. A stuck bent or burnt valve.
18. Tip over sensor needs a reset.
19. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r6-forum.com/forums/57-garage-mechanical-help/162715-will-not-start-good-battery-no-clicking-but-no-turn-over.html
http://www.r6messagenet.com/forums/r6-maintenance-technical/26969-bike-turning-over-but-not-starting.html
Yamaha XJR1300 99 Service Manual
OEM parts for Yamaha
YAMAHA XJR1300 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 29, 2014 | 2000 Yamaha XJR 1300 SP
System shuts off
please advise on what to do when system turnes on and says check SP then shuts down
Jul 02, 2009 | Yamaha DVX-S200 System
Unit wont power up
Respected title!I would ask for their help.there is a yamaha dvr-s 120 home theatre my system.Switching on ,writes it ki,"check sp,and then turns off.what may be the problem?I say thank you for their help!with respect:Hornett
Jan 20, 2008 | Yamaha DVR-S120 DVD Player
Yamaha htr5730 receiver - turns off
You may have speaker wires touching each other or a short circuit in the wire. "Check SP Wires" means to check your speaker wires.
Oct 16, 2007 | Yamaha HTR-5730 Receiver
Check sp wires?
Your problem most likly is not because of dust. Its a bad connection in the amp section or the protection circuit, or the speakers them self have a problem. There could also be a componet problem. Unless you know how to troubleshoot solid state electronics,you should take the unit in to be serviced. It would most likly cost more then its worth to repair. A unit this old is u replaced at this point. Good Luck
Aug 05, 2006 | Yamaha HTR-5440 Receiver
49 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
