When i turn it up it says check sp connection what does this mean
It turns off after it says check sp connection
My SP console keeps turning itself of when I turn it on even when its been charged
If the system remains powered on when connected directly to an electrical outlet, then you are likely looking at a bad battery. If the problem persists even when the SP is plugged into an electrical outlet for charging, then you likely have some circuitry damage and may need to replace the entire SP.
Aug 24, 2011 | Nintendo Game Boy Advance SP Console
Hi, I droped my SP-320 yesterday and now i can't turn it on. The red and green light is flashing. What does the flashing lights means? Joe
I have the same problem with flashing red and green light when I tried to turn on my Olympus SP-350.
I don't know what's wrong, so please let me know if you have any clue. I personally did not drop the cam, but someone else might and did not tell me :(
May 25, 2011 | Olympus SP-350 Digital Camera
EPSON FX9000 ERROR 03
Aprendizaje hablar español
ERROR 3 - Carriage Return Horizontal Position Error
The SP motor brake signal did not switch ON within 3 secs after turning the printer ON.
La señal del freno del motor del SP no encendió en el plazo de 3 secs después de girar la impresora.
Check SP motor connection or call for service.
Compruebe la conexión o la llamada del motor del SP para saber si hay servicio.
Apr 27, 2011 | Epson DFX-9000 Matrix Printer
What is error code SC548 on RICOH Aficio 2035/2045 machine. Functional problem within the copier. How do i reset the copier to operate normal?
SC548 means the machine it not seeing the fuser unit. Open the Right side and front doors. Check the fuser unit to see if it is mounted properly.
There is some connection on the fuser module not making good contact. Reseat the fuser and power the machine off and on.
If you need to reset. Press Clear all, 107 and hold the pink button until you cee copy sp page displayed. Press copy sp, then while on that page turn the machine off and back on.
Jul 19, 2010 | Ricoh Aficio 2035 Copier
Hi I have Ricoh Alficio 2032 copier. There is error message C545. what does this mean and how can i solve the problem
Possible causes of your sc545
• Hot roller thermistor is out of position or most likley dirty
• Fusing lamp broken -- not likley
• Thermostat broken -- could be tripped check with a meter for 0 ohms
Once we are sure all fuser components are ok then reset the code by entering sp mode
execute sp 5810
if there is no 5810 then just turn off the machine while in sp modes
Apr 14, 2010 | Ricoh Office Equipment & Supplies
Dfx9000
The SP motor brake signal did not switch on within 3 seconds after turning the printer on.
Check, and if necessary replace, the following in the order below.
1. Check for disconnected SP motor-related connectors (ROM BOARD: CNSPHS, CNSPM)
2. Check the Interlock switch, and if necessary replace the switch assembly
3. Check both the SP motor and driver. (Always check both.) Check fora broken fuse on the SP motor 42 V line.
Replace the motor assembly and/or ROM BOARD as necessary.
Jul 08, 2008 | Epson DFX-9000 Matrix Printer
LED display on Janome Sewing Machine reads SP
SP means Spool Pin. It is currently in position to wind a bobbin. Move the bobbin winder pin to the left and SP should disappear.
May 12, 2008 | Janome 8080 Computerized Sewing Machine
VCR Help
SP means Standard Play. Generally that is the Normal speed at which a VCR Records or Plays back a tape. SP is automatic, as it is the Standard setting. If you wish to record more picture than the normal 120 mins on a tape, then you choose LP (Lond Play) oe EP (Extended Play).
Nov 20, 2007 | Sansui VHF6010 VHS VCR
Yamaha htr5730 receiver - turns off
You may have speaker wires touching each other or a short circuit in the wire. "Check SP Wires" means to check your speaker wires.
Oct 16, 2007 | Yamaha HTR-5730 Receiver
23 people viewed this question
k24674
jasbo
jasbo
