Question about Vacuums
Rubber drive belt is broken.where i buy a new one in australia?
Hose was badly tangled.pull the unit apart and found belt is broken
  • 3,955 Answers
Eureka maxima vacuum smokes and smells like rubber burning..whats wrong with it..the brush turns but seems like its blowing outwards too
when you get a burning rubber smell, the drive belt is usually slipping on the motor due to friction on the brushes. Remove the belt and free all the tangled hair to allow the brushes to rotate very easily and then put a new belt on.
Jun 03, 2015 | Eureka Vacuums
My rainbow se squeals and smells when running. How do you fix that?
Flip it over and look at the belt that drives the spinning brush. There is something tangled in it (if so, pull it out), or the belt it is about to fail. Google a vacuum repair store in your area to buy a new belt. It is usually a couple of screws, lift out the brush and slide the old belt off, new on and put it back together.
Or, or, let the guy at the vacuum cleaner store do it.
Aug 04, 2014 | Rainbow Vacuums
HV9010P ROLLER BRUSH DOESN'T MOVE
That is probably the belt. Open up the bottom screws and take a look. The cat or dog hair usually gets stuck in the ends of the rollers and stops the belt from effectively pushing the roller. You may find that the belt is still on the drive and the roller. If you do just clean out the roller.
Jan 22, 2013 | Black & Decker AV1200 DustBuster Handheld...
My vacuum cleaner brush stopped rotating. Just before it stopped, I smelled some burnt smell. Any idea?
Almost certainly you have broken the drive belt. THese machines have a rubber belt that is designed to snap if you get the roller brush stuck on something. The most common reason for this to occur is that you **** up the end of a rug, the curtain or a sock. This will stop the roller but the drive shaft will continue to spin which chews through the rubber belt.
What you will need to do is buy a new belt and fit it on.
Hope this is helpful for you. If it is please take a moment to give me a rating. If you are in Australia and need somewhere to get you miele belt from try nelsonvacuums or VacuumSpot.
Dec 22, 2010 | Miele S184 Powerhouse Bagged Upright...
Brush head not spinning
Belts broken, buy a new belt
Mar 21, 2010 | Dyson Vacuums
Dirt doesn't make it to cannister ...it used to have the spin around affect now it just sits there but some dirt is leaving floor....it is in the hose..I have cleaned ALL filters ...YUCK......help
You have a broken belt. Turn the vacuum over and remove cover plate. You will probably find a broken rubber belt. Buy a new belt for your vacuum. Remove the brush , install the new belt with the brush. Put cover plate back on. You are ready to go!
Jim
Jun 10, 2009 | Bissell 6594 PowerForce Bagless Upright...
Whill not dispense liquid
There is a panel on the side for belt access, open this and inspect your belt. Usually replacing the rubber belt will fix this problem, as the belt from the main motor is what drives the water pump unit. (The cogged belt in the front is what drives the brushroll, but if the rubber belt isn't functioning properly the brushes generally won't turn either.)
If the rubber belt seems ok and the brushes are turning either you have soap clogging the lines, or your pump has gone bad.
Flushing out the water lines can help clear a soap clog, but to effectively do it requires disassembly of the lower chassis. Both this procedure and pump replacements in these units are a nightmare because all of the rubber hoses running around in the machine have a tendency to get pinched closed on reassembly, so if you do disassemble your unit, be very careful to align all of the hoses so that they are not crimped upon reassembly.
-R
Aug 09, 2008 | Vacuums
Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell Lift Off Broken Belt and Brush Roller
I had the same problem. I found that the brush actually melted to the end cap (the one with the square/ovalish end). I was able to pull it off with some force and applied some WD-40, but that only worked for one more use. The brush has again melted to the end cap and it is too deformed to try and fix. I suppose I will have to search for a new brush, but this model obviously has some innate flaws.
Feb 14, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Broken transmission belt
Hi There, Is it the main drive belts from the motor to the tech drive? If it is the are very easy to replace by taking out the tech drive. If it's a belt inside the tech drive unit you will not be able to buy the belts anyway as they are classed from kirby as a sealed unit. Hope this helps Chris www.elidistribution.co.uk
Aug 26, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
