Question about The Computers & Internet
Why does window updates fail?
Window 7 desktop computer i have the window updates setting on automatically but when i check the history on the updates all fail on the date it suppose to be update what could be causing updates to fail?
  • The Master
  • 3,649 Answers
Could be a bad update prior to the failure.Suggest going to programs and features and selecting show updates . Then remove two last updates and then try to update it again
Posted on May 02, 2017
Updates was installed: 9/5/16 at 7:30pm on my window 7 computer but it fail why?
It is normal for the updates to fail on windows update. Just let it do its thing on its own. It will retry to install them and may fail again. This is normal now if it tries over and over to install the same update and it fails then you most likely have software that is conflicting with the install. Either way it will eventually either install the update or stop trying. As it will see that it is in fact a conflict and move on. Don't be alarmed by this just let it go.
Sep 09, 2016 | Computers & Internet
Tip
How to Check Computer's History After Someone Deletes It
If your computers history is delete by someone. But still if you want you can get the
computer's history back. Since the computer automatically backs up all the history even
after someone deletes it. You can simply get the computers history by searching the
index.dat file and you need to open it up with the help of an appropriate software
Follow the steps which i have mentioned below:
1. Go to the start menu and select Search.
2. In the search window click Tools on the menu bar which is at the top of the search window and then select "Folder options".
3. Now click the View Tab.
4. Select "Show hidden files and folders.
5. Uncheck the two checkboxes "Hide extensions for known file types" and "Hide protected operating system files which are checked by default.
6. Click the Apply button to apply these settings and the close the folder option window and return to the search window again.
7. Select "All Files and Folders" and in the Look in box select C: drive After this type "index.dat" into the search bar, and hit the "Search" button. You may get a number of index.dat file.
8. Try Downloading a ".dat" file reader to your computer if you don't already have one and then install it on your machine.
9. Use this Application for reading the deleted history of your computer
on Mar 18, 2010 | Computers & Internet
How do I eliminate automatic updates on Windows 7?
Go to windows update--- under start
The on the left side-- change setting
Oct 16, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Tata photon very slow
1)Please check range in your area that may be the problem
2)If range is ok then then you need to change some settings on your desktop
a)disable windows updates using instructions given at below link:
http://windows.microsoft.com/en-in/windows/turn-automatic-updating-on-off#turn-automatic-updating-on-off=windows-7
b)Use below registry tweaks to increase speed:
http://www.maketecheasier.com/3-ways-to-increase-network-speed-via-registry-editor-windows/2012/03/19
c)Use software internet downlaod manger which increase download speed 3x faster.
Regards,
Rahul
Jul 14, 2013 | Computers & Internet
Acer aspire one zge netbook wont update windows
Check the TIME and DATE settings, Set Correctly, then you will be able to Update...
Oct 14, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have a failed update in my update history list
I am sorry, there's was an unexpected connection failure which i didn't notice. If your problem isn't solved yet, please let me know. I am ready to assist you further. Good luck.
May 26, 2010 | Computers & Internet
None of the Microsoft suggestions correct error #0x80072F8F and allow me to get updates
search for updates manually. especially for installer 3.1 install it and restart your computer. Check Services and make sure windows automatic update service is set to automatic and started. Check time and Date and download the latest version of internet explorer from microsoft site. Install it and it will automatically update many root certificates for your windows. Set the security setting of internet explorer to default level and finally try to use update application of windows. It should work.
Sep 07, 2009 | HP Pavilion 510c PC Desktop
Dell pc giving blue screen -issue with recent Windows update?
Dear SherriJ:
Some time you might get this issues with the updates if they doesn't install properly or the computer turns off while instaiing updates.
However you can select last known good configuration of restore you computer to earlier time.
I would recommend you to keep the automatic updates on that will help you keep your computer in a good state.
Regards,
Mohammed
Jul 18, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
1,433 people viewed this question
Top The Computers & Internet Experts
JWMcCormick
JWMcCormick
Level 1 Expert
TEKUSER
TEKUSER
Sloop Johnb
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
