Question about Ovens
The hinges have broken off the pan cupboard door on our Spinflo caprice caravan cooker is it possible to get either a new door or the hinges to repair it
3 Suggested Answers
  • 4 Answers
SOURCE: Hotpoint BD 31 Cooker door
The doors are easy to remove if you know how.!
Where the hinge enters the door itself, there is a little catch which can be turned with a flat screwdriver.
By doing so you prevent the hinge from moving into the door.
Do this on both sides.
Then allow the door to move towards the closed position.
About 3/4 of the way to closing, grasp the door at each side, firmly, and move it from side to side gently.
The hinges will begin to dislodge from the oven frame.
The door will be free to remove and be worked on.
The sealant which holds the glass door to the hinges, needs to be a silicone that is heat resistent.
Silcoset 158 Silicone Adhesive Sealant in a 75ml tube has done the job for me - other brands are available online - but make sure they are heat resistent to 300C
Posted on Jul 25, 2008
SOURCE: I have a valor classic 2 si cooker and the door
I have same problem and psoke to valor (now Stoves ) and this item is now obsolete, unfortunately I have had to buy a new cooker.
Posted on Apr 05, 2010
This hinge has snapped in two Can it possible be welded back together again?
It depends on what material it is made from. The easy answer is yes most materials can be successfully welded but some materials are more problematic than others and need specialist equipment and skills.
If the material is mild steel you will have no trouble getting the welding done once the hinge has been removed from the door and the oven. I think that could be the major problem of the exercise.
A hinge wouldn't break for no reason. I think it would be wise to discover the reason before carrying out a repair. I suggest checking the price and availability of a new replacement hinge from the manufacturer before going ahead. The broken hinge might be a design flaw (whoever heard of a broken oven door hinge?) and a replacement might be a modified part that would resist breaking.
It is possible a new part could be cheaper than having it welded but you won't know until you check.
Apr 02, 2016 | Ovens
I have a Competence B 6139-4-m electric oven. the door does not close properly, have tried cleaning it as intruction manual suggests, the heat escaping from the oven has scorched my cupboards
the fault is unlikely to be the actual oven unit so therefore in order of least expense the things to check are:- the door seal being complete, the hinges not having been forced, the door not being buckled, self adhesive universal seals are available online from *spares etc. Hinges are easy to remove from the cooker and then can be unscrewed from the door and replaced. if it's the door I would have to say that's less likely to be available for a sensible price.
Feb 05, 2013 | AEG B1180-4 Electric Single Oven
I have a valor classic 2 si cooker and the door hinge has broken and also the plastic strip on top of the door where can I purchase a new hinge/plastic strip or door?
Mar 19, 2010 | Miele H378B2 KAT Electric Double Oven
Door came off the hinge
These Videos will help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at our website
1 how to remove your oven door for cleaning or repairs and how to reseat the door when finished.
2 How to change and fit oven door hinges.
We can not allways cover Every model but hope this helps. Remember to send us an email if you can’t find the part you need.
We also supply all the Parts you need for Repairing your cooker oven Door.
Oven Door Hinge Spare Parts
Oven Door Glass panels
Cooker Door Handels ETC
Cooker Door Catches ETC
Cooker & Oven Door Seal / Gaskets
Remember to Leave feed Back and pass our site on to your Friends:
Our Shop http://www.apart4u.co.uk
Our Video Help Section http://www.apart4u.co.uk/video-tutorials.html
Mar 04, 2010 | Whirlpool RBS305PDS Electric Single Oven
Locked oven door to clean. Need instructions to
These might help you get the door off
Mar 04, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Can I get replacement door for my top oven, and new door seals for Creda Cachet Solarplus Model 48182, serial 60.1.00082
we should be able to help if you contact the office
Mar 04, 2010 | Ovens
My oven door won't open and its not locked or on clean. what do i do
Mar 03, 2010 | Ovens
The hinge on our westinghouse silhouett oven door may be damaged as the door will not give a tight seal can it be repaired or replaced and how, the rest of the oven works like new.
If it is a drop down door, then the hinges are not repairable, the only solution is to replace both door hinges, and not just the broken one.
Hope this helps.
Jan 30, 2010 | Ovens
Belling oven door not closing fully
Hi. Yes, you will need to replace hinges, and possibly the hinge guides located inside the cookere.
Oct 17, 2008 | Belling XOU252 Electric Single Oven
Ovens Logo
26 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
