Question about Sharp Televison & Video
Blown fuse after cleaning the crt sharp tv circuit baord
4 Suggested Answers
SOURCE: Purchasing an internal circuit board part for a sharp LC 20S1E LCD TV
send me the model and serial number and i will be able to advise you
Lou Margo
Allied Electronics
loumargo@verizon.net
Posted on Dec 24, 2007
gopakumarg43
  • 74634 Answers
SOURCE: sharp 14" crt tv model598WJ
What is the problem with your Sharp TV? Provide more details please.
Posted on Sep 29, 2012
gopakumarg43
  • 74634 Answers
SOURCE: i have a crt tv sharp model:21v-fw150m blk.. is
Try to download the repair manual to this TV by internet. It has all details.
Posted on Oct 05, 2013
Resistor value of R704 of Sharp tv model 21v-fk200m
How do i unlock sharp crt tv model 21v-fk200m? i forgot the ...
www.fixya.com/.../t25439922-unlock_sharp_crt_tv_model_21v_fk200...
Feb 17, 2015 - Question about Sharp Standard (CRT) Televisions .... What is the valueof resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
Sharp value 2 watt resistor Standard (CRT) Televisions ...
www.fixya.com > ... > value 2 watt resistor > Standard (CRT) Televisions
value of r707 sharp model #27c241 R707 is 27 ohm 1/2 watt carbon resistor,if you ... What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit ..
Dec 28, 2015 | Sharp Televison & Video
Tv no raster no sound black only
Hi
Is the standby light (red) on? If not the fuse may be open or blown. If it is open circuit, try to replace it;; but if it is blackened something is wrong (short) in the power supply and associated circuits and need to be serviced.
Sully
Sep 28, 2013 | Sharp Televison & Video
I have an old flat-screen CRT Sharp TV. Model # 27U-F810 ; Serial # 204813681. It was working perfectly well yesterday. However, today I woke up to find out it doesn't turn on. I replaced the old batt
Look for a Power button on the TV and press that for a manual start. If the circuit breaker in your home for that outlet is not blown is not blown it would appear that the power supply seems to have died on the TV.
Mar 18, 2013 | Televison & Video
WONT TURN ON
Hello
Check the glass cartridge type, relpaceable fuse inside the Tv. This fuse can be located on the power regualtor section of the TV. Usually, it will come on the main board. If found blown up, never insert an other one, without point out the reason for the present fuse's blow up.
Mar 15, 2012 | Sharp 27L-X2000 27" TV
Bush tv picture colour red&purple
Check for any loose soldering points on the video output card [ a circuit baord located at the neck of the pircture tube]. Resolder all the suspected solder points. Green colour out put is absend now with your Tv.
Mar 14, 2012 | Bush Televison & Video
Curtis TV wont power on
Hello
Check the power supply regulator board inside. It has a fuse [ a glass cartridge type, replacable] on it. Check it for blown out. If found blown up, replace the fuse with same size and ratings. its ratings will be marked on it. If the newly inserted fuse blows off too, as soon as you switch the Set ON, never replace an other one in place, as it will damage more components.
make sure that the present power baord has some shorted component/s on it. It will be best to replace power regualtor boards as card basis, as components on it will be very hard to get from electonic spare part selling shops.
Mar 09, 2012 | Televison & Video
Tv will not turn on. Checked electrical and cable.
if you know that you have power and everything is ok otherwise than in the back of the tv there is a fuse. what it sounds like is that your fuse has blown. you will need to take the back of the tv off and look for the fuse and rep[lace it. please disconnect the power cord before attempting this....
Dec 12, 2009 | Sharp 32K-S400 32" TV
Sharp tv
Verify the diode bridge if it is not in the short circuit.and chemical capacitor, which is after the diode bridge and or demagnetiseur.
im sorry but my english is bad.
Dec 30, 2007 | Sharp 32F640 32" TV
25" Sharp tv
check fuses if the seconary fuse blown then posible bad fly back
Nov 01, 2007 | Philips 27PS60S 27" TV
Nothing works
The fact the set blows up the correct fuse is because it has a short ahead in the circuit,it could be one of the diodes(4) that is shorted,if one of these guys is bad all of them should be replaced with the exact replacement,ahead of them it should be a regulator and he is bad (shorted) it could have taken the diodes and the main fuse.The cause might have been a power surge.If you are familiar with tv service you can check the regulator and the diodes before you put in a new fuse,if you are not too familiar be safe and take the set for an estimate.If you suspect power surge or lighting damage it might not be worth repairing.Let Us know if you need more information.
Oct 26, 2006 | Sharp 25N-M100 25" TV
Televison & Video Logo
26 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
