Question about MAC Computers & Internet
How do I write on disks with my new usb floppy drive on a MAC
Geekman
  • 32281 Answers
SOURCE: Dell Internal / External USB Floppy Drive 1.44Mb
Any USB external Floppy drive will work with any computer with a USB port, but if you have Windows 98 you will need an USB driver.
Posted on Jul 29, 2009
  • 101 Answers
SOURCE: lacie usb floppy drive won't format a disc
on the floppy disk there should be a little switch push it across
now put in right click options format
Posted on Aug 29, 2009
bob_computer
  • 3153 Answers
SOURCE: mac won't recognize usb drive
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
For MAC users I am sorry but apart from the above steps that is all I can offer.
Posted on Sep 01, 2009
  • 69 Answers
SOURCE: download usb floppy disk driver on windows vista
have you try to download the driver from this link ?
http://www.bestdrv.com/samsung_sfd_321u_ep_driver_83033.htm
Posted on Sep 06, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Don't have floppy disk drive but I get floppy diskette se failure
Go to the control Panel > Device Manager > scroll to drives, right click on "A" drive and disable it. You can also go into the computers BIOS settings....usually the Delete key when you see the manufacturers splash screen on boot up. When you are in the BIOS, go to the computer peripherals and disable the A drive if it is listed. Hit F10 and reboot.
Posted on Sep 25, 2009
Testimonial: "It was right on you were right on target "
Can I use a Bytecc BT-144 usb external floppy disk drive with an iMac running OS 10.10.1?
I'm not a Mac tech, but I wouldn't see why not. Floppy drives are kinda old school now. You may need a driver for the floppy. Check online and see what you can find. Download and install it.
Or you may have to plug the floppy in, then reboot, to get the Mac to recognize it, especially with a USB port. Some old Windozz machines were like that...maybe your Mac too????
Mac OS is very close to Linux/Unix systems, which have awful support for floppy drives. That's another possibility.
If your windows machine can't read the disk, makes me think the floppy drive is bad or you have corrupted files on the disk. Try a couple known good floppy disks on the Windoz box and see what happens. Or another removable floppy drive. They cost $5 to $10 now.
Jan 22, 2015 | BYTECC (BT144) External Floppy Drive
I now have a iMac and would like to open my floppy disks on it. I have a usb floppy disk drive that i used to download them on my windows xp. Will it work on the iMac/
If it's usb go for it...I don't see why it wouldn't...however the programs that are on your floppys may not open right or may not open at all...depends on what programs you have on the mac...
Jun 27, 2012 | Mad Dog Multimedia Dominator (MDED1F)...
IBM Portable disk
Any "plug-and-play" device with a USB interface should be supported by Mac OS X. Try it!
Jan 27, 2012 | IBM USB Portable Diskette Drive (05K9276)...
Ibm portable disk with iMAC
You should be able to use it, just plug it in then open up disk utility which can be found in applications and then utilities. Once open you can format whatever way you require.
I am using a Mac Pro. My SmartDisk Titanium Edition Will not read a double sided floppy disk. It will read a regular floppy disk. What can i do?
Windows XP "natively" supports this "plug-and-play" USB device.
So, if it is "dead", search eBay for "external USB floppy" and buy a replacement.
Jul 18, 2011 | SmartDisk USB Floppy Drive Titanium...
Is my VST USB floppy disk drive repairable ? wont load disks !!
Unfortunately, we live in a disposable society, you can easily find a brand new mac compatible usb floppy drive for under $50.
It would certainly take several hours and spare parts to repair your drive... :(
Mar 30, 2009 | Apple Computers & Internet
1 want to install floppy drive to i mac
when u connect it leave it connected restart computer when it gets into windows it should find it auto
Feb 06, 2009 | SmartDisk (FDUSB-TM) External Floppy Drive
Need updated drives for my MAC OS 10.4 for floppy disk drive
Had a power failure now my model #SD-USB -M2 drive for macintosh will not work what do I need
Nov 24, 2008 | Imation (01946) External Floppy Drive
Nexxtech usb external floppy drive
The simple answer to your question is yes. The trick is getting the external floppy drive.
If you have one you should be able to connect it to you mac and simply drag the files on to your desktop. Depending what the files are you should then be able to still read them and save them on the mac in a new format.
It really depends on what format the files are and what app they where created in.
Floppy disks! I have not come across them for years! The process is quite slow!
Sep 30, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Computers & Internet Logo
55 people viewed this question
Top MAC Computers & Internet Experts
Iris Cheng
Ada Copper
Suresh Sharma
Suresh Sharma
Level 1 Expert
Are you a MAC Computer and Internet Expert? Answer questions, earn points and help others
