Question about Lands Phones
When I record, I can still hear old recording at the background
StuntJay20
  • 24 Answers
SOURCE: Black Screen
What is the camera model number?
Posted on Mar 19, 2008
  • 34 Answers
SOURCE: i hear background whitenoise/static
You need a better quality connection. Make sure that all of the wires run a straight path without unneeded or unnatural twists or ties. You also need to use the best cables for your situation. This means that you should use the right length and gauge recommended for your devices. If none of this works, you can always get an electronic loop-isolator (sweetwater, radioshack) which is essentially an enexpensive feedback eliminator and does the same thing as a grounded outlet, elimintating all of the extra "electric noise" which is not needed. Make sure that your devices are all plugged into grounded outlets as well. A surge protector with grounded slots will not always work, especially if it is not inserted into a three-prong outlet. Another thing is to make sure that no extra current is running through your devices. Because, in addition to the "noise" you are also damaging your equipment more from such "noise." In fact, depending on how long you have used your equipment, you may have already done some damage.
Posted on Mar 22, 2008
  • 9 Answers
SOURCE: I can hear static in my recording in quiet and
try moving any strong magnetic appliances away from your recording apperatus
Posted on Oct 16, 2009
  • 150 Answers
SOURCE: How can I clean up a recording that is full of noise & static?
I Don't know of any Olympus proprietory program to remove noise but if you can export it to a .wav format, it can then be edited and cleaned up digitally buy any semi pro sound editing software.such as sony's Sound Forge or cubase? cakewalk. software used for edit old records for conversion to cd may also help here. From there you can then save to cd for playback. If sound editing is beyond you, contact a recording studio or media house that produces commercials, they may be able to help.
Hope this is helpful
Posted on Jan 17, 2010
dunnbiker
  • 8546 Answers
SOURCE: ion profile pro -- recording picks up background sound
If you're picking up background (room) sounds the TT pickup is acting as a microphone. Isolate it physically from air- and room-borne vibrations. Turn your speakers down so they don't add to the problem, or use headphones while recording.
Posted on Feb 14, 2010
Testimonial: "Thanks! I also realized I have a built-in mic on my computer which I had to turn off."
Back ground noise
You cannot remove the background noise of already recorded material unless you have special software for that purpose. It is available, but costly. To eliminate some background noise, you may in the future, try to muffle the microphone by turning down the volume and recording by moving the device closer to the sound sources. Some folks put a wind sock over the recorder, as you may have noticed during TV News recordings on street events or at a studio. Try a wool or thick sock over the recorder and see if that helps.
Apr 15, 2014 | Olympus VN-711PC Digital Voice Recorder...
Background noise recording with dell
Get a wired lapel microphone and plug it into the microphone input on your Dell. The onboard mic is designed to record all ambient sounds. You want a different product to get the result you're looking for.
May 20, 2017 | Dell Audio Players & Recorders
I need a user manual for a Cable and Wireless CWT2100 answerphone, Thanks Anne
I have the same phone. To record a message, press Menu - press down arrow keys until you get to Record Outgoing Message - Press and hold down Menu again to Record. You record handsfree. I have a problem with the quality of the recorded message, it is very hard to hear it, there is a lot of background noise.
If you want to revert back to the pre-recorded message, do all of the above as far as recording the message but instead of actually recording a message, lift the handset and it reinstates the pre-recorded message.
To listen to the message you have recorded, Press Menu, click on down arrow keys as far as OGM and press Menu again to play the message.
Oct 29, 2011 | Lands Phones
Is there a volume control for the canon powershot sd 1200 IS microphone? The speaker is working perfectly. Old video recordings play back beautifully, but new recordings play back very softly. Playback...
As far as I know there is no way to adjust the microphone's sensitivity on this model. Make sure you are recording in a relatively quiet environment as these cameras' microphones tend to pick up everything and can generate a lot of background noise in your recordings. If you still feel like you need to shout into the mic to hear anything then you should look into getting your camera service by an authorized Canon service center. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
How do i set the answering system on a uniden 1580-3 phone, mine is just background noise on the answering machine when someone calls in to leave a message
Here is the manual for your phone. You can download the manual and the instructions for setting up your answering machine are on page 43:
http://www.uniden.com/pdf/DECT1580-3om.pdf
Setting Up the Answering System
You can set up your answering system's features from the handset. Only one handset at a time can access the answering system menus.
Note: If you have multiple bases, select the base with answering system you want to access (see page 15).
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
Jun 15, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
Jan 15, 2010 | Olympus VN-4100PC Digital Voice Recorder
When boss dictates a letter I can barely hear any sound!
The tape might be getting old, replace it and see what happens.  If it is still acting up, It might be he is not recording properly or the recorder is bad.  Try talking directly into the mic and see if it is better.  If it is, he needs to talk louder or needs to hold it close.
Mar 04, 2009 | Dictaphone 3225 Handheld Cassette Voice...
Won't rewind microcassette recorder
Although this unit may look new, it is over 10 years old. The problem is probably that the rubber belts and drive tire are bad. They can fail even if never used. I would suggest replacing with a newer model.
Dec 31, 2008 | Olympus DS-2300 Digital Voice Recorder
Quiet Noisey feedback out of speakers
The speakers are not hooked up correctly. I don't know if you still have the instructions but it is a hardware problem and not software. Try to figure out how to hook them up correctly.
Dec 27, 2008 | Dell Inspiron 1521 Laptop
Lands Phones Logo
32 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
