Question about HP Pavilion dv9000z Notebook
Problem with the NVIDIA video chip on System Board
I'm having the same problem with my dv9233. You should be able to boot into Windows Safe mode. Hold down the F8 button while booting, and select Windows Safe mode with networking.
Tom's Hardware published an article related to this issue:
http://www.tomshardware.com/news/HP-Having-Nvidia-Chipset-Issues,7669.html
Hope this helps,
Mike
    Scholar:
  • 107 Answers
Ok?
Posted on Aug 02, 2009
Why don't NVIDIA appear in safe mode?
I believe it's because when Windows is in Safe mode it only loads a very basic driver so that problems can be troubleshot without rogue video drivers causing problems. The correct driver should load when Windows is restarted normally.
Oct 19, 2017 | Computers & Internet
Acer Aspire 5520G and Nvidia 8400M G. I have tried to install newest drivers from Nvidia official page, but after restarting my windows 8 freezes at home screen.
Booting Into Safe Mode on Windows 8
The trick is to hold the Shift button and mash the F8 key, this will sometimes boot you into the new advanced "recovery mode", where you can choose to see advanced repair options.
You will need to click on the Troubleshoot option.
Now select Advanced Options.
Now choose the Windows Startup Settings option, by the looks of things we were never meant to find Safe Mode.
Finally hit the Restart button.
Like magic, when your PC reboots you will be able to boot into Safe Mode from the familiar looking Advanced Boot Options screen.
select safemode with networking
go to driver site NVIDIA DRIVERS GeForce 335 23 Driver WHQL
32 bit version
for the 64 bit
install in safe mode hope that works
Dec 28, 2013 | Acer Computers & Internet
My screen keeps flashing on and off wen instaled windows 7
Solution
1 Check to see if you nvida card is compatible with the version of windows 7 32 bit or 64 bit what ever is in stalled ( Make sure Operation system is genuine )
2 Download latest drivers from nvida if drivers are compatible ( That Nivda card is very old your trying to install and could be damaged witch would cause the screen to flash )
3 If problem Continues and you cant install drivers because u cant see the screen try booting up in safe mode by hitting f8 before window screen boots up start in safe mode with networking or if your motherboard has on board video boot up and install drivers that way
4 Still all that dont work take your broke *** to the store and buy a better video card
Ideal IT Support
for remote repair emaill me at idealitsupport@live.com
Feb 23, 2011 | Nvidia GeForce 6600 Graphic Card
I have nvidia geforce fx 5500 when i connect vga cable of monitor windows is booting but then monitor had a blak screen pl. giv eme a solution thanks in advance
boot in safe mode keep hitting f-8 key while booting when in safe mode delete all video drivers that are not used make sure your hard ware drivers are installed for board,should work after 1st try if not reboot in safe repeat steps,good luck!!
Jan 08, 2011 | Nvidia GeForce FX 5500 Video Card Graphic...
System shuts down
  • switch on system in safe mode by pressing F8
  • go to start menu >in system tools try to restore system to earlyar time
Jun 23, 2010 | PC Chips PCChips A15G Motherboard - v1.0,...
I have windows 7 Operating system installed on Intel Original D865GBF motherboard. The processor is 3.2GHZ. Ram is 2 GB dual channel (!GB x 2). I have added a graphic card PNY Ge Force NVidia 6200 AGP. The...
sounds like yo had the same Probles that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the montior cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is runing with your card you can also see that fron the about nvidia you must have the driver for the card installed to do all this.. hope I helped
Feb 27, 2010 | Nvidia GeForce 6200 AGP Graphic Card
White screen with vertical lines, can't do anything
Can you bootup in Safe Mode?
Press F8 when you bootup.
Then select LAST KNOWN GOOD CONFIGURATION. then check the Device Manager to see if the Video driver is OK and enabled. If OK then shut down and bootup again to see if it boots up normally.
If this doesn't work select SAFE MODE instead of Last Known ......
When Windows starts then select a Restore Point prior to the installation of the driver update and when it boots up again with luck it will be OK. The graphic card update maybe causing the problem.
Sep 22, 2009 | Fujitsu Siemens AMILO Xi 1546 Notebook
I have a Nvidia gforce 7100 that will not display thru s-video
boot in safe mode. safe mode will not use your settings. Once you have booted in safe mode then you can reset your video card.
Jun 06, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
Laptop Startup
hi dear
oh so sorry to hear that
this methode for windows Xp
and let try this
Microsoft Windows Vista users Tip: If you are running Safe Mode because you cannot get into Windows you may want to first try loading the last known good configuration. Additional information about this mode can be found on document CH000626
To get into the Windows Vista Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Directory Services Restore Mode
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcment
Start Windows Normally
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver.
ok
cropp
Mar 19, 2008 | Computers & Internet
Vertical lines problem
Did you formate before installation or used windows repair instllation tool? id you did use the reapir tool try to use full formate instead
Aug 05, 2007 | Microsoft Windows XP Professional With...
HP Pavilion dv9000z Notebook Logo
199 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
