Question about Samsung Cell Phones
What happens if I reset my phone to factory settings im wanting to clean it out if thats possible I have a samsung luna
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 127 Answers
Factory reset will erase all your personal data.
You can do this from Settings - Backup & Reset - Factory data reset - Erase everything.
SUBSCRIBE to my channel - ZFix
Posted on May 02, 2017
trendsetter
  • 43 Answers
SOURCE: Unlock Phone SAmsung SGH-U700
hi amielle,
     if ur have forgotten ur phone lock code, it won work with any sim u insert...u can't go inside d phone, unless d lock is removed, which is possible if u know d code....so take it to an authorised samsung service centre and tel ur problem....they ll remove d lock and restore it to factory settings...because oly they have d software to unlock ur phone....if ur mobile is within warranty period, this would be done at free of cost....
        best wishes,
        trendsetter
Posted on Jul 03, 2008
fasacosta
  • 21 Answers
SOURCE: Reset phone to factory
*BEFORE COMPLETING A HARD RESET, BACKUP ANYTHING YOU HAVE STORED ON THE HANDSET, THIS INCLUDES CONTACTS*
1. Select MENU
2. Select Settings
3. Select RESET SETTINGS
4. Select ALL
5. Press OK
6. Press Reset
7. Enter Password (default 00000000)
this was taken from mobilereviews.o2.co.uk
display_flip('id3190', 'divId3190');
Posted on May 02, 2009
SOURCE: Forgot Lock Code - Samsung m500 Cell Phone
try to use last 4 digit of your phone number . go into the menu then setting then security then enter four digets and you can find these 4 degits into in setting then phone info enjoyyyyyyyyyyyyyy
Posted on Jun 05, 2009
  • 4 Answers
SOURCE: want to factory reset an unlocked htc touch cdma (vogue)
All you have to do is... hold down the (RED) End button and the (GREEN) Send button at the same time, and while still holding them down POKE your stylus in the soft reset hole at the bottom of phone.
Soft Reset button is located to the right of the mini USB charging port, assuming the phone's screen is facing you.
Confirm you want to Format and Done!
P.S. Sometimes if you don't hold the Green and Red buttons hard enough they tend to unclick and reclick if you don't apply Firm and even pressure. Also if you still have trouble make sure the phone is in the BOOTING cycle when you attempt this.
Posted on Feb 03, 2010
  • 239 Answers
SOURCE: reset s3310 to factory default settings
*2767*3855# is the master reset code and "if" it asks for password type *#9072641*# ..
if it works or not works mail me at ssgodfather@gmail.com..
therefore i can work with more..
i hope,it solves your problem..
"rate solution"
Posted on Apr 17, 2010
Factory reset for galaxy tab
Method 1: From Startup (Tab 4)
  1. With the device off, press and hold the "Volume Up", "Home", and "Power" buttons.
  2. Release the buttons when you see the recovery screen and the Samsung logo.
  3. Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...
  4. On the next screen, press "Volume Up" to continue.
Jul 15, 2016 | Samsung Galaxy Tab Tablet PC
I forgot the security code of nokia 8600 how to reset
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 04, 2012 | Nokia 8600 Luna Cellular Phone
Is it possible to restore my phone to its original state? having problems uninstalling programs that want net all the time. Only want to us WiFi
Yes, it is possible to reset your phone to factory setting. The codes are different for different brands. For your Samsung the reset code is *2767*2878#. After you typed the code your phone will re-start and its all back to the original factory settings! See you around. Take care.
Dec 02, 2011 | Samsung Cell Phones
How to reset samsung star to default factory
pls help me how to restore samsung mobile phone s5233w factory setting code
May 04, 2010 | Samsung Star GT-S5233 Cell Phone
Samsung jet no sim mode ??
there is a possibility that it can be, but check first your phone profiles through settings, phone profiles, check the profile modes, if offline mode is check, select another profile mode from your phone, normal, outdoor, meeting, up to you. but after you made this and the phone has the same issue, then do the following, turn off your phone, remove your sim, clean the sim's contact's surface with pencil eraser and wipe it out by soft cloth, clean those six contact's on your phone, but be very careful cause one bent of contact's what you'll get is a damaged phone,.
once finished, insert again your sim and check. if nothing happened, then do a factory reset, remove your sim, switch on your phone, and type this code to your keypad *2767*3855#..
good luck
Feb 24, 2010 | Cell Phones
Need to reset phone
To reset the handset follow the steps below:
  1. While in standby mode, press the Menu / OK buttonmenu-ok.giffor Menu
  2. Select Settings (9)
  3. Select Phone Settings (5)
  4. Select Security (3)
  5. Enter the lock code, default password is the last 4 digits of cell phone number, unless it has been changed
  6. Select Reset Phone (4)
  7. Press the left soft key for Yes to confirm resetting the handset to factory default settings
Note: All settings (except Contacts) are reset to factory default settings
Jul 19, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Mobile phone Samsung D900 discharges battery in approx 4 hours - only started happening recently (may be to do with bluetooth?). Have bought new battery and charger (as advised by contract supplier) but...
Hi Joe - http://horizonwirelessonline.com has the answer!
They can reflash the phone with newest firmware and restore to factory original settings for you.
If you want they can reset all the GPRS ans WAP info too.
You need to send them the phone, but it's worth it.
Jan 16, 2008 | Cell Phones
Cell Phones Logo
62 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
