Question about Bosch Saws
Bosch 4100 table saw miter adjustment red lever won't budge to adjust formatted rips.
How do I get red miter adjustment lever to release without breaking it on the Bosch 4100 table saw?
  • 37 Answers
SOURCE: The delta universal miter saw stand will not adjust to level posi
Hi, The legs on the stand should have leveling pads on it. at the bottom of each stand legs, there is a hole which the pad goes in. you can adjust the pad by unloosening the top nut. put a level on the saw base and adjust the pad up or down to level your stand.
If this doesn’t work for you, please write back. Thanks,
Posted on Nov 28, 2008
efs_perpends
  • 1996 Answers
SOURCE: bevel locking lever won't tighten
It looks like that handle should be able to pull straight off the end of the shaft once you remove the screw. See this exploded parts view: http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_2703.pdf
My experience with them is that people tend to get frustrated and abandon the lock lever and just run the saw "loose". Scary as it sounds, I've seen it on more than one site.
Anyway, I don't have a fix for you if you can't get the handle off to re-position it.
Makita does have a tech support line if you want to give it a try. Otherwise, you may have to shell out a few bucks to one of their service centers. We used to have a great one in Albuquerque, but it's now defunct. People don't seem to repair tools like they used to...
Locate Nearest Service Center online
or Free technical support center (1-800-4MAKITA)
Monday – Friday 7:00am – 7:00pm EST
Good luck, and best wishes...
Posted on Mar 28, 2009
rowdy45176
  • 2176 Answers
SOURCE: Table and base not level (co-planar). Extension wings higfher than base as well.
Just read thru most of the user manual and they do not address this situation. Most major adjustments they list as Service Center meaning they might have to completely disassemble and find out hy this saw is not accurate, wish I had better news.
Posted on May 25, 2009
jyackle5
  • 8197 Answers
SOURCE: need manual for bosch 4000 table saw
You can get manual at link below.
owners manual.
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00160v-1.pdf
Parts diagram.
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00442v-1.pdf
Good Luck
Posted on Sep 29, 2009
rowdy45176
  • 2176 Answers
SOURCE: Laser guide on Bosch 4410L miter saw is off.Can it
I looked thru their onwers manual and the parts breakdown and find no reference to adjusting the laser. I would recommend calling them direct at 1-877-267-2499 for assistance. I wish I have better information but this is all I can find. Good Luck
Posted on Nov 15, 2009
Clamp Lever - How to loosen and tighten to adjust bevel.
The 8mm bolt head, which is below the "stop plate"--- for olack of a better word-- is only to ALLOW ROOM to complete the swivel of the bevel-- ONCE THE CLAMP LEVER IS LOOSENED!! I neither have been able to loosen the CLAMP LEVER!! There is a large philips screwhead inside the handle of the lever, which I tried to loosen without much luck. I am very afraid to force that... ALSO, i tapped on the lever handle itself to see if it would unstick, but with no luck AND DIDNT WANT TO FORCE THAT EITHER!! So here I am online looking for answers again!!
Apr 15, 2014 | Hitachi C10FCE2 10" Compound Miter Saw
Bosch Glide Miter Saw get stuck at 45 degree bevel to the left
Adjusting the miter angle involves two cast surfaces sliding against each other. If those surfaces have some irregularities, high spots on the two surfaces will bind against each other. You may have to disassemble the rotating table from the base and do some filing or grinding.
Dec 29, 2013 | Makita Tools 12" Compound Miter Saw -...
Makita L1011 compound sliding saw with sticky miter table
The LS1011 doesn't have a table angle release lever like the newer models so it's harder too swing the table from angle to angle, this also causes the plastic swing body to crack. Have you loosened the locking screw for the table? The table may have to be removed and the pivet shaft greased. I had this problem with an old Makita Table Saw 10" 2600.
Feb 01, 2013 | Saws
Brand new bosch 4100 jobsite table saw
there are no adjustments on the movement you described. If this is a new saw as indicated I would return for warranty repair/replacement.
Feb 09, 2012 | Bosch Saws
My 10" Bosch miter saw
I would remove the blade and try the saw again, there is a possibility that you might have gotten a flange on incorrectly or left the spacer out.
Sep 10, 2011 | Bosch 10" Slide Miter Saw
Electric blade brake sounds like it is seized up. Upon starting table saw (bosch 4000), motor sounds like it is binding. How can I disengage the brake??
There is no electric brake on the Bosch 4100 table saw. If the motor sounds like it is being held back its possible the rear armature bearing has seized or the field coil is faulty. Both these problems cause the motr to not turn at full speed. The motor must be serviced.
Dec 08, 2010 | Bosch 4100 10" Worksite Table Saw
May 10, 2009 | Bosch 12" Dual - Bevel Compound Miter Saw...
I purchased the Bosch saw blade on Ebay
If the arbors the same and you're running with in the RPM rating, it will be fine. But ALWAYS wear your safety glasses.
Mar 15, 2009 | Bosch PRO1072SM 10 Inch 72T Miter Saw...
How do you adjust the angle of the miter
It should move if you unscrew the handle at the base of teh table. There is also a lever on most of these saws, under the handle. Unscrew handle, operate lever to release locking pin and move. That's the theory anyway.
Oct 24, 2008 | Makita 10" Miter Saw LS1030N
Saws Logo
97 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
