Question about The Computers & Internet
Sound is distorted what could the reason - The Computers & Internet
  • The Master
  • 2,045 Answers
Where and how, please more details
Posted on May 02, 2017
Reason and fix for distorted sound?
Your amplifier circuit is in serious need of repair. If both amps are responding the same, then the likelihood of two separate amps going bad at same time is remote. Look at something they both share in common such as the power supply. If you do not feed the amp the correct "juice" it is not going to do squat!
Apr 06, 2015 | Mackie SRM-450 System
Do I need a amp for Fusion MS-BX402 speakers
the reason for running an amp is becauze ur running your volume so loud you are getting distortion. Btw, its the distortion that damages speakers. If your happy with the sound then you dont need an amp. If your running your radio "full tilt" to get your sound, think about adding some power.
Dec 01, 2014 | Fusion Car Audio & Video
CS-2724R speakers starting to sound distorted. Can speakers be replaced @ home or must be done by qualified tech? Will replacing speakers likely fix problem or could the diminishing audio quality be a...
Replacing speakers are not a skilled work, can be done at homw. But, reason for distortion should be troubeshooted before replacing the speakers, and make sure that the distrotion is due to damaged speakers itself. Otherwise it will be a waste of money. It will be best to contact any service technician.
Aug 25, 2013 | Mitsubishi CS-13103 TV
What is a compatible turntable for my Sherwood rx-4109 receiver?
many decks have pre amps or need preamps. hence the reason why you have distorted sound i would guess. you need the opposite of what you used. What record deck did you try?
Jan 06, 2013 | Sherwood New-RX-4109 STEREO RECEIVER WITH...
Bose L1 Speaker Distorting
See this article on the inputs on the Bose L1®.
L1 Model Bose L1 Encyclopedia FAQ Wiki
Set the trim levels so that lights are solid green with occasional flickers of red.
Mar 15, 2012 | Bose L1 Speaker
At start up, distorted / dble vision fuzzy. Screen will go black with sound. Turn off & on to get very poor distorted picture. After 15 - 20 minutes clears up.
The reason your television is having distorted vision and screen going black with sound is because there is a problem inside the unit. This problem could be caused by either a bad lamp or a faulty t-com board.
My best bet is the lamp, because it is when the lamp start developing any fault it begins the distorted screen thing and coming up black.
What you hsve to do is to get a replacement lamp, open up the television and replace the lamp with a new one, after doing that your television will be in good condition once again.
Take care and good luck
Oct 27, 2010 | Sony BRAVIA KDL-46V3000 Television
Crackly sound when recording vhs tape to disc
try new cables going from the vcr to the video capture (yellow red white)
Dec 01, 2009 | Pinnacle Dazzle DVC-100 DVD Recorder
My subwoofer sound is distorted
whatever player are you using must be having Equalizer in it...try adjusting that [keep that down to a minimum]. Check the program for your audio device...some programs have sound options like jazz,rock,pop these are predefined equalizer changing these could also help. Try using a different media player like VLC [it's free to download on the web] Try uninstalling the audio driver and then reinstalling the driver. It is quite possible that your speaker doesn't match with the Laptop's amplifier or the speaker is gone kaput [a coil problem or something needs repair...but do not repair rather buy a good speaker coz repairing loses the quality].
Aug 04, 2009 | Computers & Internet
I want to know about the car speaker for ford focus 2004 model 1.4lx
O.K hear is the deal on most factory car Speakers their not very high wattage they don't need to be, see Distortion level has as much to do with Sound Quility as Power you don't need a lot of Power if the unit is crystal clear this is usely done thru Low Wattage because of Voltage humm and grounding issues most of your Factory Units have great to Exceptional Ground and very low levels of distortion 0.2 % or Lower that is the reason they sound so Great there crystal clear they won't blow Your Windows out but you can hear every little chim or Musical Note that the system can put out.power is Impressive as far as looks but not nessasary as far as great Sound untill you get to your very high end cars that have custom installed systems most are Low Voltage Low Distortion Units and Speakers
Jul 25, 2009 | Car Audio & Video
Webcam audio problem
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone and have a built-in mike, between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Mar 23, 2009 | Microsoft Lifecam 6000 Webcam
Computers & Internet Logo
69 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
