Question about Sewing Machines
I need a lower looper part for my delta overlocker 1000
SOURCE: lower looper threader
check to make sure it is not wraping around the upper looper. just stitch without the material and you will see it. but then you must rethread the upper looper and the lower looper again in the right order. hope this helps
Posted on Jun 25, 2008
SOURCE: thread continually breaking in lower looper needle
I was having this very same problem with my lower looper . I had been using the one needle stitching all afternoon and I was doing quite nice stitching. then I decided to put the right needle back in and do some overlock stitching and guess what I spent the next two hours fighting the looper problem. I had completely re-thread this machine at least 20 times now. I decided to take the needle out and re-insert it and re-thread it one more time (right lower looper- then upper looper- right needle- then left needle) was careful to pull all threads to the back and under the presser foot for about 6 inches.
Held on to the thread, lowered presser foot and did the chaining stitch. BINGO it didn't break, tried it with a piece of cloth and Perfect stitches. I have a Babylock BL402 and used tension settings left to right
4-3-3-3 and default settings for the rest.
Hope this helps someone someday.
Jo Griffith
Posted on Mar 29, 2009
WonderTech
  • 268 Answers
SOURCE: When i use my janome overlocker the needle is
Here are a few things to try.
* When you insert anew needle, make sure it’s positioned correctly. Usually with the flat side
away from the bobbin, but consult your manual. Make sure that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot
Make sure it’s attached securely.
* Change your pressure foot
Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins
A needle that hits a pin can break. Always remove the pins from your fabric before they reach
your needle.
* Don’t pull your fabric as you sew
You could be bending your needle back, causing it to hit your needle plate instead of going into
the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate
Make sure it's securely in position.
* Change your needle plate
If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for
sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle
Sewing machines with zigzag capability allow you to adjust the position of your needle – right,
left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or
pressure foot.
I hope one of these solutions help you.
Posted on Sep 15, 2009
  • 1116 Answers
SOURCE: I have a 3/4 thread 234 model Bernette overlocker,
Newcastle where?
In the US, a sewing machine repair service can do the work - a Bernina tech would be better.
Service starts at about $100 plus any parts that have to be replaced.
If you go to the Bernina website, there should be a dealer locator option.
Posted on Mar 20, 2010
SOURCE: How do I thread my Delta OL-1000 overlocker
on the website---diplodocs.com---there is a operation manual--pdf file to download FREE
on the first page go to the alphebet letters & find the D & click on it,, it will take you to the next page & in the orange box find the word delta & it will take you to the next page,,go down to the lower part of the page to a box that says TOP USER GUIDES & CLICK ON--ol 1000 & it will take you to the download icon on the left hand side in box that says USER MANUAL DELTA OL-1000..
please rate this
Posted on Aug 09, 2010
Bernina 335 serger won't sew/overlock. carefully rethreaded the serger but that hasn't helped.
The 335 has a two thread chain stitch (stitch type 401), and the overlock side (right needle side), is a three thread plain overlock. If you are describing the plain overlock as the problem, I would first suggest the following in re-threading:
1. Thread the upper looper
2. Thread the lower looper
3. Thread the needle last (important)
If the needle threaded, you cannot re-thread the lower looper without breaking the thread.
In order to thread the lower looper, the lower looper must pass by the needle thus picking up the needle thread. So, instead of threading the lower looper thread underneath the needle thread, the looper would be threaded on top and cannot sew without breaking the thread.
Make sure that the threads are bedded between the tension disks. Check this by stretching the thread fore and aft of the tension disks as well as visually noting that the threads are not accidentally threaded behind the disks. You can also loosen the tension disks when threading so as to allow the threads to bed deeply between the disks.
Please reply with your observations.
Sep 27, 2015 | Bernina Sewing Machines
I A NEED PARTS NUMBER FOR SINGER OVERLOCKER 14U134A LOWER LOOPER
See if you can call Singer customer service to get a parts list. They might even look it up for you and help you get it.
Sep 13, 2014 | Sewing Machines
Delta ol 1000 overlocker sewingmachine
check with a1sewingmachines.com or sewvacdoctor.com and call them or email them about the parts you need
or check ebay
Sep 25, 2013 | Elna Sewing Machines
Correct threading for 4 th. Juki ind. overlocker
Overlockers and or Sergers are ALWAYS threaded the same way. Upper looper, Lower looper, right needle, left needle. If you have a model number for your Juki we might be able to find you more information.
The best way to figure out tension problems is to thread each thread in a different color so you can determine which thread is giving you problems.
These machines can be frustrating and EVERY time the thread breaks you MUST start the threading problem from the beginning... upper looper, lower looper, right needle left needle.
Aug 31, 2012 | Sewing Machines
How do I oil my Janome 664d overlocker
Does your overlocker have a threading diagram on the inside of the front cover? Often this will also show a couple of red dots where you need to oil.
Obviously always best to consult the manual if you have it; I haven't been able to find an image of the threading or oiling diagram for your machine.
If it doesnt have this diagram and you don't have a manual then I would hazard a guess and say that you need to oil the loopers where they move through another metal part. So open up the front and have a look at the lower looper mechanisim, manually turn the flywheel to move the looper and you should be able to see what I mean. The lower looper will move back and forwards through a metal socket piece and the looper bar may look lubricated on each side. So give the metal holding bit a drop and the oil should work into it. There may be a similar looking bit for the top looper, have a look and give it a drop of oil.
Some overlockers will have an oiling point at the back of the sewing table, it may be a little hole marked with red paint.
Sep 06, 2011 | Janome MyLock 644D
I have a bernina overlocker and whenever I use it the lower looper (marked in red) thread breaks. How can I fix this? It was serviced yesterday and when other people used it before me it worked fine!
Then it's one of two things. First try setting your lower looper tension on 3 and see if that works. If not set it back on 4 and cut ALL your threads and re-thread the machine STARTING with the UPPER looper, then the lower looper, then the right needle, last the left needle if you're sewing a 4 thread overlock stitch. Make sure the threads aren't twisted in the thread guide. Make sure the lower looper thread is OVER the elbow on the upper looper and over the upper looper thread. Let me know if this works. We'll work until we get it fixed!
Sep 14, 2010 | Sewing Machines
please rate this
Aug 08, 2010 | Sewing Machines
Lower looper threader
Apr 14, 2008 | Brother 929D Mechanical Sewing Machine
Sewing Machines Logo
52 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
