Question about The Video Game Consoles & Games
I have a Fleetwood Deluxe, 2345TW and it needs needle stop. The last time I used it A needle broke and I couldn't get another one installed where the machine would work again.
Previously installation was a guessing game.
  • 4 Answers
SOURCE: Pfaff Creative 1371
Did the machine get dropped, or otherwise roughly handled? Or have a rough, bumpy ride back home, etc? That could explain why it's not working correctly.
Posted on Aug 06, 2007
  • 164 Answers
SOURCE: game freeze
Vista is the issue.
Very few games run well on Vista.
Have you defragmented your computer this month?
How much free space remains on your Hard Drive? It needs to be above 15%.
Go to your control panel, then display and see what video card is showing.I
If it is an nVidia card, go to their web page and update the drivers.
Then go to DirectX at Microsoft and get the 9.0C or above update.
Posted on Feb 19, 2009
  • 240 Answers
SOURCE: breaks needle
Yes they can indeed go out of time and breaking needles is the most likely cause. To solve timing problems you will need a sewing machine engineer though. The part which needs adjusting would be the area above the needle-the needlebar but it is a fiddly affair only to be attembed by someone who can repair sewing machines. It is also a fairly expensive repair as it is very time consuming. However-don't assume it is that. Firstly make sure the new needle is in correctly-the most common cause of problems is needles in wrong direction! If bobbin opens at front then the flat part of the needle faces the back. If bobbin area opens at side then the flat side of needle faces the body of the machine to the right. Check needleplate for damage so that new needle does not catch. File it smooth if you need to! Check you are using a good quality thread as cheap thread causes no end of problems. Guuterman is the best I found.
Posted on Jun 11, 2009
  • 3153 Answers
SOURCE: need sims2 double deluxe code for installation?
We are not allowed to provide that information
It should however be on the packaging.
If not you should contact the supplier
Posted on Aug 31, 2009
SOURCE: thread keeps breaking on sewing machine
Probably just the needle. Try turning it 180 degrees
Posted on Sep 23, 2009
I have a CG 500. First time sewing in 30 yrs. Making a baby quilt, got through most of until the needle broke. I replaced the needle with the suggested type, now it stitch.
You don't specify exactly what is happening when you try to stitch.
Remove all the threads from the machine, RAISE the presser foot and rethread from the beginning (verify the thread path is correct and the bobbin is loaded and thread correctly). If the threads are not connecting, it could be the incorrect needle. However, given that the last needle broke, the machine may have been knocked out of time (happens frequently with broken needles). You can search for sewing machine timing or take it for service.
Feb 09, 2017 | Sewing Machines
I've got a Fleetwood deluxe zig zag sewing machine and it's trying to sew but pulls thread out of needle
Be sure to pull plenty of tail through the needle eye before beginning to stitch. It also helps to raise the take-up lever all the way to the top BEFORE taking the first stitch. In addition, pull the bobbin thread to the top of the fabric and then grasp both thread tails gently with your left hand while taking the first couple of stitches.
How and Why to Bring up the Bobbin Thread
Jan 14, 2017 | Sewing Machines
I was sewing with my CG590 singer machine and then my needle broke. So I put in a new needle, and now it seems like it is hitting something when it goes down. What could this be and how do I fix it?
If the needle hit something (which is usually what happens when the needle breaks), it could very well have knocked the machine out of time. You can try installing another needle (make sure it is installed facing the correct direction) and see if that changes things. If it continues to hit something, you can search the internet for web sites and videos discussing "sewing machine timing" or take it for service.
Nov 12, 2016 | Singer CG590 Mechanical Sewing Machine
My machine stopped working!
it's possible that the machine will need a adjustment or the timing
checked at a repair shop
Dec 06, 2012 | Sewing Machines
I have a Singer 327K that stitches three or four good stitches and then stops completely stitching
it's very possible that when the needle broke the machine went out of time & would have to be retimed at a sewing machine shop
Mar 10, 2012 | Singer Sewing Machines
What is the need size, I broke my needle
the needle series is 130/705H the size depends on the fabric as a rule of thumb 80/12 for cotton 70/10 for silk 100/16 denim needles for heavy woven etc also the needles are available in stretch, leather, sharps (for micro fibre) etc.
Apr 24, 2011 | Euro-Pro Deluxe 7130 Mechanical Sewing...
Tl98e broke a needle and now won't stop looping.
needle plate may be sanded lightly for nicks and scratches. Timing is probably off, need to see an expert repair service in your area.
May 30, 2010 | Feiyue FS288
Heater fan on a 1988 cadillac fleetwood deluxe
passenger side under the dash... tho there is a chance it's mounted on the passenger side inside the engine compartment
Jan 23, 2009 | 1988 Cadillac Fleetwood
Microsoft visual c ++ runtime error PEX.exe
My problem was I had to many pictures in my C/ pictures folder. It couldn,t load before it timed out. I moved those pictures to my C/photo folder, worked great! no more problem. I have win xp home ed sp 2. The Lord Jesus help me after month of prayer and not finding any solution on the web, Last night the answer just popped in my head, I'm not smart on pc, so I know I had help.Thank Jesus if this helps you. I did!
Sep 15, 2008 | Nova Development Photo Explosion Deluxe...
Video Game Consoles & Games Logo
Top The Video Game Consoles & Games Experts
Mary-Ann Silva
Mary-Ann Silva
Are you a The Video Game Console and Game Expert? Answer questions, earn points and help others
