Question about Philips 50PFP5332D 50 in. Plasma Television
MY Philips Plasma 50PFP532D must have overscan on and I need to get to the service menu to disable. The edges of my HD content from my PC are lost when hooked up. Thanks
  • Anonymous Mar 14, 2014
    my philips plasma 50pfp532d is not staying tuned to chanels overnight. i have to set up scan everyday, help
How do I enter the service menu on an Emerson EWF2004 CRT Television? (Pictures of the OVERSCAN ISSUE will be provided if needed.)
Older sets had vertical and horizontal size controls. If you have the horizontal size control, turning it counterclockwise will reduce the size of the picture horizontally and reduce the overscan.
Feb 25, 2016 | Emerson EWF2004 20" TV
Apex TV Service Mode
The service menu for this TV may be accessed by holding down the INPUT button on the TV and pressing 2580 on the remote. To navigate the service menu use the arrow keys on the remote. The center Enter button is used to go down into a submenu. The Menu button returns from a submenu. The exit key exits the menu.
There is an option to adjust Over Scan in the Picture settings menu. Set the positions to zero and the size to +100 for both horizontal and vertical. Then set the Sharpness to zero in the Picture Mode menu for each picture mode (optional, but sharpness makes text and sharp lines really ugly if you're using a PC).
I've owned this TV since Feb. 2013 and I've been disgusted with its lack of disable-able overscan and forced to use VGA to get a usable picture. The VGA port finally started going out (flickering colors) and rather than tearing it apart to resolder the VGA connector I tried to find a service manual again. Found one for a different Apex LCD TV but the service code was the same. It's like having a brand new, much better TV now! Overscan is the worst thing the TV industry ever did, it's totally and completely unnecessary on digital, pixel-perfect signals.
Aug 06, 2014 | Apex'i LE4643T 46 inch Glossy Black 1080P...
Philips plasma service manual
Look for service manuals and schematic diagrams for Philips Plasma for troubleshooting and maintenance here
http://myfixbase.com/service_manuals/philips/plasma.html
Sep 07, 2012 | Philips 50PF9731D 50" Plasma HDTV w/ Pixel...
50 in philips hd plasma with ambilight model number 50PF9631D/37
The x-sus and y-sus panels have some fuses,check to find out wich panel is broken and replace.
Sep 04, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Panasonic viera doesn't display computer correctly
I have had what is fundamentally the same problem. I have a desktop PC that I am plugging in to my Panasonic Viera TX-32LZD80. I am using DVI connection plugged in to HDMI port.
The solution is fairly simple; use the Menu button on the TV remote to get to the Main Menu for the TV and then select Setup which should be the fourth of four options. This will get you to the Setup Menu for the TV for the current channel. Look for the Picture Overscan option, it will very probably be set to On if you have the problem of %5 or so of display being missing on all sides.
Switch Picture Overscan to Off.
This immediately should solve your problem. A note of warning on this is that I suspected this was the problem but when I first looked at the Setup Menu I could not find the Picture Overscan option.
If you are unable to find the Picture Overscan option then trying fiddling with the Aspect settings. You will probably find it set to Auto. Switch it to 16:9 and you should find the Picture Overscan option will be available from the Setup Menu.
Hope it works for you.
Mar 03, 2009 | Televison & Video
Display to big with PS3
All CRT RPTVs have overscan, and some sources bring this out more than others.
It can always be cured to at least be able to see the needed parts of the pic, but hoses your picture beyond belief, and correcting that takes time, experience, patience and expertise.
I do overscan reduction on all CRT RPTVs as part of what my calibrations offer, but charge extra to do so.
Mr Bob
Feb 02, 2008 | Philips 60PP9352 60" Rear Projection...
Vertical black bar on plasma screen
This is usually caused by a screen addressing fault. The location of the fault can be on the main screen driver board, or in the area for the screen address processing. It can also be matrix fault with the drive to the screen.
You will have to give the set out for an estimate. From this you can make the decision if the set is worth to service or not.
Jerry G.
Jan 22, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Overscan is off a bit
Does's the set have a repair history? If it was previously serviced , the capacitor which is connected between the emitter and the collector of the horizontal output transistor transistor might have been changed with the wrong value, which would cause and overscan situation.The service menu for this set is even hard for technicians to use. It' my opinion if the service manual will not correct the horizontal width, the wrong capacitor was probably installed. Scrivitron (also these sets are known for the forementioned capacitor to short , flame or open.
Jul 09, 2007 | Philips Magnavox 27MS343S 27" TV
Philips 55pw9363 factory default settings
Yes,there is almost always a way! you will need the CD ROM literature for your model--it will list the normal range of settings. My reserved question is what caused the overscan and why did you decide to go in the servicer menu to "fix" the problem???? You may have some convergence issue,also.
Oct 17, 2006 | Philips 55PW9363 55" Rear Projection...
Philips 50PFP5332D 50 in. Plasma Television Logo
472 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
