Runs through cycle but does not spin - Washing Machines
Samsung WF209ANW washer spins excessively and loud. Runs longer than time on cycle
I think you should call a technician and i am guessing has reach the end of its life :)
Jul 29, 2014 | Samsung WF209ANW 40 cu. ft. Front Load...
The water runs during the spin cycle. The clothes
Does the water run through the ENTIRE spin cycle? There is a period where the water will run during the spin; This is called, the "Final Rinse". But it usually only runs for about 10 seconds then stops.
Dec 22, 2009 | Washing Machines
Only spin cycle
Check the lid switch, it only locks out the spin cycle.
eric
Jun 30, 2009 | Roper RAS8445KQ Top Load Washer
Blows 6 amp fuse in top panel. On spin cycle runs the pump but motor wont rotate for spin. If left blows fuse again.
Remove the hoses and check the impeller of the pump for an obstruction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Washing Machines
Spins slow or not at all, in the spin cycle.
Remove the water pump and check for a blockage in the pump.
If no pump problem replace the brake and the drive coupling.
Feb 22, 2009 | Kenmore 23012 Top Load Washer
WASHER WON'T SPIN OR AGITATE
Fisher and Paykel pride 5.5. It is about 11 yrs old
Oct 04, 2008 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
