Question about Sharp Televison & Video
I have a sharp Aquino's TV that keeps changing channels by it's self how do i stop it from changing channels
SOURCE: channels keep changing
Make sure there is no other remote control working simultaneously or with a key pressed constantly by mistake. In my case i found the air conditioning remote control with one key being pressed by my furniture next to my bed, it was causing that erratic behavior. As soon i realized, i stopped that remote control and problem solved. I hope this works.
Posted on Nov 27, 2007
SOURCE: sharp tv changing channels
Well, the only thing that seems to be working so far is to plug AV cables into the "input 2" ports (on the front of TV). I plugged in my PS2, without turning it on. It has not switched at random since (about 30 minutes - it had been switching off and on for the past 2 hours). Anyone else have similar success?
Posted on Nov 28, 2007
  • 168 Answers
SOURCE: Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Posted on Feb 12, 2008
Highdefjeff
  • 124 Answers
SOURCE: help it wont stop changing channel by its self?
Sluger,
Check for a stuck remote button. Take the batteries out of remotes and see if that stops it. If you have Dish Network, let me know.
Posted on Apr 08, 2008
  • 60 Answers
SOURCE: RCA P52929 changes channel non stop
try unplugging it from the electric wall outlet for an hour then plug back in, this should reset your tv back to factory default, you will have to adjust your setings if you changed them
Posted on Mar 08, 2009
My sharp tv keeps changing to channel 110 every night at 8:30
Do a hard reset on it and that should fix it, something strange is going on with the software.
Dec 05, 2017 | Sharp Televison & Video
Why am I not able to change channel on Sharp Aquos television?
Try changing channels with the button on the TV to make sure the remote is not bad. Sometimes one or just a few buttons on the remote will quit functioning. It is usually the ones that are used the most. What channel is the TV on? If it is 3 or 4 or one of the aux inputs; it may have been told to stay that way because the channels were changed by a cable box. Go to set up and scan channels into memory. After it has started, do not stop it until it says on the screen that is finished. If you stoop it before it has completed the scan, the TV will keep its original program. (one channel)
Aug 30, 2014 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
The channels on my ge 32gt720 tv keep changing by them self
Channel change button on the remote or on the side of the TV coule be stuck.
Jul 20, 2014 | GE 32GT720 32" TV
Ihave spn 4235 plsama tv problem is keep scan channel and rase the valume by self also icanot use the remote control to use the tv for on and off just plug and unplug the wire power need help plz
First take the Batteries out of your remote control to see if the T.V. is still changing channels or not. If it stops changing the channels and volume, try opening the remote with a knife and clean all the pads with rubbing alcohol to prevent sticking buttons. Be careful if using a remote with a roller ball.
Jun 06, 2011 | Samsung SPN4235 42 in. Plasma HDTV
Is a Insigna TV, it turns on by it self and starts changeing channels and I can't stop it I have to unplug it.
the problem of your TV is the button of the channel will not getting back so channel can't stop
you have to do is replace the button if you will or use a remote control to access the channel and never use manual changing channel again
Mar 09, 2011 | Televison & Video
This problem never happened before , We on the tv and the channels keep changing by it self . We are not touching any buttons and we even tried offing the tv and switching the power off . Each time we on...
As a test, block its (or the cable Box's) remote infrared sensor so even you can't change the channels with a remote. Then watch and wait. If it keeps happening, you have a poltergeist or a defective unit.
If not, something out 'there' is emitting infrared signals that the unit interprets as channel commands. Find the remote someone is sitting on or that guy across the street who's aiming at your TV with HIS remote.
Mar 06, 2011 | JVC Audio Players & Recorders
I have a problem if example i am merride to a british man and we get married in Uk, what they ganna put on my british passport example my name is Paula Nazareno Aquino, Paula is my name and Nazareno is my...
You get to decide for yourself what your full name will be! If you want, you can keep Paula Nazareno Aquino, just as it is. Or you can become Paula Jonestone. Or Paula Nazareno Aquino Jonestone. I suspect most people in your situation keep the father's surname and drop the mother's, which would make you Paula Aquino Jonestone, but it's up to you. The system in the UK is much less prescriptive than it used to be.
Oct 05, 2010 | Health & Beauty
Mac =)
Feb 12, 2008 | Televison & Video
Help it wont stop changing channel by its self?
Sluger,
Dec 30, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp 27" tv
You got the right idea,use the ext.imput on you tv and use the vcr to change the channels,you can check the solder conections in the tuner ,ussually the ground gets loose after a while but if you are not too familiar with tv service and dont want put any money in this set use your vcr.If the quality of the picture is still good then is worth keeping it.Let Us know if you need more information.
Oct 30, 2006 | Sharp 27C-240 27" TV
Televison & Video Logo
22 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
