Question about The Computers & Internet
What was the thing the master would put the slaves in, it was in the ground
No clutch master cylinder reservoir on my 84 AMC Eagle.
Check the master cylinder on the brake and see if there is a line connecting to the slave cylinder. otherwise it should be mounted on the firewall where the clutch comes through the firewall.
May 21, 2013 | 1984 AMC American Motors Eagle
Where is the clutch auto adjustment located at on a 98 manual Volkswagen jetta?
you most likely have a hydraulic clutch, which the clutch master cylinder is located on the firewall on the driverside close to your drivers side windsheild.it takes brake fluid to fill dot brake fluid will fill it properly. however if your slave cylinder on the transmission is leaking,this will require a replacement of the clutch slave cylinder. look for leakage under passenger side,,just under or below passenger side seat onto ground. recommend if you replace the clutch slave cylinder,you also replace clutch master cylinder located on the drivers side firewall at wind sheild.look under the car while someone pumps the clutch in and out,if you see brake fluid leaking under car onto ground or inside onto carpet at brake pedal,you have a bad clutch master cylinder. recommend you replace both slave cylinder and clutch master cylinder. this will save you lots of time and headaches. thank you for choosing fixya.com
Sep 24, 2011 | 1998 Volkswagen Jetta
What are the jumper settings on the drive for the following? Cable select Slave Master
For Slave/Master set up most hard drives have a little diagram on them showing you where to put your jumpers for master and where to put the other one for slave. All hard drives are different. But on your diagram it should say "MA" for master, "SL" for slave and "CS" for cable select.
For Cable select you have to set jumpers to cable selected which should be on the diagram on your hard drive. You will need an 80 conductor IDE/ATA cable. The master conductor is at the end of the cable and the slave conductor is in the middle.
Mar 25, 2011 | Computers & Internet
It is difficult to put into gear from a stop and while downshifting. 2000 mustang V6
check gear fluid in the tranny, brake fluid in the clutch master cylinder. after that check slave cylinder and linkage
Jul 30, 2010 | Ford Mustang Cars & Trucks
What happen if i dont put jumper in a hard a hard drive?
If you don't put jumper in harddrive is detects it as cable select means if you connect your harddrive to middle socket of ide cable and then it detects it as slave but if you connect it at the end of ide cable it detects as slave.But make sure that otehr device is not set as master only 1 device is set as master or slave .
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 01, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
Clutch
i don't know if you went back to look at my post, but i fixed my car by putting in a new slave and new master cylinder and then tightening up the clutch petal. it does NOT grind anymore! and my baby is like new! it cost me about $90 through napa auto parts. $66 for the master and $16 for the slave and it comes with everything you need. hope this helps you!
Jan 20, 2009 | 1991 Mitsubishi Eclipse
Where do i plug in a second hard drive on the motherdoard on a hp pavilion a1220n
When you open up the casing (make sure you ground yourself), there should be a ribbon cable marked master and slave. The master is your primary drive, so you would connect the slave to your secondary hard drive. Have any other questions, let me know
Nov 25, 2008 | HP Computers & Internet
Hard disk
you have to have both drives share the ide cable.on the back of each drive you will see a jumper,you will also see markings cs,mas,slave.the drive you want as master use the jumper on cs (cable select).the drive you want for slave use the slave jumper.if you just want to use your new drive put the jumper to cs first if that doesnt work put the jumper to master.
Jan 07, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
20 people viewed this question
Top The Computers & Internet Experts
Ap12
Ap12
MonsterByte
Level 1 Expert
Kelley Hopper
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
