Question about Refrigerators
My icemaking machine is giving me deficient. What does that mean?
What causes low potassium in men
A man rarely develops a potassium deficiency as a result of inadequate dietary intake of potassium, although it is possible. Most potassium deficiencies occur as a result of long-term use of diuretics, laxatives and steroids. Chronic vomiting and diarrhea also can cause a potassium deficiency in men. Chronic kidney diseases can lead to hypokalemia, as well.
Sep 21, 2017 | Cooking
What does the word deficent mean keeps showing up
Hello Jenny;
My name is peter. I am a retired field service refrigeration technician.
The term deficient refers to deficient cooling. You did not provide a model number which is on a label inside the fresh food section wall.
So, what is going on. Is your freezer fan running? Is it warm in the fresh food section? Is your freezer warm?
Nov 14, 2014 | Refrigerators
Leaves falling off why?
Is tree 5-7 years old? Does the soil around the base rock when you push on trunk? If so strangulated roots and not correctable. Old tree? Could be water deficiency, nutrition deficiency, insects, fungus or a bacteria.
Dec 01, 2013 | Garden
What are the faults and deficiencies in reading?
see best reply i from
Leave blank until a deficiency is found. If a fault has been found then enter
the current odometer reading. Enter a "K" after the reading if the measurement
Feb 28, 2011 | Computers & Internet
I have a GE profile TFX26PPdaWW refrigertor which has stopped making ice. The bar is down, so the icemaker is on. Every once in a while the interior arm will turn to force ice out, but nothing comes...
The place to start is at the fill tube going into icemaker...look into that and make sure its not frozen up with an ice plug. if it is, the inlet valve is bad..defrost the tube and this will give you temp service while looking for new valve..
if no ice plug , then the fill valve is bad or your icemaker. if you have water and ice..its a dual valve..One side does water and the other does ice..the ice side could be bad, but you have to replace the whole assembly...I would take a ohm meter and ohm out the coil,or run a cheater cord to it and see if it opens.(this means run 110 volts directly to coil) if you get water inside to icemaker, more than likely the icemaker module is bad, but ,I would replace complete icemaker assembly
Jan 23, 2011 | GE Refrigerators
What does 108 iq mean?
It is what it is. It's certainly not "brilliant" nor is it "mentally challenged." Simply average. Here's what they all mean:
Over 140 - Genius or near genius
120 - 140 - Very superior intelligence
110 - 119 - Superior intelligence
90 - 109 - Normal or average intelligence
80 - 89 - Dullness
70 - 79 - Borderline deficiency
Under 70 - Definite feeble-mindedness
Jan 22, 2011 | Computers & Internet
Ice machine stopped making ice. The "bucket" that holds the water around the ice making sensors no longer moves when the ice machine is powered on or off, and noise can be heard as if it is try...
I had a similiar problem. The unit would only flash deficient. I removed the rear cover (3 screws along the back top, 3 screws underneath, and the 2 feet), then opened the panel to access the control board and disconnected the temp. sensor. Working great now, but the deficient continues to flash. Hopefully i will be able to find a replacement part.
Jan 05, 2011 | Sunpentown SPT IM-100 Portable Ice Maker,...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
