Question about Cell Phones
Hi some of my apps say none set as default - Cell Phones
How do I clear an MMS error code 226 from my Kyocera Hydra phone
1) Download (Handcent next SMS) app, and set as default message app.
2) open and pull down menu in upper right corner, and click on delivery reports.
3) delete all undelivered messages.
4) exit, and click on stock SMS app, and set as default messaging app, or continue to use Handcent as default messaging app. PROBLEM SOLVED! :)
May 22, 2016 | Kyocera Cell Phones
I cannot receive any text messages that contain a picture
There are a few things to do that may fix your issue:
1. Delete text messages off of your phone (especially if you have hundreds of texts to one recipient)
2. Go to settings in your "messager" app and reset setting to default.
3. Make sure your APN settings are correct:
Go to "Settings"
Select "More networks"
Select "APN"
Edit your currently used apn...
APN: wap.cingular
Proxy: none
Port: none
Username and password are blank
Server: none
Mmsc: http://mmsc.cingular.com
Mms proxy: wireless.cingular.com
Mms port: 80
Mcc: 310
Mnc: 410
Authentication type: none
APN type: default
Oct 05, 2015 | AT&T GoPhone ZTE Maven 4G with 2GB Memory...
My tracphone SCH-S738C keeps freezing up. Tried bunch of cleaner, booster, optimizers ect but none so far are helping. What apps do u recomend?
The absolute best thing to try first is a factory reset on the phone, generally found in settings. If the phone at factory defaults still freezes up, it's most likely a problem with the phone and you may need to contact either the manufacturer or the retailer you purchased it from. If it works fine at factory defaults, add your previous apps one at a time and test it to make sure it runs fine with that app. When you find the app that's causing your phone to lock up, try to find an alternate app that will fulfill the same function but without as much taxation of your cell phone's resources.
IMHO, cleaner apps, booster apps, et. al. are not worth the time, space or data to even bother with them.
Apr 15, 2015 | Cell Phones
Why when I plug in headphones It doesn't cancel my phone speaker?
Didyoucheckte app?someapps might default to external speaker
Mark
Motorola Support
Jul 03, 2014 | Motorola Mobility DROID RAZR M
I have a Cisco lynxsis wireless router I had wireless the other day but the. It just stopped connecting. First it said I was connected then none of my apps would load using the internet. Then it stopped...
The previous answers get you to the point where you can log into your router using the IP address of the default gateway. You will, of course, need the proper credentials (username/password). What you want to do is change the wireless channel. Most modern routers/gateways default to "auto," which means they can change channels at will. I prefer to fix my routers to a specific channel, based on some analysis. For this, I use an app called WiFi Analyzer, which is a free download from the Google Store. If you have an Apple device you're out-of-luck, as Apple will not allow your phone to determine the signal strength of nearby WiFi devices. The WiFi Analyzer app provides various representations of the signal strength of all channels on your router. Simply choose the best channel and set your router to use that channel.
Sep 25, 2017 | Computers & Internet
How to remove sms reg on android
Do you want to change the default SMS app on your phone? If so, you can go to the Apps > Settings > Apps > Messaging App > And choose option to restore defaults. Then find a different default messaging app from Google Play Store and choose it as your messaging app.
Mark
Motorola Support
May 30, 2014 | Motorola Cell Phones
How to set default browser
How to set default browser: http://browsers.about.com/od/faq/tp/Setting-The-Default-Browser.htm
Nov 15, 2013 | Computers & Internet
Where to find password to join wireless network?
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | 2wire HomePortal 100W (1000-400026-000)...
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
