Question about Cell Phones
HI my phone will got give me permission to get into my apps .How do l turn it off. thank you
How to give android permission to access sdcard
I'm not sure what you mean by "accessing". Individual apps will ask for permission to access your SD card when you first run them. Is your SD card not appearing in Settings?
Aug 11, 2017 | Computers & Internet
Tip
BlackBerry Tour: How to change app permissions
Every app that you install on your BlackBerry Tour has a set of permissions that tell it what functions or information it can or can't access. For personal, business, or security reasons, you may at some point want to modify your apps' permissions. Below is the procedure for changing app permissions on a BlackBerry Tour.
From the main screen, press the BlackBerry button (to the left of the trackball) to bring up the Home folder. Scroll down to Options (the wrench icon) and select it. From the Options menu, select Applications.
On the Applications screen, you can view three different categories of apps: Third Party, Add-ons, and Core apps. Select the type of app that you want to modify, and all of the apps of that type will appear in a list.
From the list, scroll down to the app that you're looking for and highlight it, then click the BlackBerry button. Select Edit Permissions, and you'll see a list of all of the permission categories for that app and what they are currently set to. You can modify any of the individual permissions however you want; for example, you could allow USB connections for a specific app while denying Bluetooth connections.
Be aware when modifying app permissions that certain apps will require certain permissions to function. For example, a GPS program probably won't be able to function if you deny it the permission for Location Data. Some core apps -- like BlackBerry Messenger -- won't even allow you to edit their permissions.
Your BlackBerry has a default permissions configuration that it applies to new apps, and you can modify this default permission list as well. To change default permissions, click the BlackBerry button from inside an app's permissions and choose Edit Defaults, or click the BlackBerry button when in the prior Applications screen and select Edit Default Permissions.
on Jan 06, 2011 | RIM BlackBerry? Tour 9630 Smartphone
What does screen overlay detected mean with android phone?
Step one: "Screen overlay detected" fix
Find you what apps have permission to draw over the screen. On a non-Samsung smartphone, follow these steps:
  • Open the Settings
  • Tap the magnifying glass at the top right
  • Enter the search term "draw"
  • Tap Draw over other apps
  • Alternative route: Apps> [gear icon]> Draw over other apps
For Samsung users:
  • Open the Settings
  • Then Applications > Application manager
  • Press on More > Apps that can appear on top
Step two
You will find yourself in front of a list of apps that have permission to use floating buttons or other screen overlays. Now you need to identify the problem app and temporarily deny it permission to draw over the screen. Here is are some pointers on how to identify the app that's causing trouble:
  • Do you see an app bubble on your screen? If do, this app is almost certainly the cause. Either you hide the app bubble or disable the app in the list
  • Do you have an app installed that changes the colors on the display or adjusts the brightness?
  • Reportedly, Clean Master can be a trouble maker. If you see Clean Master in the list, disable it
  • If there's no obvious cause, disable everything
Step three
Now you can try launching the app again, and it should request permissions without the "Display overlay detected" error getting in the way.
For Samsung users: We have also received a report that suggests the one-handed keyboard setting could be the root cause. Deactivate it by going to Settings> Advanced features > One-handed operation.
Step four: reactivate screen overlays
In order for the app(s) that you have disabled in step two to work again, you need to re-enable its overlay permissions. If you turned off all apps, it might be worth considering only reactivating those apps that you actually use.
This is a rather inelegant workaround, but it's the best we have until Google makes the necessary changes to prevent app overlays from interfering with permission dialogues.
Has this guide helped? If you are still experiencing the error after following our guide, leave a comment, so we can try and address the problem.
Oct 20, 2016 | Android Cell Phones
Is a flash light download on a Smart phone melicious spy ware?
Check the permissions the app needs. Permissions for camera is normal (for flash). Permissions for network, contacts, test storage etc are overboard and highly suspicious. It may even be cause to report the app in whatever appstore it was obtained from.
Note that network permissions would be needed for the app to display advertisements.
Feb 28, 2015 | Apple iPhone Cell Phones
Install youtube
In order to install Youtube to your phone you will need to access the market from your apps menu.Click on the market and then type in Youtube in the search line provided.The YouTube application will show up and then you click on it to download it.Once it is downloaded you will be asked if you will give permission to install it.Give the permission to it and it will automatically install to your phone.Once it is done it will prompt you to open the application.You will be able to find the Youtube application in your apps menu.
Thank you for choosing Fixya!!
Jul 02, 2012 | LG GD510 Cell Phone
After upgrade of software Phone turns itself back on even hours later
There is likely a process or application that is preventing your phone from turning all the way off, or it is turning your phone back on for its own purposes. Check the permissions of your installed apps to make sure none of them have that permission, and talk to Verizon to see if the recent upgrade may be causing the problem.
Nov 24, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
Need to save apps to sd card, how to get permissions signed for apps
Unfortunatly due to application Licenses they cannot be saved to SD cards to prevent illegal distrubution of the app as far a permissions to save the apps must be obtained from the creator of the app and 99% of the time they will not release that permission due to the potential financial loss
Sep 21, 2010 | Samsung SGH-A877 Impression Cell Phone
Java Applications Not Working On My Cingular Se w810i
Reinstall the Firmware or updating to the latest software from S.e 's site.
that must be then some hardcore java errors?
Nov 04, 2007 | Sony Ericsson W850i Cellular Phone
Java Applications Not Working On My Cingular Se 810i
i understand ur problem , but it has been very frequently noticed that most of the application available on net are not compatible with Sony Erricsson handsets...plz make sure that the apps u r trying to install are compatible for ur phone , it is a clear java version mismatch...
Oct 14, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Oct 11, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
