Question about Craftsman Garden
42 inch craftsman 19.5 engine. I replaced belt, now there is less tension on the new belt. I have the deck with the rod and not the cable. How to adjust tensioner on deck if Possible?
    Champion:
    Habit-Forming:
  • 211 Answers
Here is a link to the craftsman web site. type in your maodel number and check out your owners manual
http://www.searspartsdirect.com/partsdirect/user-manuals
Posted on Jun 22, 2017
  • 5 Answers
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
Posted on Apr 25, 2009
  • 57 Answers
SOURCE: craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
Posted on May 18, 2009
  • 10865 Answers
SOURCE: I have a craftsman riding lawn mover 42" model #917270812
Hi Paul It sounds like the belt is worn, stretched, or possibly just two long for your machine. Save yourself a lot of aggrivation by checking your operator manual and getting exactly the right belt for your mower.
You don't say how old your machine is but if it has been mowing for many, many hours, the tensioning spring may need to be replaced. If that is the case you can order a new one at Sears.com
Posted on May 20, 2009
  • 148 Answers
SOURCE: need a manual for a LT1000 craftsman 19 1/2 HP 42 inch mower deck
You can download a free copy at www.managemyhome.com or you can go to www.searspartsdirect.com and buy a copy along with look at the diagram that you need.
Posted on Jul 23, 2009
The GR8 1
  • 7 Answers
SOURCE: Craftsman 42 inch deck mower.
That model number des not show up as a good number on the http://www.searspartsdirect.com site. Are you sure you have the belts on correctly? If it has 2 belts on the deck & 1 is not installed correctly they work against each other. Safely make sure that each blade will turn by hand. did you take the blades off? If they are too long by just a fraction, they will hit ach other, but that usually makes quiet a noise. Get your book out & systematically go over everything you touched or changed. It sounds like something really simple you have overlooked. you can go to http://www.searspartsdirect.com & enter a good model number & view all of the parts diagrams. Sometimes they are a big help, & at other times they just confuse you more:). Let me know what you find!!
Posted on Aug 13, 2010
How do i troubleshoot 42 inch craftsman lawn tractor on which the mower deck quit engageing
Most likeley is a spring on the top of the deck or the cable that goes from said spring to the lever. if you could provide the model number I can look up the manual and diagram and show you.
Jun 29, 2014 | Craftsman Garden
I have a 17hp craftsmans lawnmower with a 42 inch deck. The motor runs fine, I just cant get the deck to engage. How do i fix this?
I hope you didn,t put wd40 on the belt that will cause it to slip, also with the motor OFF you should be able to engage the belt, so try that just to make sure it does engage and check the tension on the belt it should be snug. Again only with the motor OFF.
Mar 26, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman gt5000 26hp 54" deck. I removed the cutting deck cleaned and replaced blades then when i put it all together the belt wont fit. Theres a belt tensioner rod that i disengaged but...
Belts do not change length. You are doing something wrong with the routing. Maybe the tensioner goes on the other side of the belt or the belt should be routed around the other side of both the tensioner & idler.
Gary
Jul 06, 2011 | Craftsman GT 5000 26 HP54" Garden Tractor...
Need a diagram how to put a belt on a craftmans 42 inch 19 hp twin engine
http://media.fotki.com/1_p,srbkgqfsgggdwfgxgtqsskgwtqkq,th/rrdqddwqbxbwgwtsrdbxttqfksftw/1/1303472/5961991/image7270496268268023884img-th.jpg
May 26, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I need to tighten belt for the mower deck, how is that done? it is a 2004 craftsman 17.5HP 42 " deck. Can you help me
Each of the pulleys on top of the deck should have tensioners. These tensioners are usually the type which have a bolt for you to tighten while attached to the pulley. While you tighten the bolt, the pulley puts tension on the belt.
Aug 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 19 hp Troy Bilt Super Bronco with the
sounds like spring tension on top of deck is connected to a bolt post,mine broke and went missing with the spring,blades kept slipping,didnt know how to tighten belt,go figure
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower Belt Won't Engage
The fact is that belts don't stretch. They wear down on the sides, causing them to ride deeper in the pulleys and they APPEAR to be longer. Check belt "width" to see if it is less than one half inch. Most craftsman riders use half-inch (AKA: "A section") belts.
Sep 26, 2009 | Garden
Craftsman 42 inch cutting deck riding lawn mower. I can not get the mower to to ingage. The belt appears to be tight and has not follen off the pulley.
Some of the 42 inch Craftsman mowers Have a cable that goes from the blade leaver to the deck some have a linkage if it has the cable check it to see if it has broken. Find where it connects to the deck pully and pull on the cable wire not the cable cover and see if if comes out also make sure it is connected to the top of the idler pully. If it has a linkage there is a clip that holdes that linkage to the deck it most likely came off.
Aug 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 inch deck won't run
May 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I need belt diagram for 42 in deck
Apr 23, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
77 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
