Can't insert ink cartridge...opened one cover...cannot open cover exposing existing cartridges
Mix-it-up
  • 832 Answers
SOURCE: new ink cartridge istallation: Brother MFC-240
I guess you d used generic ink carts?!
If yes, the cart holder needs replacement due to ink that has stained the led control. The ink has made a short circuit. The error can only be deleted by replacing the whole cart holder!
Posted on Jan 28, 2008
SOURCE: MFC does not recognise the new black ink cartridge.
Disconnect power supply and USB lead (leave disconnected for 10 min). Repeat this for each colour that is not working and hey presto the LCD readout will revert to normal and you will be able to print again. Happy Christmas! Hope this works for you (worked for me)
Posted on Dec 22, 2008
SOURCE: epson stylus cx8400 cannot recognize ink cartridges
I had the same problem except it would not recognize any of the ink cartridges. I kept hitting the OK button over and over again with the same cartridges in place not removing them at all and it finally recognized them. Decided to go to maintenance on the printer to do a test, and it went right back to not recognizing the cartridges. So i pressed the OK button over and over again until it finally recognized all the cartridges again, but this time i did not try and go into the maintenance to do a test run. Plugged it up to the computer and it has been working ever since. So press the OK button until it recognizes the cartridges, and run no tests on it is what my solution was for the problem. Really is a pain but it works now.
Posted on Apr 06, 2009
SOURCE: No Cartridge installed on Brother MFC-640CW
i need insteled solfwere of the mfc-640cw
Posted on Oct 29, 2009
  • 1218 Answers
SOURCE: error- no ink cartridges
1. Set all the printer cartridge both black and color cartridge (including the empty one)
2. Right click on printer driver properties
3. Click Maintenance tab
4. Click on Ink Cartridge Setting mark
5. In pop up menu, select the cartridge which has ink inside (black only or color only). or check the following information..
http://www.fixya.com/support/t2689003-set_ink_cartridge_invalid_ink_cartridge
Posted on Sep 06, 2010
I have an epson sx510w how to change ink cartridge
use the tool button to access the menu and let it know you want to change cartridges. IF you dont have the instructions then go here and download the basic operation guide
http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Stylus-SX515W/Drivers-Support?defaultOSId=3&target=#
Jan 08, 2012 | Epson Office Equipment & Supplies
How to change printing cartridges
Here's how to change your cartridges: 1 Make sure the printer is on. 2 Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. printmastert_25.jpg
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid. printmastert_26.jpg
4 Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
You may also refer to this link: How to Set Up the Lexmark X3600 or X4600 Series All-In-One
Apr 04, 2011 | Lexmark X3650 Printer
How to refit the epson scan printer cartridge
Turn on your printer and open the top cover (not just the scanner lid) and press the maintenance button (the little paper icon with a drop) and wait for the head to move into the maintenance position. Now lift the ink cartridge clamp to expose the ink cartridge and carefully lift the old cartridge out. Now open the new cartridge and remove the yellow strip, but however do not touch the green tab, now insert the new cartridge with the green tab facing toward the front of the printer. Now close the clamp and re press the maintenance button and wait for the printer to recognise the new ink cartridge (30 secs.) And you are finished.
Thanks,
Ash.
Feb 28, 2011 | Epson Stylus NX400 InkJet Printer
I need to know where the ink cartridge goes on my x6575 what cartridge goes where
1.Turn on the printer.
2. Open the printer by grasping the printer's top lid, to the left of the control panel and just below the scanner cover ,( approx. 1 inch ) to expose the ink cartridges.
3.Press down on the cartridge carrier levers.
4.Remove the tape from the black print cartridge, insert it in the left cartridge carrier and close the lid.
5. Remove the tape from the color print cartridge, insert it in the right cartridge carrier and close the lid.
6. Close the printer.
Your ink cartridges are installed.
Feb 17, 2011 | Lexmark X6575 All-In-One InkJet Printer
How do you load new printer cartriges
To replace an ink cartridge using the fonth.gif ink button, follow the steps below.
1. Make sure that the printer is on. The fontp.gif power light should be on, but not flashing.
2. Lower the output tray, then open the printer cover.
3. Press the fonth.gif ink button. The print head moves to the ink cartridge replacement position, the fontp.gif power light begins to flash, and the fonth.gif ink out light corresponding to the ink cartridge that needs to be replaced begins to flash or remains on.
4. Open the cartridge cover. Pinch the sides of the ink cartridge that you want to replace. Lift the cartridge out of the printer and dispose of it properly. Do not take the used cartridge apart or try to refill it.
5.Remove the new ink cartridge from its protective bag. Place the ink cartridge vertically into the cartridge holder. Then, push the ink cartridge down until it clicks into place. Do not apply excessive force to the cartridge.
6. When you are finished replacing the cartridge, close the cartridge cover and the printer cover.
7. Press the fonth.gif ink button. The printer moves the print head and begins charging the ink delivery system. The fonth.gif ink lights start flashing. This process takes about one minute to complete. When the ink charging process is finished, the printer returns the print head to its home position. The fontp.gif power light will stop flashing and remain on, and the fonth.gif ink out light will turn off. The fontp.gif power light will continue to flash while the printer is charging ink. Never turn off the printer while this light is flashing.
Nov 19, 2010 | Epson Office Equipment & Supplies
How do you replace the ink cartridge on my Canon pixma mx320 printer?
Lift up the top lip cover together with the scanning unit cover to expose the cartridge carrier.
Open the ink locking cover. Gently pinch and pull up the cover of the cartridge carrier.
8bc22ce.jpgAfter that replace the ink cartridge...
I hope that instruction will be of help.
Please rate this answer.
Thank you for using Fixya
Jun 07, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Replaced ink cartridge still shows ink low needs to be replaced but is printing? Can it be reset?
  1. Remove your current empty cartridge from your Dell printer. Turn on your printer and lift the cover and top half of the unit. You can suspend it in place by lifting the blue plastic lever and securing it to hold up the top of the printer. At this point the ink cartridges should move to the center of the printer and be easy to access. Follow the instructions locate on your printer to remove the cartridges. You can do this by pressing on the blue tab to remove the colored cartridge or the black tab to remove the black cartridge. Once you press the tab, the cartridge cover will pop open. Carefully pull out the exposed cartridge from it’s setting. Save the empty cartridge so it can be refilled.
    Remove the sticker from the newly refilled Dell ink cartridge. Follow the directions on the opened printer to insert the cartridge. Hold the cartridge so the writing is on the top and the ink spot is on the bottom. Gently push it into the opened setting until it is securely in place. Close the cover of the cartridge holder by pressing down on it gently until it clicks into place. Remember that the black cartridge goes into the black setting and the color cartridge goes into the blue setting. Close the top of the printer. You will hear the ink cartridges move back into place.
  2. Test your newly refilled Dell ink cartridge and load your printer with paper.Print a document so either in color or black and white (depending on the type of cartridge you had refilled). Review your printed document to make sure the color is consistent and you are pleased with the outcome.
    Repeat whenever you run out of ink.
Apr 30, 2010 | Dell V305w All-In-One R840635AU InkJet...
How do you install ink cartidrige
Assuming your printer is powered ON. Just open the printer cover then wait for the cartridge carriage to be in the cartridge loading position (on the right side of the printer). Pull existing cartridge (if there is any) by pushing the end of the cartridge down and pull.
Inserting new cartridge is done the opposite way... insert the cartridge by pushing it forward then up.
Black goes on your left and Colored in on your right.
Hope this comes clear on you.
Jan 29, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
How do i change my ink cartridges on SX200 please
Open top cover, exposing control pad.
Press button (align??) to move expended cartridge into place for removal
Squeeze both clips to remove.
Peel tape from new cartridge, being careful to avoid touching contacts.
Insert new cartridge, gently push until fully seated.
Press button again.
Close top cover.
Aug 05, 2009 | Epson Office Equipment & Supplies
23 people viewed this question
k24674
jasbo
jasbo
