Question about Timex Watches
3v timex battery does not stay in place, loose.
    Top Expert:
  • Timex Master
  • 45,112 Answers
The keeper could be damaged or missing.
Posted on May 02, 2017
Timex battery don't stay in baTTERY HOUSING
Could be wrong type battery or broken or damaged retainer
May 02, 2017 | Timex Watches
Timex expedition battery replacement,how to keep battery in.
push down on the battery it should click in if not use a small peace of seletape.
Feb 10, 2013 | Timex Expedition Watches
Hello. I own a 40 to 50 year old "Timex Electronic" watch. There is a number date at the 3 o'clock position. I see no other identifying info on the outside. I don't have a battery for it. How
What is the exact model of the watch. I have several Timex Electronic watches that might fit your description. If you pop the caseback do you see the old battery inside? Most batteries would have a reference like: CR2016.
Jan 06, 2013 | Timex Watches
Got new battery for my Timex two weeks ago at Gaisano Mall. Now watch is dead. Repair technician at Gaisano said I need to take it to a Timex Center, because a circuit needs to be repaired. Is there any...
here's the address of service centers in Cebu TIMEX factory outlet Mactan Marina Mall . tel no. (032)3406638 and WATCH REPUBLIC SM Cebu Upper Ground Flr. tel no. (032)2336427. in Butuan timex only has drop off center at GAISANO BUTUAN. I hope i had helped you.
Jul 17, 2011 | Timex Expedition 84601 Wristwatch
My battery is running dead . Can I have it replaced ?
Yes, the battery for this watch can be replaced. Timex estimates that the battery should last 2-3 years, but that assumes an "average" use of the Indiglo backlight. If you never use the backlight or audible alarms, your batteries would have lasted longer; heavy use of both would have run the battery down more quickly.
If you want to replace the watch battery yourself, you'll need a very fine philips or flathead screwdriver, the new battery, and a bit of patience. It would also be helpful to have a pair of tweezers, but that's not absolutely necessary. If you carefully look on the back of your watch, Timex usually lists the battery type so that you can buy a replacement battery without first opening the watch. If you can't figure out what the numbers mean, take it to a jewelry counter at Target or Walmart, and they should be able to help you decipher it. I don't know which battery this specific watch takes, but many Timex watches use a #1620 or #2016 3v battery. Look for a number like that on your watch back.
To open up the back of the watch, open the strap so that you have good access to the back. If you have a steel band, you might need to slip out one of the adjustment pins to separate the band into halves. Yes, you might be able to take the back off without this step, but it makes it a lot easier.
Place the watch face down onto a soft surface. I like to use a dark towel, so that if I drop one one of the tiny screws you'll be dealing with in a minute, they won't bounce and you can easily find them again.
Use your screwdriver to loose the back of the watch, one screw at a time. I find it very helpful to loosen a screw, then use the tweezers to pick it up out of the hole. These guys are tough to grab with your fingers! Put the screw in a safe place, then carefully remove the back of the watch. A little black neoprene gasket may be stuck to the back or be floating around--don't lose that!
You should be able to see where the battery is kept. On most Timex watches, there's a metal shield covering the watch and completing the power circuit. Using your screwdriver, gently pry the tabs of this shield away from the watch movement, one tab at a time. Try very hard not to snap off any of the little plastic anchors. On a Casio watch I recently serviced, I had to remove the movement from the watch to get at these little tabs; I don't remember ever having to do that with a Timex.
Once the shield is loose or removed, the battery should slide right out. Replace the battery, and gently snap down the metal shield. Turn the watch over to check whether it's working again. If it's not, you may have to push a little "reset" pin on the watch movement to clear the registries. The back of the metal shield usually has instructions on where that little pin is located. If the watch is already working, you won't need to do this.
Closing up the watch is the reverse of what you did to get it open. Make sure the neoprene gasket is back in place--that's what's keeping sweat and water out of the watch--and carefully set the cover back in place. Tighten the screws in an "X" pattern--i.e., top left, then bottom right, then bottom left, then top right. I get all the screws loosely screwed in before tightening them down in earnest. This watch has a plastic case, so you want to tighten the screws snugly, but not over-tighten them so that they strip out the screw hole.
May 10, 2011 | Timex Ironman 30 Lap 53952 Wrist Watch
I have a timex exped. that looses time i changed the battery twice can you give me some suggestions on fixing this problem ?
Generally speaking if a Timex needs more than a new battery (cell) it is new watch time. Anything else is either too expensive (more than a new watch) or can't be fixed. Make sure you have the cell in correctley, if there is a reset, reset the movement. This is often a matter of shorting out a small pad to ground with metal tweezers.
Mar 10, 2011 | Timex Watches
On my Timex T53722 the bottom of the display is cut off and the Contact mode is getting erratic. It has a new battery.
mcdevito75 here, If you changed the battery yourself, you"ll have to go back into the watch to make sure the buttons are presssing fully, and on the correct spot on the quartz movement, some times these button contacts get mis-aligned due to moveing the movement while replaceing the battery, you"ll also have to check the battery contact in the watch also, make sure the battery is being held fairly tight, the battery could have gotton loose. If you had the shop replace the battery, return to the shop for adjustments.
Jul 18, 2010 | Timex Advanced Data Link 53722 Wrist Watch
I though I had a dead battery and had it replace since then it looses time and the compass does not work Does this watch have two batteries The person that replaced the battery could not see but one...
The Timex web site for similar models implies only one battery.
I would have thought space was a little too restricted for two batteries.
It seems likely that there is something else wrong and the watch should therefore be taken to an authorised repair agent (see Timex web site for details).
Mar 17, 2010 | Timex Expedition 40141 Wristwatch
Looses time
bring it back its still under warranty. if this helps please rate
Nov 19, 2008 | Timex Watches
Watches Logo
82 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
