Question about Camping, Backpacking & Hiking
HOW CAN I GETSCREW CAP FOR A AIR MATTRESS TWINSIZE
Air leaking from cap on Ozark air mattress
There should be an internal one-way inflation valve that prevents leakage. The valve may be failing to close completely.
Aug 24, 2016 | Ozark Trail Velour Top Airbed Kit Queen
Northwest queen air mattress
You can always make a plug. Get a piece of clear vinyl tubing about 1 inch long. The inner diameter of the tube should be the same size or just a bit wider then the width of the mattress plug your missing. Get a small tube of clear silicone rubber (make sure its pure silicone rubber) and completely fill the vinyl tube. Let it sit for 4 or 5 days to completely dry. Cut off the vinyl and your new plug emerges! Use your scissors to cut the tip at an angle so its easier to get it into the mattress tube.
Mar 24, 2015 | Vacuums
Need a replacement valve cap for an Embark Queen air mattress
I went to dirt cheap yesterday and purchased a Embark Air Mattress and once I got it home I discovered that the mattress didn't have a valve cap. I want to know if you could replace the cap without any cost? If you would like to send me one here is my address P.O. Box 282 Blue Mountain Miss 38610 Thanks for your help
Feb 16, 2014 | Embark Queen Pillow Top Double High Air...
What type of mattress is best to buy for a sofa-bed?
The best type of sofa bed mattress are:
1. Latex Mattress
2. Spring Mattress
3. Foam Mattress
4. Pillow Top Mattress, etc.
It is really a tough task to choose a mattress for a sofa bed. You can consider color combination and several factors of the mattress to buy the best one for you and your house.
Aug 16, 2012 | Furniture
How do I deflate my air mattress?
Some pumps come with a deflate setting so make sure to check that first. If not, you need to unscrew the cap off the valve and listen to hear that air is escaping. Then remove your shoes and walk up and down the surface of the mattress. Once you have done this a few times, you will be able to roll up the mattress from the end opposite the valve.
Jul 31, 2012 | Camping, Backpacking & Hiking
Why other leter n ke board not function
its just dirty contacts if you can open your keyboard, clean contacts with non rubber eraser like the ones used by engineers and draftsmen. also include the rubber contacts under the keys
Jul 25, 2012 | Acer Computers & Internet
How do you deflate the northwest territory queen size air bed
I was confused by this too. Here's the trick:
When you inflate the mattress, you unscrew the square-shaped plastic cap, like this:
But this is *not* the cap you unscrew to deflate it!
To deflate it, you have to unscrew the plastic at the *round* part that's beneath the square cape -- i.e. the part of the plastic that's affixed directly to the mattress. When you unscrew the round part, the entire plastic apparatus detaches from the mattress, leaving a big open round hole where the air rushes out.
It looks like this:
Jan 06, 2012 | Baby Gear
I cannot find a manual for a blue magic super pump
See the instructions near the bottom of this web page: (picture at the top of pasted instuctions on th link)
http://www.abcwaterbed.com/pump2.htm
  1. IMPORTANT! - Unplug waterbed heater for safety
  2. Remove cap and seal and put aside in safe place.
  3. Remove any excess air from mattress - slide forearm or broom handle from the head of the bed toward the fill hole to move air pocket
  4. Attach the heavy duty hose to the hose valve coupling, connect to the waterbed mattress and other end to the pump intake side. Be sure to include O-rings. Gently push the coupling deep into the mattress.
  5. Attach garden hose to the discharge side of the pump, this hose goes to a tub, or a deep sink.
  6. Plug in the pump. When it starts it should have a low whirring sound, not a high whiny one. If water is not pumping immediately unplug the motor and check hose connections for tightness, verify there is no air in the mattress.
  7. As the pump removes the water, be sure the hose valve coupling at the mattress is pushed down in the mattress to maintain suction. Heavy phone books or other like items will help maintain proper position deep in the mattress.
  8. Keep pumping the water out and continuing to maintain the hose valve coupling position low in the mattress so it can keep pumping.
  9. Do not leave the pump or the area until finished. A dry pump can burn up.
  10. When the mattress is part way empty, you can place pillows under it at the head to help the water run downhill towards the hose valve coupling.
  11. Continue pumping until water flow stops or pump changes sound. The more water you get out, the easier your mattress will be to handle.
  12. If you are satisfied you have got as much water out as you can, remove the hose valve coupling and quickly replace the mattress seal and screw the cap on.
  13. If the mattress is to be stored for a period of time, pour in a large bottle of waterbed conditioner into the mattress before you cap and seal the mattress.
  14. We recommend rolling up the mattress from the head to the foot and carefully sliding one end into a wardrobe box. Another wardrobe box can be worked over the top of the mattress. Work one box into the other and seal both ends and tape the boxes together in the middle. You can now safely move the mattress.
  15. If you don't get enough water out, the fiber layers can easily slide out of position during moving and you may not be able to get them back into position when you fill the bed.
Nov 18, 2010 | Magic Pool & Spa
Camping, Backpacking & Hiking Logo
540 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
