Question about Jensen Car Audio & Video
We can not get our Jensen Media Pro 5000 to turn on. the display shows 1200 am. We checked the fuses and they are fine. I am looking for troubleshooting tips.
    Master:
  • 507 Answers
Http://www.outbackers.com/forums/index.php?showtopic=53361
Posted on May 02, 2017
Tip
Playstation2 SCPH 3000 - 5006 General Problems
No Power (Totally Death).
  1. Check the output regulator 12volt DC Power Supply.
  2. Check the Fuse (Voltage Security Fuse).
  3. Check the Flexible cable on switch board (reset & eject button).
  4. Check the Output Diode.
Lens Problems (Optic)
  • Optical Spull not move (up down).
  1. Check the flexible cable.
  2. Check the Optical spull.
  3. If you have SCPH - 3000 series, check the IC Driver (BA 5815).
  4. If you have SCPH - 5000 series, check the IC Driver (LA 6508).
  5. Check the optical flexible cable socket.
  • Optics spool laterally tilted or irregular jump when the engine turn on.
  1. Check the resistor on 102 block (In IC Servo Master Control area = CXD 3098 : 470-8pin,102-8pin).
  2. Check the resistor under IC Servo Master Control.
  • Optics can only read one CD/DVD format.
  1. Check the Optic Laser Diode.
  2. Check the Optic Laser Diode with Voltmeter : V3 (CD=1080 to 1260, & DVD=800 to 1300), V4 (CD=850 to 900, & DVD=1200 to 1400), V5 (CD=1200, & DVD=1400), V7 (CD=1200, & DVD=1100 to 1400), V9 (CD=1200 to 1400, & DVD=1200 to 1400).
  • Optics Lights not lit (Lens not light).
  2. Check the optics spull.
  3. Check the SP 3727 IC.
  4. Check the Amp transistor ( in IC SP 3727 socket board), Upper for CD & under for DVD.
  5. Check the IC 7805 (IC Regulator).
  • Excellent optics but won't to read.
  1. Check the mecanic gear.
  2. If you have SCPH - 3000 series, check the IC Driver (BA 5815).
  3. If you have SCPH - 5000 series, check the IC Driver (LA 6508).
  4. Check the ModChip.
  5. Check the IC SP 3727.
  6. Check the resistor (in 220 block), between IC Servo Master Control & IC Interface (CXD 9611 BR).
  7. Check the transistor (in socket optics= pin 6).
on Sep 16, 2010 | Sony PlayStation 2 (PS2) Console
Hello, I have the Jensen Media Pro 5000. System worked fine in October before winter storage in a building. Pulled the camper out to use in June and the system failed to turn on. There was a blue l
This is a common fault to almost all systems during winter. some of them even won't power up too. Contact any service technician. The internal wiring connection/s should be checked for proper contact with its sockets. http://electronicshelponline.blogspot.com/
Nov 14, 2014 | Jensen New Original MEDIA PRO 5000 Remote...
Wont turn on
open the remote and clean the keypads from dirty, dust, oxide, with c.cleaners.
2) retight the springs contacts cleaner with pliers for better contacts.
3)clean the contacts cleaner with c. cleaner.
If this do not resolve the problem go to the repair shop TV for fix it.
see the block d.
God bless you
Sep 06, 2012 | Jensen New Original MEDIA PRO 5000 Remote...
Error code of C-50 showing in my CS/PRO Copier
C-05 Error code occurs on fuser unite.
When it display open back cover and press reset button.
Machine ready.If are not fix this problem.May be change or replace thermostat or lamp fuse.
Apr 06, 2010 | Minolta EP4000/5000 CS/PRO Copier
I am looking to buy a 1200 watt jensen 2 channel amp. what model is this? is there a jensen 1200, i have not seem it.
I would recommend you purchase a brand name 600watt RMS amp instead of a Jensen 1200 watt peak amp. Trust me you will notice the difference. Try a kicker, hifonics, MTX, audiobahn Autotech... Its not the watts its the quality of the watts..
Sep 12, 2009 | Car Audio & Video
Wont turn on
check your fuses and all connections, make sure you have a good ground to the stereo and make sure the yellow and red positive wires are not loose!
Jul 19, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
I have a jensen media pro 5000 in my new camper and the dvd only played for 15 mins and now it doesn't turn any hints on how to fix
I had the same problem with the whole radio itself. It would play fine for about 2 mins and then it would quit and the blue backround would stay on the screen. I took it out of the wall and took the fuse out and put a new one in. It played fine for about 2 mins and then the same thing happened. The fuse was still good. Phoned the dealer and switched the radio. works fine now.
Mar 28, 2008 | Televison & Video
Mic has quit working on Quickcam Pro 5000
Did you by chance mute it in the computers sound manager or a specific program (msn, yahoo)? These settings tend to over-ride the Logitech console settings.
Nov 14, 2007 | Logitech QuickCam Pro 5000 Webcam
Car Audio & Video Logo
197 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
