Question about Vizio Televison & Video
Vizio tv doesn't turn on after outage. Measured power board: Fuse=0ohms,DC to main board are 5,12,12,24. Measured: 5,0,0,0 cable to main disconnected. Bad power board?
    Top Expert:
  • Vizio Master
  • 74,383 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on May 02, 2017
My vizio E370VLE is getting no power at all. The vizio logo under the screen isn't even lit up. I have tried plugging into new outlets and even switch out the power cord with a new one so i know its n
the problem is probably your main power board.. these can be replaced by yourself.. find the model no and then enquire about a replacement board ..I have had similar problem tv repairman wanted $500+ to fix board only cost $134..make sure to disconnect power supply ..undo all the screws around back of case including wall mount and base follow power lead entry into case do not touch any circuitry as some capacitors store power disconnect the little plugs that run from the boardundo the 4 screws and replace with purchased replacement board and re assemble..
Dec 20, 2014 | Vizio Televison & Video
After power outage Visio tv says no signal
The signal is not getting to tv. Try other source on same input. Also check cable. if still not working replace main board.
Apr 17, 2014 | Vizio Televison & Video
TV won't turn on
there is a surge protector on the main power board this has probably blown. or the main power board fuse or plug fuse. check them one by one. there even may be a secondary fuse in the tv around 3amp witch can blow. it will have red and black lines on it or orange that is the rating of the fuse. surge protector is like a battery shap round with 2 prongs onto the board.
Sep 20, 2013 | Panasonic VIERA Televison & Video
Getting 120 v to white plug where it first plugs into board should i have power reading at fuse?
yes after to the fuse you must have a reading of 120vac if none the fuse get busted. if the 120v is present then it will goes through the rectifier bridge diode and primary capacitor of the power supply board to have an stand by voltage at the power supply board. when you press the power button it will send signal voltage coming from the main board to turn on the power supply board. the you will need to get an output voltage at the power supply board of 5v dc, 12v-16vdc and 24v to turn on the all the circuit, the main board sound amplifier and the inverter board for screen back light.if you can get those supply the tv unit will not turn on.
Nov 09, 2012 | Vizio L37 Television
My vizio tv doesn't turn on
Check its power supply board. Replace it. Check the fuse.
Jun 08, 2012 | Vizio Televison & Video
The other day, my 2007 vizio 32" lcd tv lost picture, sound, and i was unable to turn the tv off via the on/off button on the tv. i had to unplug it to turn it off. i took it to the local tv repair shop. ...
Yes, it can be main board processor problem or it can be cuased by unstable DC power supply due to bad DC filrter caps, if the repair person verify that all the DC outputs from the power supply are OK, then it can be the main board. He need to have a spare board to try for sure. You can look at shopjimmy.com to see how much the boards are.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Oct 23, 2010 | Vizio VX32LHDTV10A 32 in. LCD HDTV
No power to tv after power outage
The power boards go bad alot in vizio's, Most likely 4 bad cap's need to be replaced, $10 in parts,,
Feb 12, 2010 | Vizio Televison & Video
My akai tv model lct3785ta will not turn on
Ok.. What is the status of the power LED at the front. Does it blink, change color a few seconds after its turned on? Do you notice any clicking noise from the set?
Please provide this info so that we can continue with the diagnosis.
Sai.
Jan 25, 2010 | Akai LCT3785TA 37 in. LCD HDTV
Televison & Video Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
