Question about Sanyo Televison & Video
Sanyo tv, dish system and suddenly the picture is too big for the screen (I am losing things written on the sides
    New Friend:
    Problem Solver:
  • 9 Answers
You should have add a picture setting on a remote. Wide panoramic Cinema xcetera find one that fits your TV
Posted on May 02, 2017
  • Susan Gower
    Susan Gower May 02, 2017
    Thank you....did a reset from my dish remote and fixed the problem
    Master:
  • 507 Answers
Buy a bigger TV?
Check your sat receiver display and TV display settings
  • 556 Answers
SOURCE: Sanyo 25" tv
blue clock set screen. is seen due to no signal as due to Accidently hit remote might have got defective or setting must have disturbed. refer owner's manual which you must have received during buying set. good luck
Posted on Sep 24, 2007
  • 5 Answers
SOURCE: big problem
Try replaceinf the Hard drive. Any SATA 2.5" Laptop HDD will work. Install it. And follow the setup. Takes about 15mins.
Posted on Mar 03, 2008
danromarris
  • 101 Answers
SOURCE: Tv has sound but no picture.
If it works on DVD but not on your Dish, and when you connected it to another house it had the same problem then it sounds like your input connection is bad on the TV. That is if I am understanding this right. From what I am reading your Dish network is not showing a picture but the audio is working fine. The DVD player works fine on the TV though. Then you took the TV and hooked it to another dish system and it was the same problem. That sounds to me like you TV is having a problem, either that or the cables for your Dish network are bad. Try switching to a different input, like the one the DVD player is on and seeing if it works there. If not, then the cables are bad and you just need to replace the cables. If it does work though where the DVD was working before then your TV input is bad on that port you were hooked to before.
Let me know if you have any other questions and if this was helpful. If you need some more clarification let me know, I hope this is helpful. Good luck and have a good weekend. Get it fixed before the Super Bowl.
Posted on Jan 25, 2009
SOURCE: New flatscreen Sanyo tv. Picture is to big for the screen
use the picture button to change the shape, Most likely you have it set to picture 3 which would cause that.
Posted on Jul 05, 2009
let me help
  • 196 Answers
SOURCE: Sanyo lcd32k30td tv has blue
switch it off for 10 seconds .. then press button TV/AV
its probably due to power fluctuation ..
if the problem occurs check for local warranty service or service center
Posted on Mar 29, 2011
Could our Dish remote control be causing our picture size problems? The ends of our picture are cut off. We've used the TV remote to change the size but all of those options are still too big.
the ends of the picture on most non hd will be cut off because they are made for the old tvs which don't have the same aspect ratio as the theatre screen shaped flatscreens.
Sep 01, 2015 | Sanyo DP55441 55 in. LCD HDTV
Get my dish reciever, sony home theatre, and 55in sanyo tv to work together
If your TV and sound system both have a Digital Optical Out/In you can use a TOSLink cable (an optical cable) to connect your TV directly to your sound system, and remove the connection between the DISH receiver and the sound system. As long as your sound system is on the right input, all sound accompanying the picture on screen will go to your sound system. Most TVs also have an option to turn off the internal speakers, if not just reduce your volume all the way down to avoid that weird ghost sound effect. If you use your sound system all the time for volume, you can program the sound system to your DISH remote's AUX, and even set the remote so that it only sends volume and mute commands to the sound system (that way you don't have to dance between sat, tv, and aux all day, just leave it in sat mode).
To program your remote to the sound system, follow the instructions on the sheet you got with the remote (yeah, right like anyone kept that) http://www.mydish.com/support/remotecodes you can use that link to program your remote. You can also use the learning mode if your remote has a little glossy square on the top left side and you have the original remote to the sound system. (Learning mode can be gleaned from the remote manual Remote Control Manuals)
After programming the aux device, and verifying that it changes the volume up, down, and mute, THEN:
Hold AUX until light blinks 3 times, hit pound (#), Volume Up, 0 (Zero), pound (#), SAT, then test to make sure it goes up and down.
Sep 24, 2014 | DISH Network Televison & Video
I have dish network 622 and 722 dvr receivers. this same issue happens on both receivers. when i put the picture in picture screens side by side, one is in widescreen with the black bars above and below...
Justin Warshowsky,
There is no way to change the format once PIP is in use. Try unplugging the receiver for 10 seconds and plugging it back in. I would also recommend making sure your formats on both TV's are set correctly.
If the problem persists, send me an email at thomas.faust@dish.com and I can look into submitted a report to our Operations team to check it out.
Tommy Faust
DISH Social Media Representative
Jun 27, 2012 | DISH Network ViP622 DVR DTV Receiver /...
Overscanning Issue
Hi, I am sorry you are having a problem with the video being zoomed in on your TV. If your DISH remote works the volume and power on the TV then try selecting the "*" (star) button under the number 7 on the remote. This is a format button that will reformat the TV picture and you can find the one that works best for you. If you have any additional questions or concerns, please email me. Thank you!
Mary Catherine Brady
DISH Internet Response Team
marycatherine.brady@dish.com
2:45pm-11:15pm (MST) Tuesday-Saturday
May 18, 2012 | Sanyo DP32647 32 in. LCD TV
I have the remote for my sanyo mts tv but i cant find out how to get it to switch to video mode so i can play games on it there is no button
There is button on your remote labeled TV/AV . Press the button to get a blank screen with AV written on the screen. If your game device is connected at the back to this AV socket ( Yellow / Red / White ) you will see the game menu display.
On some of the TV remotes it might not be written TV/AV but INPUT SOURCE or just a picture of a TV screen with an arrow pointing inwards ( that LOGO is the universal symbol for INPUT )
Apr 22, 2011 | Sanyo DS31590 31" TV
Once the TV is turned on, the sound and picture disappears and replaced by a blank screen. If one turns it off again and on imediately the picture and sound returns. This may happen several times in a row,...
Could be ethier one the dish box or the tv itself have cold solders joints on the FBT-Flyback transformer.That the big black block of plastic with a red wire with a black cap hook to the CRT-(tv tube).Call ur tv Dish box customer service,get a replacement box.See, if this will solved ur tv problems.If not,than the tv must be taken aparts and must have tools like a soldering iron,a roll of solders,also must know basic soldering.Resolders all the coldsolders joints on the FBT for a better High voltages contact to the CRT-(tv tube).This problems,will be solved.
Dec 03, 2010 | Philips Magnavox 27MS343S 27" TV
Sanyo CP29YS2B - Picture has zoomed in/enlarged
My Sanyo CP29YS2B - all of a sudden picture has changed - it now looks like it is in a zoom mode - large parts of the eterior of pictures and menu settings do not appear on screen. Using menu does not offer any solutions
Jul 13, 2010 | Sanyo 42 in. LCD TV
Screen showss double picture
Good Day, cs81801;
It sounds like the TV's Convergence Circuit has failed.First, try
to reset TV by unplugging TV from A/C source, for 2 to 5 minutes. Then plug TV back into outlet. Also, try the Magic Focus button on front of TV.
Still no work? To fix yourself call 1-800-458-6053 and ask for KIT 10. This will provide you with all the parts you will need. These are soldered in parts, or call an Authorized Service Center and have them give you a written estimate b4 repairs are performed. Cost? between $450 to 650 depending on your location and Service Center. Good Luck, big IRISH.
Sep 06, 2008 | Hitachi 53UWX10B 53" Rear Projection...
TV problem
can you describe what type of problem the picture was having before it went out/ Also need the model number of your set. Please respond to this same post so the previous info is available when You post the model number.
Jun 27, 2008 | Televison & Video
Sound but No Picture
Connect your outdoor antenna directly to your antenna in, in your TV see if it works and do the same with your cable input if it works then the A/B box is at fault.
Oct 28, 2007 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Televison & Video Logo
32 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
