Question about LG Televison & Video
Lg 32ls3400 no picture
Have audio no picture channels change video modes change
    Master:
  • 507 Answers
There are average three main boards inside; one of them has gone bad and a repair shop is needed.
Posted on May 02, 2017
Have a westinghouse lcd tv 50inch model ew50t5kw and would like to know before changing any parts or boards what causes a blue screen no sound or picture
  1. Frank: Verizon. com says try this: Change your VCR's Channel to 3 or 4. Most blue screen issues are caused by the VCR not being set to Channel 3 or 4. If changing the VCR's channel (using the channel buttons on the VCR or from the VCR remote control) did not change your TV screen, go to step 2.
  2. Make sure your TV is not in Video mode. There are three possible ways to change your TV's mode using your TV remote control: 1) Press a Mode button, toggle through the options and select TV, 2) Press a Video button to change your TV's mode from Video to TV or 3) Press Menu, locate Mode or Audio/Video setup and select TV from one of the options. If you are not sure how to change your TV's mode, see your TV's user guide for more information.
  3. Check to make sure your set-top box is plugged in and turned on.
  4. Check to see if other TVs (connected to different outlets) have a blue screen. If they do, contact the Verizon Fiber Solutions Center.
May 21, 2015 | Westinghouse Televison & Video
Lg-32LS3400 scrambled
re check the connection from the component input and tuner. then at the same time the system that you have using like NTSC or PAL, SECAM select the appropriate in your location.if still the same problem contact the supplier sine it was covered by warranty they checked the unit for free.
Sep 02, 2012 | LG 32LS3400 32" Class LED 720p HDTV
What channel or setting is used on the TV to play a DVD?
Hi, Channel 3 or 4 might work for older TVs. Most new HDTV's have a mode setting in the menu. (Video 1 or 2 or 3) or (Component 1 or 2). On your remote you may have DVD button. Try all these suggestions, 1 of these will work. You can play with the remote too. Good luck.
Jun 13, 2011 | LG 42LB2R 42 in. LCD HDTV
I have picture but no sound LG flatron TV and Pioneer DVD player.
connect audio output (RCA Jack white n red color) from the video, to the audio input of your TV. Make sure you use same AV channel for the video and audio.
i.e AV1 or AV2 or AV3
Apr 10, 2010 | LG Flatron MW-30LZ10 30" LCD Monitor
I have the lg lsc27990tt fridge with the tv in it i have hooked up the cable from my direct tv but cant get a picture i have it on catv ran it threw the channel set up but the catv goes from channel 15 to...
I have had this problem twice. I found that the tv only works if the refrigerator door is open. The first time I had the door replaced, and it worked for a while. Now it is broken again. They say it is the wiring harness in the refrigerator.
Jan 05, 2010 | LG Refrigerators
Can not see the Video when I input it, see only a blue screen.
ok hook up the audio video in the OUTPUT on vcr and INPUT on the tv then make sure tv is changed to the right input channel now go to vcr and change that channel to AV,.if AV isnt there you may have to go into menu of vcr and do a channel search,but when you change it to AV on vcr you should see the picture
May 27, 2009 | Televison & Video
Dvd hookup
  • First make sure the audio (red &black) and video (yellow) are plugged into their respective color matching inputs on the TV monitor.
  • Second either using the TV remote contol or TV's builtin control panel set the tuner mode to video. Depends on which TV's input terminal you connect the DVD player; that's where the Video mode has to be assigned.
  • For example: if you connect them to video1, set the tuner to video1. changing the channels up or down will never set it to video mode. You must press video button to change the tuner from regular channel mode to video mode.
Feb 16, 2008 | Televison & Video
My picture went dark but the audio is ok on Philips model 51pw9303
your tv needs to be taken to tech i is having problem in the video and related circuit.or power supply.good luck
Apr 03, 2007 | Philips 51PW9303 51" Rear Projection...
Televison & Video Logo
78 people viewed this question
Computer Repairing
Computer Repairing
