Question about Pool & Spa
My index portable hot tub wall bubbled out .Not sure if someone sat on it. Any idea how to get it back without emptying and starting over? Will it damage spa if I use it?
    Master:
  • 507 Answers
Bubbled out?
Possibly some of internal "stitching" the lines you see on the side were torn on the inside and the wall may be failing.
This is an inflatable spa?
Posted on May 02, 2017
I have just installed my intex portable hot tub but there seems to be a leak coming from the bottom.
That's unfortunate. Well, empty the hot tub, and then check the place thoroughly. Is it leaking from inside the outlet? Than check the plug in the outlet tube, if it fits correctly.
Detecting Leak in an Blow Up Hot Tub
Apr 01, 2017 | Pool & Spa
When the water has reached it's proper level, the hot water turns off, but the cold water keeps filling until the water overflows the basket
Try this. With the wash tub empty, start to fill with water. Without turning washer off, unplug the washer from wall.
If water filling stops (hot and cold), then you are looking at a bad timer assembly. Replacement isn't that hard, parts can be difficult to find though.
If water continues to fill, your valve body / solenoid assembly is likely full of lime-scale. Easily replaced.
Jan 04, 2010 | GE WVSR1060A Top Load Washer
Sewer gas smell every time the tub is emptyed
If you are getting a gas smell when the tub is emptied it is because you either do not have a big enough vent pipe or your vent pipe is plugged.
I have seen cases where a vent pipe has sagged enough to trap condensate and rain water and plug that way. Find what is the actual cause can be difficult and time comsuming. Often times the cause is hidden over a ceiling or behins a wall.
I have fixed them already but installing a "cheater vent" or "Studor" vent under a vanity cabinet that is close to the tub. These vents are just a one way valve that will let air into the line but not back out.
Your problem is because when the water goes down it replaces some air with water volume. That air comes bubbles back up the piping and creates a smell.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 07, 2009 | American Standard Cambridge 5' Americast...
Cleaning solution will not dispense
After sitting for a period of time, some of the solution may have dried in the inner walls of the feed tube from the solution tank. What I would suggest is to empty the solution tank and then fill it with hot tap water, put it back on the Floormate, and hold the solution "feed lever" on until it starts dripping water. The hot water will hopefully disolve the dried solution and allow it to flow again.
I hope this helps! :)
Sep 22, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Water not heating
It sounds like your inline heater has stopped working. The only way to test it is to drain the water back out, remove the inline heater, and hook power to it to see if it heats up.
If it doesn't you can get one at a discount supply house (like Home Depot or Lowes) for less than $150.
May 28, 2009 | Home
QCA Opal hot tub display reading OH.
The tub experienced an overheat situation. This may be due to leaving the t stat turned all the way up and not monitoring or the hi-limit sensor is defective. The hi-limit sensor will shut down the heating cicuit if temp gets above 105 D optimally.the fact that the heater light is on is a good sign that things are working at this point.Whether or not a suitable temp(100-103 D) will be arrived at is to be seen. If spa heat kicks off before set temp is reached then replace hi-limit sensor.
Apr 10, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
LG TROM STEAM WASHER-WM2487 HRM
You are probably using too much soap and softner. You only need about 1 Tablespoon of each for a full load with a front load machine. Run it with nothing it in except bleach. If you see bubbles inside that means there's left over soap in the tub. Keep running it empty (with bleach) until you don't see bubbles anymore then start using less soap and softner.
Jul 31, 2008 | LG WD-14124RD Front Load Washer / Dryer
After cycles complete, some soap still left in machine.
try wash it empty add no soap.. at the end of the wash cycle before it goes into spin open the lid and see if you have soap bubbles.. if you do have have a build up of soap and are using to much or the wrong soap for you area... let me know what you find out...
Aug 27, 2007 | Frigidaire GLWS1233A Top Load Washer
Pool & Spa Logo
37 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
