Question about Garden
My GX126s overheats dealer can not find problem tractor is 2years old and it has done it since new please help
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
I had an issue many years ago , not on a tractor but may still apply. I bought a water pump for my car. Car still overheated. Turns out the water pump had an obstruction in it. Just maybe your factory waterpump is defective.
Posted on May 02, 2017
What can be causing 2015 GX126S kubota tractor to overheat it has done this since new and dealer is unable to fix it
Contact Kubota support. Also, seek advice from some of the authorized Kubota dealers listed on their site. Low coolant, faulty thermostat or plugged radiator is suspect.
May 02, 2017 | Kubota Garden
My friend has a eastern steel generator 2years old an has not been started I have done every thing I could think of any ideas thanks John
if it has sat for 2 yrs with gas in it, it will need to be cleaned.
varnish builds up and blocks jets and filters
Dec 09, 2014 | Eastern Steel Electrical Supplies
2001 VW Golf TDI ,overheats,spent over $2000 instaled new radiator,water pump,timing belt kit after VW dealer at Ontario,CA diagnosed problem.Car still overheats,but I used other repair shop to replace...
Fact is, for a 2001 car, taking it to a dealer is just asking for trouble-they saw you coming, and too advantage of it. You might consult with an attorney, but the fact of the matter is you decided to allow them to 'diagnose' it and then took it to another facility for repair. That it took them 4 hours to incorrectly diagnose says it all-unless a car is under warranty, taking a vehicle to a dealer is a huge waste of money.
Get a compression test done-it might reveal a blown head gasket or worse, damage to the mating surfaces of the engine and head(s)-I think the repair facility who actually did the repairs bought into the bad diagnosis, so appeal to their professionalism-have them do the compression test and a pressure test to the cooling system to determine the extent of the damage. Finally, your car is 10 years old-the dealer should have done right by you, but more often than not, the abuse people who drive older cars because of the years of attachment and the possibility of a huge bill.
Sep 23, 2011 | 2001 Volkswagen Golf
My craftsman lawn tractor seemed to overheat and struggle with hesitation. I replaced the spark plugs, cleaned the filter and added oil, however, it still seeems a little sluggish with hesitation. Do you...
Check the oil, if it is a milky color then it has water in it and will cause it to over heat. Also smell it for gas that will also cause it to over heat. Has any other work been done recently?
Aug 19, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Boiler fires up for 15 secs and then drops off. pcb has been changed twice, heat exchanger changed rads flushed. boiler is 2years old
Check that the overheat thermostat is working [i.e. the wires are connected] - If in doubt connect the terminals together to bypass.
Check that the air extractor fan is working and that the coaxial pipes have no gaps.
Check the air sensor plastic tubes to the fan are connected and intact
Check the central heating valves below the boiler and not turned off
Mar 13, 2010 | Long Life Water Heaters
Sharp lc-26dv12u about 2years old. All of a sudden
Sounds like the Main mother board is the problem. When the processor chip overheats, the programming information passing through the chip slows down. Most cases, replacing the main mother board will fix the problem.
Dec 29, 2009 | Sharp LC-26DV12U 26 in. LCD TV/DVD Combo
Why would a 2005 SSR overheat, normal maintenance is done?
First coolant full ? Next are the electric cooling fans between the radiator and the engine operating ?. Independent show be able to determine. If not a Chevy dealer is in your future. .Hope this helps
Apr 13, 2009 | 2005 Chevrolet SSR
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
