Question about Pool & Spa
Side wall bubbled out
Everything was fine then part of wall bubbled out. I checked pressure and it is on low side of green. Somebody might have sat on it. Any ideas how to fix without emptying spa?
2 Suggested Answers
yobo007
  • 507 Answers
SOURCE: My index portable hot tub wall bubbled out .Not sure if someone sat on it. Any idea how to get it back without emptying and starting over? Will it damage spa if I use it?
Bubbled out?
Possibly some of internal "stitching" the lines you see on the side were torn on the inside and the wall may be failing.
This is an inflatable spa?
Posted on May 02, 2017
Bubbled out?
May 02, 2017 | Pool & Spa
Tip
How To Charge Your Vehicle's Air Conditioner
You will need a charging hose with a gauge, and a can or three of R134a refrigerant. Wear eye protection and handle with care.
  1. To begin, you need to adjust the ambient temperature arrow on the gauge to the approximate temperature of the air outside, if possible with your gauge.
  2. Turn on the vehicle, and turn the A/C to high.
  3. Attach the blue charging hose to the low-pressure line, or the bigger of the two metal hoses.
  4. Once attached, check the gauge. If the indicator is in the green area, your system is fine. If it is below the green area, screw on a can of refrigerant and charge the system until the gauge reads in the green.
Steps that a tech will do if you take your car to a shop:
• A temperature sensor is inserted into the AC vent and the system's efficiency is tested.
• The high-pressure side of the system is connected to the recycling-recharging testing machine, then the low-pressure side.
• The machine reclaims and stores the refrigerant. The system is then run under a vacuum for 30 minutes to test for leaks. This process also removes accumulated moisture.
• If all is well, the refrigerant is reintroduced into the system, and topped off as required.
• The sight glass on the evaporator is literally a window into the AC system. If the window is not clear, or bubbles are visible, this can indicate system trouble.
on Jul 12, 2010 | Heating & Cooling
My boiler is making a whirling noise after I topped up low pressure. Heating and hot water are fine.
You have air in the pump-you need to keep input pressure up and open drain on output side of pump until no bubbles come out-cheers Denny
Oct 13, 2013 | Heating & Cooling
1997 A/C has high pressure on the gage is the drier failed or maybe something else
Check for bubbles at the sight glass. Bubbles indicate that the system needs additional coolant. You are prob checking at the high pressure side; add coolant at the low pressure side of the system while the engine is running until the bubbles in the sight glass disappear.
Aug 05, 2013 | Computers & Internet
High low side pressures and sight glass contains lots of bubbles
The system has a lot of air in it. If u haven't had any AC wk done on it that mean there is a leak in the system. System must be evacuated, pressurized & find the leak. Repair the leak, vacuum air from system & charge w proper AC gas. SPECIALIZED EQUIPTMENT & GAUGES NEEDED. good luck
Jul 28, 2017 | Cars & Trucks
Is the low pressure side of 92 F-150 on the condenser or near the compressor.
LOW PRESSURE SIDE IS THE SUCTION CHARGE SIDE WILL BE FROM AC COMPRESSOR REFRIGERANT LINE TO THE ACCUMULATOR OR DRIER TO THE EVAPORATOR IN THE FIRE WALL THE AC COMPRESSOR LINE TO THE CONDENSOR IS THE HIGH PRESSURE SIDE YOUR DISCHARGE SIDE. DONT DONT TRY CHARGING AC SYSTEM AT THE HIGH PRESSURE SIDE. CHARGE AT THE LOW PRESSURE SIDE.
Aug 18, 2011 | Ford F-150 Cars & Trucks
Why does the whole car wobbles from side to side.
could be a broken belt in tire or sway bar could be bad, or your tie rod or ball joints
Jan 24, 2011 | 1999 Chrysler 300M
Low pump pressure
Or blocked.
Have you used pool 'O' ring grease on all 'O'rings - tipped water from bucket on all pipe joins on suction side to see if blows bubbles?
Jul 12, 2009 | Hayward 1.5 Hp Northstar High Performance...
My 2004 ES330 A/C isn't cooling enough. I took it to a technician for checkup and he said everything is fine and there are no leaks, what might be the problem? if it needs recharge, what kind of...
R134 freon.
you need to put manifold gauges on the system to check pressures.if it is full of freon the low side should be around 30 psi and high side should be around 175 psi. if pressures are ok or alittle low on the low side you need to check exspantion valve. common with the es300's
Jun 07, 2009 | 2004 Lexus ES 330
Pool & Spa Logo
35 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
