Question about Garden
Home lite 370v blower vac - Garden
How to adjust a home lite mighty lite blower vac carburator "?"
Hi. This link,
is to the homelite page where the manuals are, however, there are 4 different models of the handheld blower you have. Either way, if this is a really new model, there may be no way to adjust the carburetor, as due to emissions standards, there may not even be any idle screws, but if they do exist, the head ma be whats called "pacman", as it looks like a little....yeah...pacman.
Apr 25, 2014 | Homelite Mighty Lite Blowervac
I do not know the oil-to-gas ratio to mix/buy. My husband passed away, and I cannot find the manual. Help, please. THANK YOU
Can you find the model number on the Homelite Mighty Lite BlowerVac?
For the UT08520 and UT08921 26cc blowers and the UT08550 and UT08951 blower vacs, you can mix the Homelite Premium Exact Lubricant with gasoline following the label directions. For other synthetic oil additives, use 2.6 oz of additive per 1 gallon of gasoline. (It's 20ml to 1 l if you use the metric system.) That's a 50:1 ratio (gasoline to additive).
Many Homelite Blower manuals are available here: . You should try to find your exact model and then check the manual to confirm that your model blower vac uses this same ratio of oil to gasoline. You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Sep 06, 2013 | Homelite Mighty Lite Blowervac
How do I switch between vac to blow?
The long thin tube is for blow and the larger dia. tube is for vac. and usually mounts at the fan area on bottom of your machine. Do you still have your instruction book or the local home center where you purchased it, will answer this question and give direction. Good Luck...
Oct 25, 2012 | Black & Decker Leaf Hog Blower Bv4000
I just need a manual for the Homelite Mighty Lite Gas Powered Blower Vac.
Do you have your model number?
You should be able to find your manual on this site:
The manuals are listed by their model number rather than their marketing name. Look for the serial number plate which should also have the model number.
Thank you for using FixYa!
Aug 26, 2011 | Homelite Mighty Lite Blowervac
I need to know the correct ratio of fuel mix for homelite blower/vac
It is 50:1. That is 2.6 Ounces 2 stroke oil/ US Gallon or 1.3 ounces of oil / 1/2 US Gallon. I recommend synthetic and adding Stabil brand gas stabilizer to the mix. It helps greatly.
Dec 03, 2010 | Homelite Mighty Lite Blowervac
I have a UT08580 Mighty Lite backpacker blower with a missing spark plug, I need to know what plug goes in it.
The Homelite part number for this spark plug is 870174001. This number crosses to Champion spark plug RCJ6Y which can be bought at any Home Depot, Lowes, Ace Hardware, etc for about $3
Oct 20, 2009 | Homelite Consumer Products Backpack...
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
