Do not know My id or password - Computers & Internet
How can I reset password for my Apple ID to get into ITunes?
Recover or Reset Forgotten Apple ID or Password on iPhone & iPad
This is all done on an iOS device and is often the simplest way to log back into an Apple account:
  1. Open the Settings app and scroll down and tap on "iCloud"
  2. Tap on the email address at the very top of the iCloud settings screen
  3. Tap on the blue text underneath the password entry that says "Forgot Apple ID or Password?" where you'll have two choices:
    • If you know your Apple ID and don't remember the password, type in your email address and click "Next" to start the reset process
    • If you don't know your Apple ID, tap on "Forgot your Apple ID?" and fill out your full name and email address to recover the Apple ID login (yes, you can then do the password reset after you have the Apple ID)
  4. Answer the security questions pertaining to that Apple ID, and follow the onscreen directions to complete the process
At this point you should be good to go, you can reset the password for the account and then login as usual.
Feb 15, 2016 | Apple iPad 32 GB WiFi Tablet PC
Login my itunes account
Nowadays, I believe that all users must actually have an AppleID to use iTunes, which is different than a password for iTunes. In other words, I used to sign into iTunes using my iTunes user name and password, but somewhere along the way, I was required to acquire an AppleID instead. An Apple ID is your user name for everything you do with Apple: Shop the iTunes Store, enable iCloud on all your devices, buy from the Apple Online Store, make a reservation at an Apple Retail Store, access the Apple Support website, and more.
I cannot tell by your question if you already have an AppleID and forgot the password for that account, or if you're trying to use your old iTunes account and forgot that password. If it's the latter, I don't think your old iTunes user name and password would work anyway. But I could be wrong.
If it's the former, here are the instructions for resetting your AppleID password (copied and pasted, obviously!):
If you forgot your Apple ID password Can't remember your Apple ID password? Try resetting the password.If you forget your Apple ID password or don't know it, choose from the following options to reset your password. After resetting your password, you'll be asked to sign in with your new password when you or your device accesses an Apple feature or service that uses Apple ID. If you know the answers to your security questions
  1. Go to My Apple ID (appleid.apple.com).
  2. Select "Reset your password."
  3. Enter your Apple ID, then select Next.
  4. Select "Answer security questions" as your authentication method. Select Next.
  5. Select the birth date associated with your Apple ID, then select Next to begin answering your security questions.
  6. After answering your security questions, you'll be asked to enter and confirm your new password. Select Reset Password when done.
If these steps didn't help you to reset your password, contact Apple Support.
If you have access to the email addresses associated with your Apple ID
  4. Select "Email authentication" as your authentication method. Select Next.
  5. Apple will send a password-reset email to the primary address or verified rescue address associated with your Apple ID. Didn't receive the email?
  6. Open the message and select the link to reset your password.
  7. When the My Apple ID page opens, enter and confirm your new password, then select Reset Password.
If I missed the mark on your question, let me know, and I'll try to help some more.
Aug 05, 2014 | Apple iPhone Cell Phones
Retrieve ID/Password for my computer
please log in as administrator and try to install software and let me know if works
Feb 16, 2014 | Apple MacBook Pro Laptop Computer with...
Change apple id password
Changing your password for your Apple ID if you know it is easy:
Follow these steps to change your Apple ID password.
  2. Click "Manage your Apple ID" and sign in.
  3. If you have two-step verification turned on, you'll be asked to send a verification code to the trusted device associated with your Apple ID. If you're unable to receive messages at your trusted device, follow the guidelines for what to do if you can't sign in with two-step verification.
  4. Click "Password and Security".
  5. In the "Choose a new password" section, click Change Password.
  6. Enter your old password, then enter a new password and confirm the new password. Click Save when done.
The next time you use an Apple feature or service that uses Apple ID, you'll be asked to sign in with your new Apple ID password.
If you don't know what your password is currently, you'll need to know which situation applies to you:
  2. Click "Reset your password."
  3. Enter your Apple ID and click Next.
  4. Select "Answer security questions" as your authentication method. Click Next.
  5. Select the birth date associated with your Apple ID, then click Next to begin answering your security questions.
  6. After answering your security questions, you will be asked to enter and confirm your new password. Click Reset Password when done.
  4. Select "Email authentication" as your authentication method. Click Next.
  5. Apple will send a message to the primary email address or verified rescue email address associated with your Apple ID. Open the message and click "Reset Apple ID password".
  6. When the My Apple ID page opens, enter and confirm your new password, then click Reset Password.
  4. Verify your identity: Enter the Recovery Key you were provided when setting up two-step verification, then choose a trusted device that will receive the verification code from Apple.
  5. After entering the verification code, create your new password and click Reset Password.
If you don't have your Recovery Key or are unable to receive messages at your trusted device, follow the instructions for what to do if you can't sign in with two-step verification.
If you don't have access to the email on file and/or don't know your security answers and/or don't have the device or code associated with two-step verification, please call AppleCare at 800-692-7753.
You will need to verify your identity using two separate pieces of information which will vary depending on your account, but after verifying your identity you will be able to have a password reset email sent to you within 24 hours.
Jan 24, 2014 | Computers & Internet
Apple id password reset
Hi I have my old iPhone 4s I wanna start using it again but I have 4got my Apple ID and password! Can I delete that can make a new one up! But befor I do that! I need to know my old Apple ID and password to get the phone going
Dec 06, 2013 | Apple iPhone Cell Phones
Lost my password to yahoo messanger
Your Yahoo! Messenger password is usually the same as the password for your Yahoo! account.
(1) If you know your Yahoo! account ID and password, just enter that in Yahoo! Messenger. On the Messenger screen, clear the boxes for ID and password, then re-enter your Yahoo ID and password, then click "Sign on".
(2) If you don't know your Yahoo! account password, you will need to reset it.
Go to the Yahoo password page:
https://edit.yahoo.com/forgotroot/
and follow the prompts. Yahoo will send an email to reset your password.
After you have reset the password, then enter the new password in Yahoo! Messenger, and sign in.
See also these Yahoo! help page:
http://help.yahoo.com/kb/index?page=content&y=PROD_ACCT&locale=en_US&id=SLN2047
http://help.yahoo.com/kb/index?page=content&y=PROD_MSNG&locale=en_US&id=SLN1406
http://help.yahoo.com/kb/index?locale=en_US&y=PROD_MSNG&page=content&id=SLN1423
Dec 27, 2011 | Yahoo Mail
How you find the wireless network key? I have the put ip address in web bar but it asks for username and password which I do not know?
If it is _your_ wireless router, try:
* ID: blank Password: blank
* ID: blank Password: admin
* ID: admin Password: blank
* ID: admin Password: admin
Otherwise, take a Norwegian paper-clip, straighten one end,
and insert it into the small hole in the back of the router,
to reset the router to "factory" settings, including ID/Password.
Dec 26, 2009 | Zoom (5590-00-03) Wireless Router (G66115)
Password
Go to www.yahoomail.com Then go to -> Forget your id or password immediately below password text box. Enter your yahoo id in Yahoo!ID. Enter further information and follow instructions. Enter new password. And login to your email id.
Sep 27, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
David Payne
David Payne
