When i plug my speakers into my amplifier i get a loud buzzing sound
  • Audio Player... Master
  • 5,056 Answers
The first thing to do is replace the big Electrolytic Capacitors in it's power supply. If that does not cure it then you might have to replace the main power amp, especially if it is a single IC amp. In fact if it is one of them replace it before you fit new capacitors.
Posted on May 06, 2017
  • 319 Answers
SOURCE: Rotel RMB-1095 Power Amplifier Problem
Sounds like wiring problems. Unhook everything, then get owners manual for proper instruction
Posted on Apr 17, 2008
jerryg50
  • 1667 Answers
SOURCE: Loud Buzzing Sound
This may be a power supply failure, and or a short in the output stage, and in the drivers for the output stage.
This is not a repair you can do at home unless you have a lot of experience in troubshooting and analysing problems in power amplifier equipment.
Jerry G.
Posted on May 04, 2008
colliewob
  • 778 Answers
SOURCE: Speakers Make a Very Loud Noise that Increases
try uninstalling drivers and reinstall them.
also remove latest M.S update as some update cause more trouble than they are worth
Posted on Jul 17, 2008
redhead7377
  • 51 Answers
SOURCE: buzzing sound coming from speakers
You maybe be able to turn the internal speakers off through the tv's menu...either in the Audio section or in Settings
Posted on Sep 09, 2008
  • 5 Answers
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Posted on Dec 16, 2008
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Loud buzzing sound
Amp is shot. Will need to be replaced. Not an uncommon complaint on this model.
Dec 02, 2013 | Mirage OMNI S8 Speaker
Loud buzzing noise.
If you pull out the "input" cables and the noise stops, you have a problem with the "ground" and you have to check if there isn't a loose contact inside the plugs. If it doesn't stop, your amplifier is the problem and that mostly is a bad contact on the board in the pre-amplifier area.
May 05, 2013 | Definitive PF 15TL+ Subwoofer Speaker
Buzzing sound car stereo
A lound buzzing sound is an indication that the Driver (transistor) for the amplifier final is bad. This is not so much a buzzing and it is extreme in loundness.
May 05, 2013 | Chrysler concorde amplifier. radio. ....
Constant buzzing in my 15 W amplifier
Make sure you have a ground prong on your power cord. Most input jacks nowadays are closed circuit. They have a switch built in that won't allow any sound without the cord plugged in. You may have a damaged jack that will give you a loud hiss, a loud hum or crackling depending on what volume your controls are set at.
Aug 27, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
My azur 540a/640a v2.0 amplifier is not working.
Loud buzzing normally means dc on output or through your spaeker,amplifier needs to be serviced as it is faulty
Dec 25, 2008 | Cambridge Audio Azur 540A Amplifier
Help with my power amplifier
This sounds like there is a problem with the final output stage. Is this a new amp? Is it under warranty?
Dan
Oct 08, 2008 | Rotel RMB-1095 Power Amplifier
Loud Buzzing Sound
Jerry G.
May 04, 2008 | Onkyo TX-SR875 Receiver
Apr 13, 2008 | Rotel RMB-1095 Power Amplifier
speaker amplifier chip may leaky or damage
you are using improper sound driver
check driver status in your computer device manager or just typing dxdiag on run in start menu, check status of sound driver installation
Jan 15, 2008 | Harman Kardon HK19.5 Computer Speakers
 Grubhead
Grubhead
