Reset clx 3305 - Office Equipment & Supplies
How do you reset chip for transfer belt Samsung 3300
Reset counter in service Tech Mode:
[Menu] [Back] [Left] [Right] [OK] [Stop] [Menu]
Data Setup - Clear Count (enter password - 1934) - Transfer Belt
Reset toner count you can here:
Nov 25, 2015 | Samsung Office Equipment & Supplies
DoIneed o replace all 4 my tner cartrdges
Hi... No, you don't have to. Use the control panel or driver software to check the levels of each cartridge. Then only replace the one that is empty.
Here is Printer Management software that can help you to get the status and ink levels of your printer:
Here is a link to the user manual for you:
And the link to the home page of your device if that can help: CLX 3305W SAMSUNG Hong Kong
Hope this helps...
Feb 01, 2015 | Samsung CLX 3305
The lcd often shows a series of black squares across the top line.
if your printer still prints its very good. Pl. replace the OPE panel to overcome.
Aug 19, 2014 | Samsung Clx-3305 Colour Laser...
It says replace a waste toner
The waste toner box is full.You have to replace it now.Replace the waste toner box with the new one or empty the waste toner box and fix it again.Your problem will be solved!
Apr 09, 2014 | Samsung CLX 3305 - multifunction fax /...
Copy/scaining problem
because there may be no page (or no page detected) in those 2 dark inches.
Feb 17, 2014 | Samsung CLX 3305 - multifunction fax /...
C406 connection problem
Yes Go To Googl Pl*** store download updated driver i would recommend going to printer and Setting But my briain Does not search for that printer is it discontinued? all i see is cartridges (i Nead more info)that is a toner # ) Printers Fr That Toner Is )CLP-360, CLP-365, CLP-365W, CLX-3300, CLX-3305, CLX-3305FN, CLX-3305FW, CLX-3305W; Xpress: C410FW, C410W, hope it helps Donald Deane MCSE,ASE,CPO
Jul 26, 2017 | Samsung Computers & Internet
How can I replace waste tonertank? (CLX 3305FN)
Hi, the waste toner tank is located on the left side when you open the front door. Just add some soap detergent and run under the tap water. You will able to use again after drying.
Dec 14, 2013 | Samsung CLX 3305 - multifunction fax /...
