Question about RCA Televison & Video
The power went out and my tv went off. Now it wont turn on manually or with remote. Is there a reset button?
It is an RCA 46LA45RQ model
    Top Expert:
  • RCA Master
  • 40,262 Answers
There may be an open internal fuse or power supply failure.
Posted on May 02, 2017
We have a 46la45rq RCA TV. The input button on the remote bring up the options but it continuously scrolls. The side buttons do not work either (no signal) Do you think it is the t-con board?
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. [open and clean] [open and clean]
Mar 19, 2016 | RCA 46 46LA45RQ LCD TV
I have a RCA LCD TV and the power button and volume bottons don't work on the tv. Which board do I need to replace? Model number is 46LA45RQ
If these functions can be done by using its remote control, and only the front panel buttons are inactive, microswtches at the front panel board should be replaced. If functions are not available with a remote control too, the main board is faulty. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Nov 04, 2015 | RCA Televison & Video
I have a RCA 46LA45RQ with blue csreen and no sound, no controls.
unplug the tv then wait 5 minutes before replugging it again....should reset the digital control system. Otherwise, take it into a repair shop.
Jul 14, 2015 | RCA Televison & Video
46LA45RQ side buttons dead.
Contact any service technician. Your TV need a through check-up. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Jan 16, 2015 | RCA 46LA45RQ 46 Class LCD HDTV - 1080p,...
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
Codes to make Sony universal remote rm-vz320 control my RCA 46LA45RQ
For mine the rca listed code 00178 almost worked (no movement during input or menu)
Code search found 01265 which works all the buttons I use.
Dec 05, 2012 | Sony RM-VZ320 Remote Control
My RCA 46la45rq tv remote AND side buttons stopped working
The panel control circuit inside should be checked. Contact any experienced service technician.
Nov 27, 2012 | RCA 46 46LA45RQ LCD TV
What are the directv remote code?
These ate the codes: 11447, 10047, 10019, 10679, 11247, 11547,
10090, 11147, 11047, 11347
Jul 04, 2012 | RCA 46 46LA45RQ LCD TV
RCA TruFlat 27F520T 27" TV Reset
Buy a new remote.
Look around the tv and find the menu button.
Generally there is a separate power button.
You can also download the manual:
Dec 02, 2017 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
