Question about Cuisinart Blenders
Iam using my cuisinart cat 2000 to make almond & cashew butter. It keeps turning off (overheating). Iam following the instructions included with my blender including adding the oil.
    Top Expert:
  • Cuisinart Master
  • 45,018 Answers
Your Cuisinart may simply be inadequately designed for the task.
Posted on May 02, 2017
PHONE # OF PARTS DEPARTMENT OF CUISINART.I HAVE A CUISINART BLENDER SR#70604 MODELE SB5600
Is this regarding the 4 rivet blade recall as that is a different kettle of squirrels.
Parts & Accessories - Cuisinart.com
https://www.cuisinart.com/parts/
  1. Cached
Cuisinart Parts for Kitchen Products. ... Water Filters- Fits all Cuisinart water filter holders. Keep your water filter current so you can make pot after pot of delicious ...
Contact Us - United States - Cuisinart.com
https://www.cuisinart.com/support/us/
  1. Cached
To best serve you, our Cuisinart Representatives are available to answer your calls between the hours ... Cuisinart® Customer Service ... Marketing Department:
PARTS DEPARTMENT OF CUISINART Google Search
Dec 29, 2016 | Cuisinart Blenders
Why does water leak out when filled passed the top of blade
About 11,000 results (0.81 seconds) Search Results
    [PDF]Instruction Booklet Premier™ 11-Cup Series - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-2011.pdf
    Cuisinart11 cups (total processed weight varies by food) ... PowerPrep® metal dough blade, metal ... bowl at the top with ... filled out. WHEN. REMOVING BLADE: CAREFULLY REMOVE. THE METAL BLADE BY .... (If machine does not ... not put base in water or... These features, plus the .... have passed into the ... food from leaking.
    [PDF]Download Manual - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-10s.pdf
    Cuisinartmatching outline O on top of .... base in water or other liquid. General ... does not fit fully in the outlet, ... as you would sharp knives, out of ... 11. KNEADING YEAST DOUGH WITH DOUGH BLADE. 12. KNEADING BREAD DOUGH ... loodfrom leaking...... uid onto dough as it passes under ..... Fill the feed tube wilh the pieces,.
    [PDF]Food Processor - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-xp.pdf
    Cuisinart
Feb 08, 2016 | Cuisinart Prep 11 Plus Dlc2011chb Food...
Can I upgrade motor on vitamix 4500...it wont make almond butter...
Contact Vitamix, find a service agent through them and have it looked at. You are only going to be able to get your motor (if you need one) through someone associated with Vitamix anyway.
Aug 27, 2012 | Vitamix Turbo Blend 4500 - Heavy Duty Vita...
Manual is destroyed. Need new copy for Cuisinart PowerBlend Blender/Food Processor
The Instruction Booklet for your Cuisinart BFP-703 SmartPower Work Top Blender can be found here:
http://www.cuisinart.ca/pdf/ibs/en/BFP-703CHC_en.pdf
Thank you for using FixYa!
Jul 30, 2011 | Cuisinart BFP-703 SmartPower Work Top...
The blender stops working after a few minutes while I am in the process of making peanut butter. Why is it overheating so rapidly
it could be the consistancy of what your processing heavyer food will overheat it quicker then less dense foods.
Dec 21, 2009 | Vitamix Super 5000 Work Top Blender
Cuisinart Quick Prep is not working properly
I think the ice was too hard for a hand blender. I think the impact has caused the blade to separate from the shaft or caused the shaft to separate internally. If your blender is still under warranty you might be able to get it fixed. Note: none of the "Smoothy" recipes in the manual call for ice. One uses ice-cream. One uses "partially thawed frozen strawberries" and one uses sherbet.
Oct 11, 2009 | Cuisinart CSB-33 Quick Prep Handheld...
The lights on my cuisinart blender come on but the motor just stopped working
Using your blade holder, turn the motor from the blade end. 1 or two turns. Tak the blade holder out, Plug in an test Sometimes the brushes in the mototor lose a good contact. SGood Luck -Ned-
Sep 19, 2009 | Cuisinart SPB-6 Smartpower 6 Speed Blender
Cuisinart BFP-703CH Chrome Blender does not start
I had the exact same problem with my Cuisinart bfp-703ch blender. When I plug it in, the lights come on but the motor wouldn't run. After reading some posts I almost decided to throw it away. But my brain started to itch and I gave it a shot anyway. I eventually found the problem to be with the Thermal fuse. If you overload/overheat the blender, this fuse is going to blow off.
To replace it, I opened the bottom panel and followed the wires that come from the circuit. Once of those wires eventually will lead to the thermal fuse. It may help you if you unscrew the circuit board. Then I detached the fuse with pliers, got a replacement thermal fuse from Radioshack and connected it back on. I also had to solder it to make sure the connection is more robust. And Voila!!! my motor started working again.
Apr 15, 2009 | Cuisinart BFP-703CH Chrome Blender
Cuisinart DFP-14 Series does not start
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor plugged in and turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. For the DFP-14, remember: handle faces front, feed tube faces back, and metal element on back of pusher faces back of processor. Connect the pieces separately - if you try to put the work bowl on with the lid and pusher already attached, it will not always lock properly. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Nov 17, 2008 | Blenders
Blenders Logo
245 people viewed this question
Top Cuisinart Blenders Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
eyecam
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
