Question about Refrigerators
Age of my refrigerator - Refrigerators
How do I remove drain pan on Viking VCSB483 refrigerator freezer? It slides out almost all the way, but gets stuck on the right hand side and won't come out.
you have to remove the float that hangs from ceiling on rh side (depending on age)
also if your tray has foil heater under it this has to be removed first (depending on age and service history)
Mar 14, 2016 | Viking VCSB483 Side by Side Refrigerator
Refrigerator leaking
this means that when the refrig goes into defrost depending on the age either the hole for the water to drain out after defrosting cycle is plugged and needs to be thawed out and blown out with compressed air of if the water drains out under the crisper droor or behind the crispers the drain is plugged there. it could also be a drain heater problem. dont know age of refrig.
May 26, 2012 | Hotpoint Refrigerators
I have a Whirlpool Refrigerator Model # ET14JKXMNRO, Serial # S41313418. Can you tell me the age of this Refrig? Thanks much, GW Allen
Using Whirlpools Age Finder I found your Serial Number to come up with these Results.
If hard to see click on photo to enlarge, I hope that was helpful, Thanks Sea Breeze
May 04, 2011 | Refrigerators
Hello. I have a Frigidaire Gallery refrigerator. model is FRT22RGCW7 (which i can't find on this website). it was made in May '98. the refrigerator portion recently got exremely cold. freezer...
I used your model # and it came up on frig web sight . but they do not give age to these # only parts info . the age would only be avlb to dealers . i know this didn't ans your question but that info is not avilb. .. sorry mm
Oct 16, 2010 | Frigidaire Gallery SeriesĀ® GLHT188WH Top...
I have an old admiral refrigerator. I need to find the approximate age of it. Is there anyway you can help?
Hello and Welcome to FixYa!
Actually no one can suggest the approximate age of an electrical component. It all depends on the use and the environment in which it is operating/working. Usually most refrigerators works fine for at least 10 years if used carefully... But this age can be extended or reduced depending upon care.
Hope this helps you understanding the scenario,
Have a Nice day,
Please Do Rate the solution, as a token of appreciation,
Concerned.
Aug 11, 2010 | Admiral Refrigerators
How do i find out age of my kenmore fridge model # 596 62822200
Your Refrigerator was Made By Amana (( The first three numbers are the true manufacture, Sears and Sears kenmore or kenmore Do not make Machines. )) you will need your serial number to find the Age. go to this link and use the Amana refrigerator link to find your Age.
Jan 14, 2010 | Refrigerators
Don't know if this old fridge is worth saving.
Can't tell the age without the serial number, but it is a 21 cubic foot refrigerator. Plug it in, if it cools could be a good garage fridge.
Jun 14, 2009 | Refrigerators
Age of Kenmore side by side refrigerator
Brand: Kenmore
Type: side by side refrigerator
Country: USA
Model: 106.58123700
Serial: HRW2754229 This product appears to have been manufactured the week of June 30, 2008
for anything like that next time on any other appliance check out this link by clicking it directly
http://www.appliance411.com/service/date-code.php
Apr 01, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
Refrigerators Logo
12 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
